(2015-03-06, 16:18)reap705 Wrote: [ -> ]Just donated and want to say thanks for Arctic: Zephyr and Eminence. Both great skins and my favorites.
Keep up the great work!
Greets from Germany
Much appreciated!
(2015-03-06, 17:29)furii Wrote: [ -> ]noticed a small bug. if you're using the media info view with the extra info selected and an episode does not have a rating the title text continues past the indicators.
Good catch. Fixed on git.
(2015-03-06, 18:28)Darkxide Wrote: [ -> ]Hi Jurial,
I simply love your new skin been using it for a few weeks now it's amazing.
Any idea what viewtypes will be supported on Advanced Launcher?
Keep up the good work
Most likely pretty much all of them
Because of different cover aspects, pretty much every view fits Adv Launcher. Its basically just me getting around to setting Adv Launcher up again for testing as I haven't used it in a while and I've done a clean install on both my machines since I last used it.
(2015-03-06, 20:03)Edworld Wrote: [ -> ]Can't wait to get back home and load the latest and greatest.
thanks again
(2015-03-06, 22:23)Feralwolf Wrote: [ -> ]Hi guys,
I've recently installed the skin - switched from Mimic - and have a few questions.
First: While playing a video and access the Player Controls (keyboard shortcut: M), I have access to the Extra Info button. What does it do? Clicking it does nothing. Does it depend on an add-on? Is it in development?
Second: When pausing a video I would prefer if the information tab came up as well, is that possible?
Third: What is the purpose of the above image. Does it use an add-on to stream the selected video (CAM)? Does it only provide information? What are the dependencies, if any.
Fourth: I'm not familiar with much of the supported add-ons on the first page. Which of those would be beneficial for a video-only XBMC setup? Can anyone post an image of the add-on with this theme and it's purpose.
1. It literally shows extra info for now playing video. Requires script.extendedinfo.
Can install from Settings > Addons > Get Addons > Helper Addons > ExtendedInfo
2. Yes. Skin Settings > OSD > Show detailed info when video is paused.
3. Requires Extendedinfo script. It shows information about movies that are in cinemas, coming out soon, popular on themoviedb, top rated on themoviedb. There is a similar window for tvshows.
4.
CULRC Lyrics -- Shows lyrics for the currently playing song in the music vis screen.
Cinema Experience -- Provides a "cinema experience" -- e.g. trailers etc.
http://kodi.wiki/view/Add-on:Cinema_Experience
Next Aired -- Provides information in tv library about what date a show will air and or the last aired episode of a cancelled show. Also has a window run from programs which shows a calendar of when tvshows in your library air.
http://kodi.wiki/view/Add-on:TV_Show_-_Next_Aired
Global Search -- Allows you to search all your media for items matching the search query. Used for search function from side menu.
Extended Info -- Provides metadata actors functionality. Allows additional info about cast members from video info screen. Provides trending movies/shows widgets. Provides extrainfo from osd controls. Provides lists of movies from director. Similar movies. Incinemas/Airing windows
Info Service -- Provides details about sets. Provides audio/subs language details in movie info dialog.
https://github.com/phil65/script.skin.info.service
TV Tunes -- Plays downloaded theme songs for tvshows when entering a show from the library
http://kodi.wiki/view/Add-on:TvTunes
Artist Slideshow -- Provides a slideshow of images for the currently playing artist in music vis.
Video Extras -- Allows access to extras/outtakes etc. that are in a special folder for videos that usually wont get scraped. Access from videoinfo dialog.
http://kodi.wiki/view/Add-on:VideoExtras
Artwork Downloader -- Allows downloading of additional artwork types for items in your library.
http://kodi.wiki/view/Add-on:Artwork_Downloader
