Can you move NextUp notifications to the top? I use subtitles and it would be very helpful!
Also the vertical menu looks good so far
Vertical menu looks great - though the background doesn't shine through enough. I realise you have to find a happy medium between transparency and readability, but my vote would be to let the images shine through a little bit more.
(2015-07-03, 03:41)Deihmos Wrote: [ -> ]Thanks but it does not work since I use classic widgets. I am only seeing movies.
It works, you just have too many movies to display which are pushing the episodes off the side. Maybe you are looking more for something like this:
plugin://service.library.data.provider?type=recommendedepisodes+recommendedmovies+randommovies&reload=$INFO[Window.Property(recommendedepisodes)]$INFO[Window.Property(recommendedmovies)]$INFO[Window.Property(randommovies)]
(2015-07-03, 04:01)calhaus Wrote: [ -> ]Can you move NextUp notifications to the top? I use subtitles and it would be very helpful!
I imagine this would annoy other people as top right is much more intrusively visible than bottom right... you might have to modify it yourself.
(2015-07-03, 04:09)deletedpenguin Wrote: [ -> ]Vertical menu looks great - though the background doesn't shine through enough. I realise you have to find a happy medium between transparency and readability, but my vote would be to let the images shine through a little bit more.
Yeah I know. The point is to match the fade between library and home so it seemlessly transitions - when it has more or less of a fade than the library then the transition looks odd.
How much fanart is faded can be controlled in the color schemes in skin.arctic.zephyr/colors/
edit the xml corresponding to the theme you use and change:
<color name="FanartFade">2Fffffff</color>
Change the "2F" part to a different hex value -- higher values show more fanart
(2015-07-03, 04:20)jurialmunkey Wrote: [ -> ] (2015-07-03, 04:09)deletedpenguin Wrote: [ -> ]Vertical menu looks great - though the background doesn't shine through enough. I realise you have to find a happy medium between transparency and readability, but my vote would be to let the images shine through a little bit more.
Ah, I figured there was a reason for it. Makes sense. Thanks!
OMG, so cool, this I was missing a long time, since I would like to have some more transparency.
Thank you
Is there any way that you could add this setting to extras, so anyone can easyer control this?
Is there and option that you would add also possibilitie for selecting secondary highlight color to extras?
Stoked that you skinned the YouTube addon. Hope Phil develops it further because it's really cool.
Can you add an indicator that there is a submenu on the vertical menu? New menu looks very good BTW.
out of curiosity how messed up is a:z on isengard? now that we're at rc1 i was considering giving it a try but don't want my favorite skin messed up
How to launch this youtube browser ? I have the latest extendedinfo script and youtube browser script but my youtube is the same as before...
EDIT : I found. It necessary to launch the script and no Youtube addon.
(2015-07-03, 17:26)radicalonions Wrote: [ -> ]Can you add an indicator that there is a submenu on the vertical menu? New menu looks very good BTW.
Definitely just trying to figure out the best way to do it.
(2015-07-03, 18:50)furii Wrote: [ -> ]out of curiosity how messed up is a:z on isengard? now that we're at rc1 i was considering giving it a try but don't want my favorite skin messed up
Not sure haven't tried.
Although now we are at rc stage and have the vertical menu pretty much done I will be making isengard changes over this next week
