2015-06-24, 20:03
Love the skin, but the one thing I love from the mod versions of the skin are the nice icons for video ratings, codec, sound format, etc. Any plans to add these to your main skin?
(2015-06-24, 19:42)BlackRose Wrote: [ -> ]JurialMunkey, just started using this theme. Arctic: Zephyr is a masterpiece. You continue to set the bar that much higher than the rest!
Have been using Eminence for some time and decided to give this one a try, and need I say, it's even better. Anyhow, wondering if there is an option like Eminence's "Set Global Background Widget" so a standard playlist can be used as global fanart on the home screen?
I'm struggling to find such an option, but I may just be being thick. Any of you kind folks know?
Once again, great skin. Best available.
(2015-06-24, 20:33)Crssi Wrote: [ -> ](2015-06-24, 19:42)BlackRose Wrote: [ -> ]JurialMunkey, just started using this theme. Arctic: Zephyr is a masterpiece. You continue to set the bar that much higher than the rest!
Create smartplaylist with desired filters... make the order random. Then edit this playlist as a file and set limit to 1 to make random trully work (unfortunatelly kodi gui doesnt allow you to set lower then 10).
Then set this playlist as a background for every main menu item you have... I believe there is not too many.
But then again you can make different smartplaylists, one for every single menu item... if you wish.... how nice is that
(2015-06-24, 21:49)Crssi Wrote: [ -> ]I will be out until next week, but I can try to help you next week over PM, to avoid hijacking this thread... because this logic has nothing to do with a skin.
I just wanted to show you here that this skin supports all variety of scenarios you would like to achive, so in short:
OK... there are two (actually 3) kinds of playlists... basic (thats one you are refering), but it is surelly in extinction and the only real future is a smartplaylist.
See here http://kodi.wiki/view/Playlists... here you will find also smartplaylist description and usage.
I am also refering to set a smartplaylist as a background on the menu where you create home items (kodi settings -> skin settings, "home" on the left and "customise home menu" on the right), there you will find also "background".
Then I have created few smartplaylists for background usage (beside others for views).
One for movies, one for cartoon movies, one for tv series... etc.
My movies are in movies folder, cartoons in cartoons, series in series etc...
Now you can start filtering in smartplaylist, where you set that you are interested for movie media and you set a filter where PATH contains /movies/ (for movies obviously).
To make background more attractive and kids friendly:
"MPAA rating" contains G (to avoid violent funarts)
Genre is Action,Adventure,Family,Fantasy,Science Fiction (those funarts are most iCandy)
Genre isnot Comedy,Drama,History (those funarts are boring)
Year greatherthan 2000 (200 is a wild guess, but old movies does not have very quality funarts)
(2015-06-20, 15:19)jurialmunkey Wrote: [ -> ]NextUp Addon
(2015-06-23, 15:38)jmccrack650 Wrote: [ -> ]Since 1.2.9 all views that don't display runtime by default show the runtime in the media flags at the bottom -- so yes Big Icons does show runtime.(2015-06-23, 15:33)Crssi Wrote: [ -> ]Big icons is almost as the one but much iCandy.Not sure it includes runtime (or maybe I am forgetting). That is the one piece of metadata that I constantly want to see, but isn't included in many skins/views.
The only info missing from Big icons is director and writer. But then again it would make skin/view overbloated and ugly... i think
(2015-06-23, 17:32)Redtusk Wrote: [ -> ]The problem is that the RPi 2 isn't very powerful as it is, and the loading of the thumbnails slows the addons down so drastically that I have to wait ~1 minute before I can even navigate inside the addon, since I need to wait until it's done loading.All large images are loaded by the background image loader so this shouldn't happen... Are you sure this doesn't happen in other skins? If so which ones does it not happen in so I can have a look.
Is there any code I can "break" to prevent the loading of thumbnails for said type of addons? It would really bug me if I had to switch back to a different skin since yours is far superior to anything else I've seen.
(2015-06-23, 22:31)djselbeck Wrote: [ -> ]I really like your themes. Especially this one. Keep up the good work please .Thanks
Would love to see more people making so elegant/minimal themes.
(2015-06-24, 19:42)BlackRose Wrote: [ -> ]JurialMunkey, just started using this theme. Arctic: Zephyr is a masterpiece. You continue to set the bar that much higher than the rest!Best option is to just set each individual menu item widget to the playlist (Skin Settings > Home > Customise Home > Select Widget). A little more inconvenient than in Eminence I know, but the way widgets are handled in A:Z is a little different and offers up even more customisation than in Eminence so its a trade off for some great possibilities.
(2015-06-24, 20:03)jmccrack650 Wrote: [ -> ]Love the skin, but the one thing I love from the mod versions of the skin are the nice icons for video ratings, codec, sound format, etc. Any plans to add these to your main skin?Check latest git
(2015-06-25, 02:31)eachmharcaigh Wrote: [ -> ]Love the skin, any chance of a Fanart/Showcase viewtype? Like what's available in amber:
(2015-06-26, 03:34)jurialmunkey Wrote: [ -> ]1.4.8 - Codec Flag Icons
Enable: Skin Settings > Furniture > Show icon media flags
(2015-06-26, 03:33)jurialmunkey Wrote: [ -> ](2015-06-23, 17:32)Redtusk Wrote: [ -> ]The problem is that the RPi 2 isn't very powerful as it is, and the loading of the thumbnails slows the addons down so drastically that I have to wait ~1 minute before I can even navigate inside the addon, since I need to wait until it's done loading.All large images are loaded by the background image loader so this shouldn't happen... Are you sure this doesn't happen in other skins? If so which ones does it not happen in so I can have a look.
