tnx been kinda offish on this forum so i didnt check the backlog
now i know atleast now i can return to my slumber
Can I make the widgets only load at startup? It takes too much time reloading every widget whenever I navigate the menu
Do you have any thoughts/plans on global search integration? Or is that already in there and I haven't located it. I only mention this as I may start working on it for my mod but if the logics already there or your planning on adding it I won't reinvent the wheel
I can't see if pvr is recording when scrolling through the channels, i''d love to see some kind of indicator in TV channels/OSD channels !
tia
greetz
Lednurb
(2015-06-11, 10:52)im85288 Wrote: [ -> ]Do you have any thoughts/plans on global search integration? Or is that already in there and I haven't located it. I only mention this as I may start working on it for my mod but if the logics already there or your planning on adding it I won't reinvent the wheel
Side menu > search
(2015-06-11, 20:30)lednurb Wrote: [ -> ]I can't see if pvr is recording when scrolling through the channels, i''d love to see some kind of indicator in TV channels/OSD channels !
tia
greetz
Lednurb
Will look into it next week when I have some time to work on the skin.
[Feature Request]
Please add Radio to the Live TV SubMenu by default for the Skin, Custom action:
ActivateWindow(RadioGuide)
Also TV Channel Logo scaling has been messed up since way back in the Eminence days, both in the Recordings View and the Channels View. Is it possible to get this finally fixed please. ?
Looks like carry over common code
Thanks J.
I noticed there are no watched etc indicators in TV recordings, any chance adding them?
tia
The only reason I don't use this skin is the lack of Advanced Launcher views ATM. My HTPC is more gaming oriented. It looks great otherwise.
(2015-06-08, 19:36)colbert Wrote: [ -> ]I just ran Artwork Downloader addon and now I have no fanart showing in the home menu, what can I do to fix? :/
I am getting a random fanart background sometimes and other times black background, can't get the fanart to work. I am checking the show fanart in skin settings but it is inconsistent, and when it does work it only shows one image and doesn't transition. Appreciate any help
