(2017-03-04, 15:20)Guilouz Wrote: [ -> ]Yes, read first post...
Required Add-ons :
- Script SkinShortcuts : This addon is needed to personnalize home menu and widgets. Dependancy script.module.simpleeval is needed for Kodi 18 version.
"Android", I found a bug, very small but makes you think that the skin doesn't work!!!
After installing everything, addons and dependencies, you will only see the background and side menu, but its because in the settings of all the Menu Widgets are set to none.I have to manually activate all of the widgets one by one to the normal defaults.
Bug
Under "Customize Menu" ----> Set type if widget: None.
I also tested this on fresh installs to confirm.
Skin Shortcuts & submenus work nicely (moving, removing, renaming etc.) but I cant seem to add new items to the main menu, nothing happens when I press "add item".
(2017-03-04, 22:01)abescalamis Wrote: [ -> ] (2017-03-04, 15:20)Guilouz Wrote: [ -> ]Yes, read first post...
Required Add-ons :
Bug
Widget are set by default. After installing all necessary addons and latest skin, you need to reboot to load menu for the first time.
(2017-03-04, 22:10)Raitsa Wrote: [ -> ]Skin Shortcuts & submenus work nicely (moving, removing, renaming etc.) but I cant seem to add new items to the main menu, nothing happens when I press "add item".
Yes, that was a mistake. It's fixed, new version 2.1.2 available on repo.
(2017-03-04, 22:41)Guilouz Wrote: [ -> ] (2017-03-04, 22:01)abescalamis Wrote: [ -> ] (2017-03-04, 15:20)Guilouz Wrote: [ -> ]Yes, read first post...
Required Add-ons :
Bug
I found the problem, the link you posted above for the "Script SkinShortcuts" is different from the one in the first page. after installing the one from the first page everything worked good, please delete or correct the link.
Every time I try to install the skin from the repo I get a "Installation failed" message.
Is there a manual file somewhere?
Greets
(2017-03-05, 12:17)-Zeppelin- Wrote: [ -> ]Every time I try to install the skin from the repo I get a "Installation failed" message.
Greets
If it's a new install, be sure to be on kodi 18 Leia latest nightly
If it's an update from previous release of this MOD, installation will fail if the MOD is in use
Here is what to do:
-switch back to stock estuary in kodi settings
-close kodi
-restart kodi
-update the MOD
-reselect this MOD in kodi settings
was failing on update but has now updated, apart from having to set up all widgets it seems to be working again!
Such a great skin, big thanks to the author.
After spending a bunch of time navigating on this skin, I must say that is the first time using XMBC/Kodi, that I can't find anything else to improve/request. Is perfect for me, so I have to say, thanks Guilouz.
Little issue in movie library using infowall
When using infowall and movie sets, movies poster are shown on the left part of the screen
All works good if the movie set has at least 3 movies in it:
and even 4 or more:
But if you have only one movie (or maybe 2 but I can not test this case), then the movies posters are not centered anymore:
New Update 2.0.3 on repository :
• Fix centered posters on some views
• Fix missing posters flag for moviesets with Wall (Thumbnails) view
• Minor fixes
