jurialmunkey Wrote:I'm still not quite sure what you are referring to. A screenshot would help.
Ok, i will do at home. Can i change the DCA text somewhere by myself? Which XML file is it?
thx in advance
No its a info label populated by kodi based upon the codec info in the file. Afaik there isnt a way to change it.
Awesome implementation of the extended info script. Keep finding it pop up in different places.
(2015-03-19, 07:23)Flest Wrote: [ -> ] (2015-03-19, 02:08)jurialmunkey Wrote: [ -> ] (2015-03-18, 16:34)Flest Wrote: [ -> ]may be to add an option "duration"?
mmm or hh:mm
I'm not sure what you mean exactly?
http://img15.hostingpics.net/pics/538071291.png
http://img15.hostingpics.net/pics/474834332.png
would be nice to add length "season" and the total length of the tv series like dd:hh:mm
and... the length of the films set
and transparency settings in the main menu
I'm really missing the duration on the "on deck" features. It's pretty annoying if you don't know how long a episode is and you don't have a clue if you can fit it in your day.
I found bug. When I open custom windows I have wrong labels on my lcd (LCDProc addon and label $INFO[System.CurrentWindow]).
ex.
In window ID 3204 lcdproc shows label 13204: "Last loaded profile:"
In window ID 3201 lcdproc shows label 13201: "Delete profile '%s'?"
In window ID 3205 lcdproc shows label 13205: "Unknown"
I noticed that in other skins too (ex Xperience1080 and Eminence).
This is because Custom id for windows should be in the range 1100–1199 (this id's don't have labels in strings.po)
(2015-03-19, 10:09)Razze Wrote: [ -> ] (2015-03-19, 07:23)Flest Wrote: [ -> ] (2015-03-19, 02:08)jurialmunkey Wrote: [ -> ]I'm not sure what you mean exactly?
this is already there on the right-hand side. it states the show name, date aired, runtime and rating.
Just installed the Artic skin, thanks for the great work. Loving the clean but stylish layout.
Just 2 things i noticed and might make the skin more perfect:
1. Live-TV, in the OSD Channels Window (during playback) nagivation Left en Right to switch between Groups is not working. Is it possible to add this to make switching groups during watching easier and prevent having to go back to the menu.
2. Live-TV, codec-info is not showing the signal quality and transponder, maybe possible just to copy-paste this from confluence?
Kind regards
Your #1 can be done with custom keymapping, got that working since way back the Eminence skin.
Did some other minor key mappings as well to make it 'better' or rather working exactly as MediaPortal does.
So I did some fix to allow for switching between channel groups in the tv guide view and fixed the key mapping to get the teletext buttons working, among some other fixes.
Right now I got no time but I could like tomorrow share how I did it in like a separate topic.
(2015-03-19, 07:23)Flest Wrote: [ -> ]would be nice to add length "season" and the total length of the tv series like dd:hh:mm
Not possible to do.
(2015-03-19, 20:18)Razor_109 Wrote: [ -> ]1. Live-TV, in the OSD Channels Window (during playback) nagivation Left en Right to switch between Groups is not working. Is it possible to add this to make switching groups during watching easier and prevent having to go back to the menu.
1. Fixed on git.
2. Not possible to simply cut and paste due to different variables + defaults + resolution. I will look into adding these though.
In future please post bugs in the bug thread so that I can keep better track of what I still need to fix
Alright @
jurialmunkey. The next aired widget is pretty awesome and exactly what I wanted. I found one problem with it. When I select use classic widgets and only display widgets when pressing up, the next aired widget does not display. All other modes for it seem to work
(2015-03-20, 02:18)jurialmunkey Wrote: [ -> ] (2015-03-19, 07:23)Flest Wrote: [ -> ]would be nice to add length "season" and the total length of the tv series like dd:hh:mm
Not possible to do.
is this what they're talking about
http://forum.kodi.tv/showthread.php?tid=209533
(2015-03-20, 06:36)locomot1f Wrote: [ -> ] (2015-03-20, 02:18)jurialmunkey Wrote: [ -> ] (2015-03-19, 07:23)Flest Wrote: [ -> ]would be nice to add length "season" and the total length of the tv series like dd:hh:mm
Not possible to do.
I think so but thats not in until Isengard. Regardless, afaik there isnt a way to get the total duration of a whole set or season
