Hello and thank you for this beautiful skin. I love it.
But I have a problem with fanart backward plan. When I activate the basic widget ( I love it ) nothing works properly in the fanart. I would set a fanart of Oblivion on the Movie tab, and when i active arrow up , it activates the widget on another film. and only then exchange the fanart on the widget selection film. But this is not done correctly.
http://prntscr.com/70zzk3
Everywhere there is the fanart of the selected widget. Then when I activated replaced by a slideshow widget fanart, I selected a folder, and now I can not change the folder, it s locked.
Can you help me to succeed this. Your skin is amazing. bravo
I also have a problem on the widgets in the section set up and power, there is always the active widgets, even though I have not selected widget in skinshortcut.
Thank you for a great skin.
The "Next Aired" widget could you skip to the next aired show, instead of showing the default image if nothing is airing on that day?
(2015-05-01, 18:34)Guilouz Wrote: [ -> ]First Preview, not finish
Although I don't feel its needed, let me know if you want any help designing some icons. I feel the icons should look as great as the skin itself.
when i am in the classic widget style the favorites widget doesnt show my favorites, only "no information available" but it shows them just fine with the normal style. I made sure I have the favorites script, other than that great skin.
The genre symbols are really nice! The Tie Fighter for SciFi is awesome.
Is the latest version of this skin 1.2.4 or am I missing something?
thanks
(2015-05-06, 15:34)Prizm4 Wrote: [ -> ]Is the latest version of this skin 1.2.4 or am I missing something?
thanks
that's the latest on the repo. it's up to 1.2.14 on github.
What is the difference between 1.2.4 and 1.2.14?
Where can i see the changes apart from the skin menu?
(i hope you can understand, my english is bad)
1.2.14
More seekbar bg fixes
Change alignment of notification/volume dialogs
Fix zorder osdsettingsdialog
Subtitle osd cycle subs
1.2.13
Fix videoextras bug
Arial font
Fix seekbar bg
1.2.12
Fix osd dark theme bugs
1.2.11
Small weather icons from 1080XF to accomodate palette flip on widget
1.2.10
Updated language files from Transifex
Added option in Extras to show busy loader in header instead of centered
Match colours on home screen
1.2.9
Furniture clearlogo
Time in flags for certain views
1.2.8
Flags show duration instead of codec for views without duration
Flags show aspect ratio in addition to resolution
Fix scroll on big wide
1.2.7
Weather options
- use realistic icons by default
- add fanart overlays to boxes
Double pane biglist
1.2.6
Hub fallback image
Hub items skin settings menu
Extra spinners
Fix spinner fallback
Actors search for globalsearch
1.2.5
pvrosdguide to fixed list show current at top
Fix osd streaming info
Add fanart in extendedinfo special windows (incinemas etc)
1.2.4
OSD clock finish time
Extra custom widget items
I have only the old version 1.2.4 How to Get update
(2015-05-06, 02:57)Guilouz Wrote: [ -> ]
First image:
Icons at bottom should be 70 - 80% of the current size. My eyes focused there the most - which is essentially bad.
Second Image:
Icons should be smaller, probably 60% - 70%.
Title of movie should be above the "Started from scratch...."
Missing images at the top right? Lots of dead space.
Looking great though.
(2015-05-06, 23:32)Feralwolf Wrote: [ -> ] (2015-05-06, 02:57)Guilouz Wrote: [ -> ]
First image:
Second Image:
Yes it's a preview, not finish yet
