Weekly Linux 4.12-rc2 build #0522x:
RPi /
RPi2
Same as #0522 but without the following packages:
HEVC playback is broken in #0522. Kodi crash when trying to play any HEVC file. #0521 and earlier work ok.
(2017-05-22, 21:36)Milhouse Wrote: [ -> ]@Vimes going back through the available builds would be the normal way to identify the first build with this unwanted behaviour... slow/tedious but usually effective.
I am getting some where as build 1223 (23rd Dec 2016) works fine. That contained CEC fixes.
I'll continue to work forward and let you know.
(2017-05-22, 19:48)Milhouse Wrote: [ -> ]The BD ISO crashes should be fixed in tonight's build, the "DVDDemuxFFmpeg: max_packet_size - use GetBlockSize directly" commit f1c3fc959e has been dropped from last night's build.
I can confirm for #522, iso playback works again.
I have found that build 314 works fine but from build 315 on it fails.
Build 315....
http://forum.kodi.tv/showthread.php?tid=...pid2549210
possibly relevant bit....
Quote:libcec:
added: log a warning when we detect that RPi's CEC service is used by something else, blocking libCEC. issue #191 (5469da23)
changed: const IAdapterCommunication::GetLogicalAddresses(), making the mutex mutable for now without changing the platform lib. closes #259 (0cf3f0fe)
fixed: cross compile includes (50f1179d)
fixed: detect debian based distros properly when installing python. closes #314 (f4e2ed77)
fixed: don't filter out broadcast in HandleDeviceVendorCommandWithId(). issue #309 (e1df683b)
fixed: send an active source message when a routing change has been received with libCEC's address as new route and no active source message has been sent yet. issue #309 #205 #233 (67d444dd)
fixed Commit:67d444d (d1a708b9)
fixed: vs2015 c++ redistributables (8563411d)
I have checked this twice by going up and down the builds and it is consistent with build 315 being the first to fail to switch the TV to the Pi3.
As noted at the beginning of this, the TV will switch on but the CEC config will not switch "source to this device on startup"
Hopefully that might be useful
EDIT: Just to add. This was a vanilla install. No addons, apart from the one to look for and install these DEV releases. No TV shows or Movies added. Apart from regional changes nothing else done.
(2017-05-23, 06:06)smp1 Wrote: [ -> ]HEVC playback is broken in #0522. Kodi crash when trying to play any HEVC file. #0521 and earlier work ok.
I can confirm this is the case, h264 plays ok h265 crashes every time. Also the same on #0522x
(2017-05-23, 10:54)Vimes Wrote: [ -> ] (2017-05-22, 21:36)Milhouse Wrote: [ -> ]@Vimes going back through the available builds would be the normal way to identify the first build with this unwanted behaviour... slow/tedious but usually effective.
Build 315....
this has been posted and bugged in several places without any reply thus far
http://forum.kodi.tv/showthread.php?tid=...pid2573814
https://github.com/Pulse-Eight/libcec/issues/342
either it's not a widespread issue or there is no fix...
(2017-05-23, 11:07)bleep42 Wrote: [ -> ] (2017-05-23, 06:06)smp1 Wrote: [ -> ]HEVC playback is broken in #0522. Kodi crash when trying to play any HEVC file. #0521 and earlier work ok.
My fault - will be fixed tonight.
(2017-05-23, 20:32)nuwonda Wrote: [ -> ] (2017-05-23, 10:54)Vimes Wrote: [ -> ] (2017-05-22, 21:36)Milhouse Wrote: [ -> ]@Vimes going back through the available builds would be the normal way to identify the first build with this unwanted behaviour... slow/tedious but usually effective.
Build 315....
-> http://forum.kodi.tv/showthread.php?tid=...pid2573814
-> https://github.com/Pulse-Eight/libcec/issues/342
Thanks for noting that
Interesting, as I see that it was reported at the time 315 was released.....
http://forum.kodi.tv/showthread.php?tid=...pid2566522
I had tried to search for the issue but could only think of "CEC" as the term to use, and that wasn't a long enough search string. If I had have been aware of it at least it would have saved quite a while trying to track the issue down which had already been noted, if not resolved.
(2017-05-22, 20:02)Milhouse Wrote: [ -> ]This kind of problem may well depend on your server configuration.....
Thank you for a great answer. I will try this and see if I can find the problem.
New LibreELEC.tv Leia build #0523:
RPi /
RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.11.2 #1 Tue May 23 21:34:18 BST 2017 armv6l GNU/Linux
# vcgencmd version
May 15 2017 17:01:07
Copyright (c) 2012 Broadcom
version 9469ea3706e34c4de62f38a5008f69a429b4b43e (clean) (release)
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170523213317-#0523-g0b589ed [Build #0523]
# Kodi version
(18.0-ALPHA1 Git:61e98fd). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (0b589ed6,
changelog) and tip of
XBMC master (c239aec7,
- Includes newclock5 patches
- Excludes the LibreELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.11.y
- Includes latest bcm2835-driver master (b9dbf8cf, ahead +5)
- Includes latest kodi-platform master (36fb4937)
- Includes latest libcec master (3953f8dc, ahead +12)
- Includes latest libnfs master (eee1b4f7, ahead +94)
- Includes latest p8-platform master (2d90f986)
- Includes latest addons: inputstream.adaptive (52eb1de3), inputstream.rtmp (d93d32d4), peripheral.joystick (1b19a511), pvr.argustv (b281e04f), pvr.demo (ffee02b8), pvr.dvblink (6d42eae1), pvr.dvbviewer (3f05af60), pvr.filmon (300c595e), pvr.hdhomerun (9073b99b), pvr.hts (7f998e0f), pvr.iptvsimple (dbf6011e), pvr.mediaportal.tvserver (07d73f3a), pvr.mythtv (f2da22ca), pvr.nextpvr (239dbef3), pvr.njoy (4785afd2), pvr.octonet (3494c4c4, +6), pvr.pctv (f61e2541), pvr.stalker (151e3d3f), pvr.vbox (df9efea4), pvr.vdr.vnsi (40dc17d0), pvr.vuplus (83a729ea), pvr.wmc (93cebfc7), vfs.rar (4ce78b0f)
- Include [env] compare: kodi18a1 latest updates
- Include [env] compare: linux: update to linux-4.11.2
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, other)
- Include [env] PR:713: linux: enable fq_codel for all projects
- Include [env] PR:1469: samba: update to samba-4.6.3
- Include [env] PR:1635: firmware: install wifi firmware from linux-firmware, cleanup wlan-firmware
- Include [pkg] PR:67: Revert "Revert "change smbd and nmbd location"" (service.libreelec.settings)
- Include [pkg] PR:12034: KODI: Update NEON support
- Include [pkg] PR:12110: smbclient: cleanup smbclient configuration
Build Highlights:
- Fix for HEVC crash
Build Details:
- XBMC:
- [windows][x64] add libbluray (PR:12150, 1 commit, 1 file changed)
- [depends] Bump samba-gplv3 to version 4.1.23 (PR:12147, 1 commit, 6 files changed)
- pvr.octonet:
- Update on kodi to addon interface (3494c4c4)
- newclock5:
- New commits in this build:
- fixup! MMALFFmpeg: Add Sand/YUVUV128 support (3d4cfcfc)
- ffmpeg: hevc: fixup pi1 (df6281d6)
- kernel 4.11.y:
- clk: bcm2835: Limit PCM clock to OSC and PLLD_PER (4222b8d5)
- clk: bcm2835: Minimise clock jitter for PCM clock (ab2c8a14)
- Added: [env] compare: kodi18a1 latest updates
I've uploaded new versions of screensaver.shadertoy, visualization.spectrum and visualization.waveform.
(2017-05-23, 20:34)popcornmix Wrote: [ -> ] (2017-05-23, 11:07)bleep42 Wrote: [ -> ] (2017-05-23, 06:06)smp1 Wrote: [ -> ]HEVC playback is broken in #0522. Kodi crash when trying to play any HEVC file. #0521 and earlier work ok.
Thanks Popcornmix,
Working great again on h265, thanks.
Kevin.
