(2015-06-18, 12:29)mark2112 Wrote: [ -> ]Getting this on all extended info screens .
Should be fixed now. Completely forgot about those windows.
(2015-06-18, 12:30)im85288 Wrote: [ -> ] (2015-06-18, 04:29)jurialmunkey Wrote: [ -> ]Coming Soon...
Here are some of the new style changes coming to the info/extendedinfo screens. Movies/Shows/ExtendedInfo are done. Just need to do the other ones now (programs, addons, music, pvr).
Nice, will you be incorporating the auto complete feature provided by the same script?
Eventually. I want to get NextUp skinned first
New Viewtypes
Inspired by a couple of the new views in the mods floating around.
Big Wide - Rolodex (Classic mode available from side menu)
Banner Wall
Just gets better and better Jurial. Thanks.
jurialmunkey
the slideshowfunction in the main menu is working gr8 now...
may you can decrease the dealy a little bit?
Whoops, left a long delay in from when I was testing stuff. Should be the same as normal now.
(2015-06-19, 08:38)jurialmunkey Wrote: [ -> ]Whoops, left a long delay in from when I was testing stuff. Should be the same as normal now.
good that we´ve talked about that!
jurialmunkey
btw. could you make the classic widget view scrollable?
it only shows the movies or series that match the screen....
(2015-06-19, 08:48)b0mb Wrote: [ -> ]@jurialmunkey
You change the amount of items shown by editing Includes_Home.xml and changing line 1091. This one:
<content target="video" limit="10">$VAR[DefWidgetContent]</content>
Change the limit to whatever value you desire.
ok!
will try that later... thx!
(2015-06-19, 09:45)jurialmunkey Wrote: [ -> ] (2015-06-19, 08:48)b0mb Wrote: [ -> ]@jurialmunkey
Hi mate, but... could this limit be handled with the smartplaylist limit behind the scenes?
In that case this would be totaly controlable by user it self without forcing the hardcoded limitation.
So, changing line 1091 to:
<content target="video">$VAR[DefWidgetContent]</content>
would fit everyones needs.
I dont know if there would some other problems arise behind the scene in that case, so if I am talking a rubbish here, then just ignore me.
cheers
(2015-06-19, 01:10)jurialmunkey Wrote: [ -> ] (2015-06-18, 12:29)mark2112 Wrote: [ -> ]Getting this on all extended info screens .
Cool, you can always use the ones from my mod as a basis
Love your take on the views I added, great stuff!
TV Tunes turned on with the latest release and I can't for the life of me figure out how to turn it off. (The tickbox in the settings menu doesn't work - it stays on regardless.)
Anyone else experiencing this issue?
(2015-06-19, 14:06)deletedpenguin Wrote: [ -> ]TV Tunes turned on with the latest release and I can't for the life of me figure out how to turn it off. (The tickbox in the settings menu doesn't work - it stays on regardless.)
Pretty sure you have to go into Settings > Addons > Programs > TvTunes > Configure and change the setting there now.
jurialmunkey, I played around with the new extended info screens last night. Man I have to say well done. I've been running im85288's mod and I liked those screens but they were a bit hard to navigate for certain information, even though they're great. You definitely put usability into these ones with a little flash.
Keep up the great work
