(2015-07-13, 14:59)bigwillch Wrote: [ -> ] (2015-07-05, 20:54)magy77 Wrote: [ -> ]i like to see a shadow behind the watched sign for better visibility.
I'd like it if the watched status was a bit more visible too. Maybe a white triangle in the top right corner under the tick?
Haven't found anything I like yet, but still trying a few things. If I come up with something I like I will add it
(2015-07-13, 22:21)wagnumpi Wrote: [ -> ] (2015-07-13, 20:42)wagnumpi Wrote: [ -> ]Hi Im using this skin with Isengaard and would like to use the these smart playlists mentioned as backgrounds for my home screen but can only see single image or multi image as options and any amount of reloading does nothing to the options?
Also, is their anyway to allow music playlists to start at startup with this skin as with these two things solved ive found my favourite new skin! Great work by the way
Just wanted to point out ive just updated to the latest version of the skin and I can see my music playlists but no preloaded skin playlists when trying to select backgrounds. Can i acquire these from somewhere and if so where do they need to be put so I can select them?
Thank you in advance!
Isengard not supported yet. Skin is Helix only (most things work in Isengard though).
The smart playlists are in addons/skin.arctic.zephyr/extras/playlists
(2015-07-14, 18:00)Magic815 Wrote: [ -> ]The more I use this skin, the more I like it. A few small nits I've thought up as I've used the skin. Would love to hear some thoughts on them:
1. I've been liking the classic widget view in horizontal mode. I've noticed, however, that the name of the widgets (i.e 'In Theaters' or 'Popular Movies') is not displayed unless I press up into the widget itself. When I played around with the vertical mode, the name of the widget was viewable even when you weren't "in" the widget. Is there a way to get that sort of behavior in the horizontal condition? I found that going from 'classic' to 'normal' mode with the widget makes the name viewable as well, but then it only shows the first widget listing. I much prefer the longer list to be shown in the 'classic' view.
2. Is there any way to make the home menu text larger? I already have font set to 'large' in the settings, but I'd love to have the menu itself ('Movies,' 'TV Shows,' 'Settings,' 'Power,' etc.) shown a little bit bigger. By default it looks great as-is on my computer, but when I'm using Kodi on my big screen TV across the living room, it'd be nice to have the home menu options a little larger. Some sort of controllable slider/setting would be awesome.
That's pretty much all I can think of. Everything else seems perfect to me.
1. I've tried this before, but it was a real pain with the animations and I couldn't get anything that I liked. I may return to it eventually, but its not a priority.
2. You can edit the 1080i/Font.xml file and change the "Home" item to a larger point size.
(2015-07-16, 00:21)Namerp Wrote: [ -> ]could we get
SkinSettings.xml
@line 368
<label>$LOCALIZE[20342] [LOWERCASE]$LOCALIZE[31178][/LOWERCASE]</label>
<label>$LOCALIZE[20343] [LOWERCASE]$LOCALIZE[31178][/LOWERCASE]</label>
completely arctic localized ? at least at the german localisation it looks ugly like hell
Kodi local 20342 = Movies
Arctic local 31178 = Hub items
result is Movie hub items but at german we need Movie-Hub Items
Will do
(2015-07-16, 13:06)Sabish Wrote: [ -> ]Hi Jurial,
Excellent work on the new OSD ! Really cool ...
I have a little suggestion/question (forgive me if it has been asked before) : would it be possible to have an option to not show the watched indicator, and instead having an option to show a little icon only on the unwatched items (the one with the little blue star). I like this approach a lot better, as it doesn't "cripple" the skin with multiple litlle green checkmarks, wich is pretty much the only thing i dislike in the skin
Hope you can take this into consideration, have a nice day
Will add an option in when I get the chance. BTW, the blue star indicates that something has been recently added (not just unwatched).
(2015-07-19, 02:54)Razze Wrote: [ -> ]Hey jurial,
thank you for the newest version of artic. Still an amazing skin.
Can you implement a fallback if the artist slideshow has no pictures to slide through? So it won't be black but show the album artwork or something like that?
If that something that has to be done by an addon, please let me know.
Fallback to the album artwork isn't very nice because sometimes the resolution can be poor.
You can change Artist Slideshow settings in Settings > Addons > Enabled Addons > Programs > Artist Slideshow > Configure
In the addon settings you can set a fallback slideshow for when no images are available. There should also be an option to use both local and remote fanart images (and choose the priority of which is used first).
(2015-07-19, 08:20)Knight77 Wrote: [ -> ]I know it sounds stupid...but Dark with dark dialogues and Dark with light dialogues looks the same to me. What is the difference? Or maybe the question is...what is intended as "dialogue"?
Dialogs are things that pop up on the layer above the main layer -- things like: Context Menu, View Menu, Yes/No and Ok Dialogs, Progress Dialog, Select Dialog (used when choosing a skin for example), Skin Customisation Dialog, File Browser Dialogs, the dialogs on the OSD when click Audio/Video/Bookmarks etc.
I prefer Dark with Light Dialogs, but some people find that Light Dialogs are too bright and hard to read.
(2015-07-19, 18:32)magy77 Wrote: [ -> ]Now playing is not shown when you navigate threw the widget. Id like to see this threw the navigation too
Fixed on git.
(2015-07-19, 21:34)im85288 Wrote: [ -> ] (2015-07-19, 19:51)Gustovier Wrote: [ -> ]All,
When you you do fast forward/rewin skips I've noticed the Osd time bar doesn't advance to the point where the video would start playing while your skipping around. This makes it hard to figure out where in the show/movie you will end up. Is this maybe already built into the skin and I just have to turn it on?
Are you using Kodi Isengard? It has changes included for adaptive seeking. I'm not sure if it's been added yet in this skin. I added it to my version about 6 weeks ago.
Yep Isengard isn't supported yet. Beginning work on Isengard support this week..
