(2017-12-31, 02:48)Glavata Wrote: [ -> ]Might be a strange request, but is there a way to remove the pause bar when a video is paused, or make it take less space/have no background? I have some videos with embeded subtitles (have no control where the subs appear) which I somtimes press pause because they are too long. The pause bar gets in the way and covers the bottom part.
Thanks for the great work!
Edit: Just saw the Eminence 2.0 skin, maybe it is more suited for the OSD I need.
You can change Kodi’s subtitle placement under video settings. You might find moving them up a little bit helps with your issue
Amazing skin, thanks!
Just one question: is there a way to disable extended info script for directors too?
I wish I could display a list of the movies I own instead of retrieving infos from internet.
Extended info script is great but It would be perfect if I could choose when to use it (pressing 'down' on an actor's picture like in other skins).
watch gallery
Can anyone help with this? I have Top 100 songs as a widget for the front page. However, it is not listing artist information for the song here as you can see. Bug? Thoughts on how to fix?
jurialmunkey for media flags can you change the HD 2160p flag to display "UHD" above 2160p instead of "HD"?
I have both clearart and clearlogo checked in the settings but it's not showing up. I've tried running art downloader manually as well and nothing shows up still.
jurialmunkey no plan to use time in hours and minutes ? Sorry if it've been already answered.
Anyone elses's clearart or logo not work or is it just me?
(2018-01-13, 04:47)peterock Wrote: [ -> ]Anyone elses's clearart or logo not work or is it just me?
Do you mean you can’t download the artwork?
The artwork downloaded addon is broken due to Kodi’s api keys being revoked, however an unofficial update which allows you to add your own api key instead is available here:
https://forum.kodi.tv/showthread.php?tid...pid2678467 (read thread for more details)
(2017-11-09, 09:20)umonkey Wrote: [ -> ]This is a view from this Skin Arctic Zephyr i have just added the details at the bottom such as rating and rotten tomatoes details these have been taken from Jurailmonkey new skin Horizon. thanks
Hey, would you mind sharing how you did this?
I would love the ratings to be like this in my Arctic! Specially the RT, IMDB, Oscars logos/ratings. Or maybe @
jurialmunkey knows an easy way?
https://i.imgur.com/afAjkjc.jpg
Hi there,
yesterday my Kodi 17.6 went back from Arctic: Zephyr to the standard skin by itself after booting up. I switched back to Arctic: Zephyr and had to manually change all the options like it was before. Now I get a "Extendedinfo-Script Error" each time I open an Info-Page of a Movie or TV-Series. I allready reinstalled the Script but nothing changed. I'm running LibreElec 8.2.2 on a Raspberry Pi 3.
What can I do to get rid of the error?
(2018-01-13, 08:40)bigwillch Wrote: [ -> ] (2018-01-13, 04:47)peterock Wrote: [ -> ]Anyone elses's clearart or logo not work or is it just me?
The artwork downloaded addon is broken due to Kodi’s api keys being revoked, however an unofficial update which allows you to add your own api key instead is available here: https://forum.kodi.tv/showthread.php?tid...pid2678467 (read thread for more details)
I guess that was the issue! Thanks, I couldn't get the unofficial update to work but artwork beef works good!
What a beautiful skin ! One of the best if not the best.
I have one question tho. Next to some movies/tv shows there's a blue star. No idea why it's there and what it means. Tried to mark those movies as watched/not watched and added/removed from favourites, but nothing happened. The star is still there. Any help with this will be much appreciated ! Thanks.
Hi!
I'm currently running OE 6.0.3 with Arctic: Zephyr Skin. I am planning to switch to LibreElec 8.0.x with Kodi Krypton 17.6.
The question is: when I switch (update) to LE with later Kodi release, does my Arctic: Zephyr Skin also auto-update?
Much appreciated
//timo
