hey Guilouz,
with lyrics addon, it will show the animated lyrics with a little bit of text lyric. it seems when the lyrics have big blocks of text instead of broken up in small parts.
lyrics:
(shows text in the background)
Jag gick i ett kvarter idag, som en gång var min egna värld, ja.
Allting var ju enklare då, men ingenting kan bli vad det var, nej.
Man ser tiden är förbi, snart är det för sent, livet det går fort och det är svårt att hinna med.
Men vi kanske kommer se, en ljuv dag i Lund, kanske ölen kommer ta oss på det djupa en stund.
vs
(doesnt show text in background)
Det är ungdomens förfall
gör dekadansen
ingen lugn man det blir ingen rast
hungrig man har binnikemask
slukar allt växer ur min kostym
gör rent hus som en inbrottstjyv
rent hus som en lokalvårdare
tuggar spottar ut varje vokal hårdare
och varje konsonant
pallar ingen kontrollant
(2017-05-03, 04:25)Guilouz Wrote: [ -> ]Can you try last git ?
i have installed 2.2.9 now, but its still happening
same lyrics in classic style and animated
(2017-05-03, 05:50)davidx Wrote: [ -> ]same lyrics in classic style and animated
What resolution do you use ? Because it's working fine for me in 1080p.
(2017-05-03, 07:59)3500 Wrote: [ -> ]
the banner and the thumbs of my series being stretched.
am i right? can you fix this?
Only banners are stretched, thumb are scaling.
EDIT : Fixed on last git.
(2017-05-03, 12:28)Guilouz Wrote: [ -> ] (2017-05-03, 05:50)davidx Wrote: [ -> ]same lyrics in classic style and animated
Acccording to his screenshot ratio, I would bet on a 16:10 screen with 1920*1200 resolution
Hi Guilouz, two small requests for you.
1. I've seen you use a really good icon for the party mode playlist, which is like a DJ, but can't find this icon in the icon list. Do you mind to add it into the list to use it in my playlists?
2. Talking about the music fullscreen view (the one with the lyrics), have you think about doing a bit more transparent the bottom bar? The one with the MP3 logo and the KBPS. I think doing it more transparent will create the appearance of a cleaner screen, and allow to see the background completely. What you reckon?
(2017-05-03, 23:54)ferent Wrote: [ -> ]Hi Guilouz, two small requests for you.
1. This icon ?
2. Like that ? Same as top bar. And it's better on video OSD too.
Before
After
(2017-05-04, 00:46)Guilouz Wrote: [ -> ] (2017-05-03, 23:54)ferent Wrote: [ -> ]Hi Guilouz, two small requests for you.
1. This icon ?
Yes, that icon, and yeah! looks much better that way, from my point of view. Great job as always.
(2017-05-04, 01:50)ferent Wrote: [ -> ] (2017-05-04, 00:46)Guilouz Wrote: [ -> ] (2017-05-03, 23:54)ferent Wrote: [ -> ]Hi Guilouz, two small requests for you.
1. This icon ?
I do not understand why I have not done this before, it's much better. Available on last git and probably tomorrow on repo.
New Update 2.2.9 on repository :
• Add support for extendedinfo youtube list
• Add shortcut for movies set info to context menu
• Add shortcut for extended info to context menu
• Fix aspect ratio on tv shows widgets
• Fix lyrics on music visualisation
• Fix channel osd recording indicator visibility
• Fix esthetic appearance
• Minor fixes
• Minor changes
Just wondering how the support for extendedinfo youtube list works. Do I have to create something ? How can I access to this new thing?
