You can also set custom widgets by navigating to the particular plugin folder you want to set and open side menu and choose set custom widget. Saves having to put the path in manually.
big thank you for that amazing skin!
finally I found a skin who gave me a reason updating to Kodi. I used Arctic mk. II before.
I have a question someone might can help me with? I removed somehow the top bar in the film/music library what shows me how many film I have - and cant get it back.
(2015-06-07, 17:33)fqpl Wrote: [ -> ]big thank you for that amazing skin!
I haven someone might can help me with? I removed somehow the top bar in the film/music library what shows me how many film I have - and cant get it back.
Settings -> Skin Settings -> Furniture
Enable "Show Header" on the right side
thank you so much. I must have been blind!
do you actually know If I that skin is able to show the spinning CDs while playing music?
im85288 has made "[MOD] Arctic Zephyr - Custom version" which is mod over the Arctic Zephyr and has the spinning disk.
great! which version do I have to download?
Edit: found it!
Hi JM
I have a question
Is this intentinal that when the focus on the right listing is on "Directed by..." that there is not picture of director on the left side as is for actors?
Unfortunately there isn't a way to get the director image so that's why it's like that. I'm thinking that I might change it so that it shows the movie poster so at least it's same aspect ratio as rest of the cast.
(2015-06-08, 05:41)jurialmunkey Wrote: [ -> ]Unfortunately there isn't a way to get the director image so that's why it's like that. I'm thinking that I might change it so that it shows the movie poster so at least it's same aspect ratio as rest of the cast.
is this using extended info? can't we just add it there?
any chance of official support for this
http://forum.kodi.tv/showthread.php?tid=228435
I see, thanx for explanation. It doesnt bother me, jut out of curiosity.
(2015-06-08, 09:42)Razze Wrote: [ -> ] (2015-06-08, 05:41)jurialmunkey Wrote: [ -> ]Unfortunately there isn't a way to get the director image so that's why it's like that. I'm thinking that I might change it so that it shows the movie poster so at least it's same aspect ratio as rest of the cast.
any chance of official support for this http://forum.kodi.tv/showthread.php?tid=228435
No it's just the standard kodi video info window, not the extended info one. Uses kodi library data so that extended info is optional rather than a dependency (extended info is only called on click of cast member if it is installed).
Got some free time coming up in a couple of weeks so will be making some skin improvements then. Will look at the next up option then.
(2015-06-08, 10:48)jurialmunkey Wrote: [ -> ] (2015-06-08, 09:42)Razze Wrote: [ -> ] (2015-06-08, 05:41)jurialmunkey Wrote: [ -> ]Unfortunately there isn't a way to get the director image so that's why it's like that. I'm thinking that I might change it so that it shows the movie poster so at least it's same aspect ratio as rest of the cast.
Thank you!
That means the kodi db has pictures for actors downloaded? Wasn't aware that it scraps these too
Yep kodi downloads actor thumbs for movies.
I just ran Artwork Downloader addon and now I have no fanart showing in the home menu, what can I do to fix? :/
