(2018-01-05, 22:42)rudrood Wrote: [ -> ] (2017-12-30, 22:09)rudrood Wrote: [ -> ]@Guilouz,
Since Milhouse build 1228 the pvr endtime in OSD is Always the same as current time. Also the progressbar at the bottom is constant filled.
This also triggers nextup notification all the time.
Using TVHeadend (pvr.hts). In the Original Estaury skin it's oke.
See samples (first stock Estaury, second Estaury Mod 2).
http://imgur.com/gallery/NWfRv
N.B. Resolution for pvr is still shown as 3D.
Can provide you access to my TVHeadend server if needed.
Thanks,
With the latest version on Git the OSD options are fixed.
But the progressbar on the OSD that shows for a few seconds when switching channels is beheaving strange.
Nextup for PVR is showing up but not a few seconds before, but after a show is finished. It then shows the next show info the complete time the current show lasts.
Don't know if it can be fixed, but pvr resolution still shows as 3D.
Try last git. Fixed PVR nextup popup and I have remove 3d tag for live tv and internet stream. If some channels are still detected as 3D, I don't know what I can do more...
Using latest nightly and version of skin on windows 10 , seem to be missing runtime and end time duration in library and on main menu. Works fine with estuary normal skin.
(2018-01-07, 19:20)elnino-1900 Wrote: [ -> ]Using latest nightly and version of skin on windows 10 , seem to be missing runtime and end time duration in library and on main menu. Works fine with estuary normal skin.
Maybe Windows builds issue because working fine on OSX and LibreELEC builds.
(2018-01-07, 19:17)Guilouz Wrote: [ -> ] (2018-01-05, 22:42)rudrood Wrote: [ -> ] (2017-12-30, 22:09)rudrood Wrote: [ -> ]@Guilouz,
Thanks,
Thanks, fixed!
Found one more:
The picons at the bottom off the epg timeline are not shown anymore. See:
http://imgur.com/a/KT8zk
(2018-01-07, 23:27)rudrood Wrote: [ -> ] (2018-01-07, 19:17)Guilouz Wrote: [ -> ] (2018-01-05, 22:42)rudrood Wrote: [ -> ] Thanks,
Thanks, fixed!
Found one more:
This icon is fallback image when SHS find nothing.
I have replaced fallback image by channel icon when no artworks are available, on last git.
No issues on Android build.
with the new Kodi 18 Alpha build from 08.01.2017 I have a problem with the skin / Skin helper service Widget...
In many cases no more Widgets are possible, because Skin Helper Service Widgets gets an error...
Any solution?
Here´s a debug log:
Debug Log
Thanks for the awesome work!!!
But is there any way to put the channels widget a little bit more beautiful ?
thanks
Apply station logos to your tv channels. This depends on your PVR backend.
You must add icons for your channels to look better, you have 2 choices :
With info on widgets tiles :
Or info with widgets titles :
Hi Guilouz, could I ask that it might be possible to increase the size of the preview window in the EPG screen? I have tried myself with help from you before but I couldn't get all the details right to show the window and info properly. If it depends on screen real estate, then I understand, but I have a lot of open space that could be used for a bigger window and even a larger grid or larger font. Just wondering ( and hoping
dreamer
