(2017-09-23, 15:52)Guilouz Wrote: [ -> ] (2017-09-23, 12:59)redglory Wrote: [ -> ]Hi @Guilouz,
I have a request.
I use script.skin.helper.widgets next and nextaired actions with path as a parameter.
ex:
plugin://script.skin.helper.widgets/?action=nextaired&mediatype=episodes&path=nfs://192.168.1.77/tvshows/&reload=$INFO[Window(Home).Property(widgetreload)]
$INFO[Window(Home).Property(widgetreload2)]'
I have to always edit skin.estuary.modv2.properties every time I need to add a new shortcut.
Can you add a new widget parameter besides: name, appearence, method and direction? Something like "filter path"
It would then be added to script.skin.helper.widgets as a parameter
Do I have to ask skin.shortcuts creator to add path as new parameter?
To my knowledge, there is no function/parameters to do that with Skin Shortcuts/Skin Helper Service.
I'll mod skin.shortcuts to implement this parameter and get back to you
Enviado do meu ONEPLUS A3003 através de Tapatalk
(2017-09-23, 13:37)Angelinas Wrote: [ -> ]@Guilouz
Add this code for background img for PVR Radio.SHS web service can show some image for Title in PVR Radio.
Look nice and easy to set if user dont want image in back
<variable name="PlayerFanartVar">
<value condition="Pvr.IsPlayingRadio">http://localhost:52307/getthumb&title=$ESCINFO[MusicPlayer.title]&type=thumb</value>
Added
EDIT : I'll have to remove it because when no info are available, it show a strange background :
Play video without pause when entering extended info don' t work for me. Everytime the video paused instead of playing further. Any idea?
(2017-09-23, 16:29)tehax Wrote: [ -> ]Play video without pause when entering extended info don' t work for me. Everytime the video paused instead of playing further. Any idea?
Just try, it's working for me.
(2017-09-23, 15:59)redglory Wrote: [ -> ] (2017-09-23, 15:52)Guilouz Wrote: [ -> ] (2017-09-23, 12:59)redglory Wrote: [ -> ]Hi @Guilouz,
I have a request.
ex:
If it's not a "official" feature in Skin Shortcuts I will not add it.
This would require using your mod to use this feature.
But if my mod gets accepted...[emoji2]
No need to use your shortcut nextaired actions with path as a parameter.
Script helper widgets have this alredy.
Just set your media folder with tv show in kodi library.And set widget
script.skin.helper.widgets-episodes-next airing episodes all working
(2017-09-23, 17:02)Guilouz Wrote: [ -> ] (2017-09-23, 16:29)tehax Wrote: [ -> ]Play video without pause when entering extended info don' t work for me. Everytime the video paused instead of playing further. Any idea?
Also with series? I have no luck. With v17 it works. I am on windows 8.1. Can you check it again?
(2017-09-23, 17:55)tehax Wrote: [ -> ] (2017-09-23, 17:02)Guilouz Wrote: [ -> ] (2017-09-23, 16:29)tehax Wrote: [ -> ]Play video without pause when entering extended info don' t work for me. Everytime the video paused instead of playing further. Any idea?
Ah yes ! Missing condition for episodes. Fixed in next release. Thanks.
(2017-09-23, 17:48)Angelinas Wrote: [ -> ]No need to use your shortcut nextaired actions with path as a parameter.
But I separate my TV shows by type (documentaries, TV shows, stand-up) and don't want to have next airing episodes of stand-up series appearing in TV shows widgets. That said I use path as a parameter in skin.helper.widgets.
Yes, it works great and now with background image
watch gallery
Btw is it possible to get artist infos and pictures such as same as it works with spotify addon?
(2017-09-23, 19:33)tehax Wrote: [ -> ]Yes, it works great and now with background image
watch gallery
I don't use Spotify. Screenshot ?
