(2017-09-02, 17:47)bmonster Wrote: [ -> ]Hi,
Not sure if this is a kodi or estuary issue, when watching a pvr recording and you press i for the osd, the programme name is missing from the top left corner just above the channel name.
Regards
Bucky..
Confirming the issue. I will look into it and will come up with a fix. Thanks for reporting.
(2017-09-02, 14:37)Milhouse Wrote: [ -> ] (2017-09-02, 08:38)Aux_ Wrote: [ -> ]Someone else has problem with the new tvheadend #0901 ?
That's a very good question...
Installed #0902 this morning then installed corresponding milhouse build of tvheadend backend addon
(LibreELEC Tvh-addon v9.0.112-#0902-milhouse-v4.2.3-39-ge195d18)
Tvheadend did not appear to have any problems with a switch back from #0824-milhouse-v4.3-358-g99d191a to #0902-milhouse-v4.2.3-39-ge195d18
(working ok in my usage case, Live TV and web access to tvheadend server etc.)
After checking everything running ok for a few minutes I performed a full reboot of rpi2 and upon 1st "reboot" after installing #0902 and corresponding tvheadend backend; I had a kodi crash and restart (crash only occurred once before kodi re-started ok without any further crashes occurring during tvheadend backend/frontend synchronization? on rpi2)
kodi crashlog
Everything running normally after the single kodi crash.
(2017-09-02, 18:44)polo_joe Wrote: [ -> ]I'm experiencing high memory usage in latest builds. My GPU mem is set to 320, I have tvheadend running on same machine. After some hours watching livetv I have memory usage of more than 40%.
Linux will use free memory for the file cache so it's quite normal for free memory to reduce over time (cached memory will be freed up when it is actually needed).
Unless you are saying the memory usage gets to 100% and then crashes I don't think there is an issue here.
Also if you believe this is an issue in "latest builds" then identifying the first build with the issue would be useful as we can closely look at the changes in that build.
(2017-09-03, 12:39)Aux_ Wrote: [ -> ]@MikeKL,
If you had not read yet, I could already solve the issue -->> https://forum.kodi.tv/showthread.php?tid...pid2641321
Aux_ Yes did read your post, before posting mine with understanding issue was more probably related to your usage/environment case.
Just thought still useful to continually update to latest builds (with recent step back from 4.3 to 4.2) and provide feedback.
(As I continue to utilize Tvheadend frontend/backend at latest Leia related build standard on same rpi2 device)
New LibreELEC.tv Leia build #0903:
RPi /
RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.12.10 #1 Sun Sep 3 21:04:51 BST 2017 armv6l GNU/Linux
# vcgencmd version
Aug 22 2017 14:20:40
Copyright (c) 2012 Broadcom
version eb51b8b84ec11d98562dfbb7be53cdd216c0ea4c (clean) (release)
# lsb_release
LibreELEC (Milhouse): devel-20170903210335-#0903-g7b1be4a [Build #0903]
# Kodi version
(18.0-ALPHA1 Git:7161dc0). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (7b1be4a,
changelog) and tip of
XBMC master (7161dc0,
- Includes newclock5 patches
- Excludes the LibreELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.12.y
- Includes latest bcm2835-driver master (625e768, ahead +1)
- Includes latest kodi-platform master (36fb493)
- Includes latest libcec master (8adc786, ahead +26)
- Includes latest libnfs master (df94ae9, ahead +56)
- Includes latest p8-platform master (a822e19)
- Includes latest addons: inputstream.adaptive (cb3c12b, +68), inputstream.rtmp (e094fa3, +1), peripheral.joystick (cc14287, +3), pvr.argustv (23cc0e8, +1), pvr.demo (122dedd, +3), pvr.dvblink (816f90c, +6), pvr.dvbviewer (8741c8b, +10), pvr.filmon (34dca04, +1), pvr.hdhomerun (ace19fa, +17), pvr.hts (53118d8, +3), pvr.iptvsimple (ac4f4bd, +7), pvr.mediaportal.tvserver (c86ab35, +17), pvr.mythtv (b46e5be, +2), pvr.nextpvr (a855663, +1), pvr.njoy (99874de, +1), pvr.octonet (a77cf11), pvr.pctv (549f690, +1), pvr.stalker (e15edca, +2), pvr.vbox (b5da811, +1), pvr.vdr.vnsi (7e6e385, +2), pvr.vuplus (9bfd868, +7), pvr.wmc (d820bf8, +1)
- Include [env] compare: kodi: updates for September
- Include [env] compare: linux: update to linux-4.12.10
- Include [env] patch: libcec: don't link non-existant libtinfo
- Include [env] patch: rev hack for kodi
- Include [env] patch: inputstream.adaptive: don't build it twice...
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, other)
- Include [env] patch: pvr addons: disable broken addons
- Include [env] PR:1773: init: make break after behaviour really break after
- Include [env] PR:1776: Don't cause system to hang on halt/reboot when net-booting
- Include [env] PR:1791: nss/nspr: include in main image [rfc]
- Include [env] PR:1835: add support for optional kernel modules in image and from addons
- Include [env] PR:1917: linux: enable ftrace
- Include [env] PR:1919: samba: don't restart smbd in samba-autoshare
- Include [env] PR:1923: mesa: update to 17.2.0-rc6
- Include [env] PR:1940: RTL8812AU: update to RTL8812AU-8e7ccba
- Include [env] PR:1943: samba: ensure new properties are populated on upgrade
- Include [pkg] patch: skin.estuary: reduce system info font size (kodi)
- Include [pkg] PR:12311: FIX: ensure real filename from videodb in playlists
- Include [pkg] PR:12708: Add contextmenu option to remove resume points
- Include [pkg] PR:12766: [PVR] Fix title missing in recordings OSD.
Build Highlights:
- [PVR] Fix title missing in recordings OSD.
- Add contextmenu option to remove resume points
Build Details:
- XBMC:
- VideoPlayer: vdpau - fix black screen after reset (PR:12756, 1 commit, 5 files changed)
- [addons] change binary callbacks (PR:12596, 2 commits, 4 files changed)
- Added: [env] PR:1943: samba: ensure new properties are populated on upgrade
- Added: [pkg] PR:12708: Add contextmenu option to remove resume points
- Added: [pkg] PR:12766: [PVR] Fix title missing in recordings OSD.
(2017-08-13, 12:42)Aux_ Wrote: [ -> ] (2017-08-13, 10:15)Cosmicbase Wrote: [ -> ] (2017-08-12, 01:44)rudrood Wrote: [ -> ]Reported earlier (link), buffering is indeed anoying when zapping through the channels.
Recording still works when you start it via contextmenu.
Yes, I know this has been repeatedly reported. Only since 20 days or since the # 0722 nothing has been changed.
I can not see so sensible TV, this is the problem.
Is this a problem for you to return to the last working build?
You cann update wen the issue has been eliminated
@ksoo Can you look over the issue. Would be great if this would run again without the buffering.
(2017-09-04, 00:28)Cosmicbase Wrote: [ -> ] (2017-08-13, 12:42)Aux_ Wrote: [ -> ] (2017-08-13, 10:15)Cosmicbase Wrote: [ -> ]Yes, I know this has been repeatedly reported. Only since 20 days or since the # 0722 nothing has been changed.
Firstly, my nickname is ksooo, secondly, without a "please" in a sentence wanting me to do something I will do nothing and thirdly, not my playground. ;-)
(2017-09-03, 11:03)ksooo Wrote: [ -> ] (2017-09-02, 17:47)bmonster Wrote: [ -> ]Hi,
Regards
Bucky..
Should be fixed in latest build.
(2017-09-04, 07:46)ksooo Wrote: [ -> ] (2017-09-04, 00:28)Cosmicbase Wrote: [ -> ] (2017-08-13, 12:42)Aux_ Wrote: [ -> ]Is this a problem for you to return to the last working build?
ksooo, I am very sorry.
Can someone look at the log or who is responsible here?
For me, my Xbox Remote isn´t working since a while. (Updating regularly every week or so). With the clean LibreElec 8.0.2 image altough, everything with the remote works just fine. Connected via GPIO IR-Receiver.
I can´t figure out whats the problem here but I think something is broken in the last builds. I tried almost everything i could find about getting Lirc back to work. Anyone who has the same issue?
Which xbox remote are you using? Xbox one and Xbox 360 remotes should work out of the box. WIth these new builds make sure you are using dtoverlay=gpio-ir (NOT lirc-rpi) and have Lirc DISABLED in LibreELEC settings.
so long,
Hias
Xbox one remote. Will try dtoverlay=gpio-ir soon. Thx in advance. I think this should solve it.
Greetings from the north of Salzburg,
maskedrider
HiassofT
Thats it, worked for me, thanks! I had to enable lirc in the LE settings, disabled didn´t work at all. Don´t know why exactly if it should run out of the box, but as long as it works fine, who cares..
