(2018-06-09, 06:14)3DBuff Wrote: [ -> ]Correct. I was really puzzled when it pupped up in build prior to #0601 and then it bacame permanent. The movies that don't scan get locked up even with roll back to prior builds that worked before. It's like the title is blacklisted but it works from other Kodi installs PC and Android box.
Can you go back to a build from a month or two ago, say #0401, delete (or rename) the MyVideos109.db, and then scan your library again - it would be interesting to see how "24 Hours to Live" is handled. If it's the same, as #0531, ie. it fails to retrieve any details, then chances are this is a website API/addon/scraper issue rather than anything to do with Kodi core.
OK, I'll try to do it today. The scan or don't scan is unpredictable in my case. Large multi-source scan seem to lock up the same titles every time with recent builds.
I had fresh #0606 with missing titles. Reversed back to #0531 and it created brand new database with all movies OK. I made a fresh chip with #0531 and it didn't scan all (the last case). I can't find a pattern to it.
My projector setup had #0407. I updated the movie database first, all OK. Updated to #0604 I think it was and it all looked OK at the beginning. The movies in the database were scanned with previous version of Kodi but any change to existing movie like a letter at the end of filename would remove it out database and lock it up for any future scans. Reversing the filename change would call up old database reference and movie would show up again.
I'ts definitely not the issue with #0602 database update.
Maybe it is a website API/addon/scraper issue but why just me?
As requested I renamed MyVideos109.db to MyVideos109#0531.db, disabled any Settings media customization like "Extract video information from files", "Show movie sets" etc. Reversed update to #0501 and let it scan. Renaming database file removed source content to "none". This had to be manually put back to movies and others.
Scan completed, movies are missing
Of course "24 Hours to Live" is one of the missing titles.
Next step. I will repeat this with #0401.
If it is scraper or TMDB than why nobody else is complaining? I don't see any threads at Metadata Scrapers complaining about missing titles from the scan.
Movie Database - missing titles out of the scan.
After hours and hours and more hours I got to the bottom of the issue. It was me
Renaming database file and deleting it all the way to official Kodi 17 8.2.5 was not helping. Certain movies would not scan.
Wiped SD and fresh Kodi 17, didn't adjust anything and added one source. All OK.
Updated to latest #0608 and tested by renaming one of the file. All good.
Went ahead and made some customization, time zone, couple of plugins and adjusted media settings.
Back to source and changed filename. No scan! Reversed steps few at the time and bingo.
Settings > Media > Videos > Use video tags
That's the one. Don't use video tags
That's why it was asking TMDB for the wrong thing. Well, I had nothing else to do today anyway
@Milhouse: Was it possible for you to reproduce my issues? Is there anything I can do fixing it?
(2018-06-10, 01:05)Germeleon Wrote: [ -> ]@Milhouse: Was it possible for you to reproduce my issues? Is there anything I can do fixing it?
Which issue(s) are still an issue?
1) The keyboard layout? Question: What keyboard layout are you configuring?
2) Zattoo - sorry can't help, contact the addon maintainer via github
3) Amazon - is this still an issue? Working fine for me but I use
plugin.video.prime_instant. Probably best to contact your Amazon addon maintainer if it's not working.
New LibreELEC.tv Leia build #0609:
RPi /
RPi2
(Supercedes previous build)
SHA256 Checksum:
60d143e3b6ccb49b68e5a884a9f123ce812fb47393cc9d2ec8c3cdbe81c6db34
(RPi)
SHA256 Checksum:
dc4e34a815af2a48f5d74d333cc75facf4358e290cf78e1fa8075f5fe1fd39e5
(RPi2)
text:
# uname -a
Linux rpi512 4.14.48 #1 Sun Jun 10 00:07:08 BST 2018 armv6l GNU/Linux
# vcgencmd version
Jun 7 2018 15:37:30
Copyright © 2012 Broadcom
version 4800f08a139d6ca1c5ecbee345ea6682e2160881 (clean) (release)
# lsb_release
LibreELEC (Milhouse): devel-20180609234309-#0609-gdf52423 [Build #0609]
# Kodi version
(18.0-ALPHA2 Git:593949a). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (df52423,
changelog) and tip of
XBMC master (5da94d1,
- Includes newclock5 patches
- Includes latest commits from kernel branch rpi-4.14.y
- Includes latest bcm2835-driver master (7884178)
- Includes latest kodi-platform master (e8574b8)
- Includes latest libcec master (8adc786, ahead +26)
- Includes latest libnfs master (6a33413, ahead +132)
- Includes latest p8-platform master (a822e19)
- Includes latest addons: inputstream.adaptive (a401504, +5), inputstream.rtmp (b8e3f39), peripheral.joystick (6312745, +1), pvr.argustv (37a3a76, +1), pvr.demo (bcd8289, +1), pvr.dvblink (1732e4b, +1), pvr.dvbviewer (986b1ba, +1), pvr.filmon (ba261c9, +1), pvr.hdhomerun (379c62c, +1), pvr.hts (f569808, +1), pvr.iptvsimple (663040c, +1), pvr.mediaportal.tvserver (01af5a0, +1), pvr.mythtv (c18ca9e, +1), pvr.nextpvr (fad3ca9, +1), pvr.njoy (30743c6, +1), pvr.octonet (1e44819, +1), pvr.pctv (d0c7241, +1), pvr.stalker (00f3fc4, +1), pvr.teleboy (dfa68b0, +1), pvr.vbox (d2e61a9, +1), pvr.vdr.vnsi (18c7474, +3), pvr.vuplus (bcfd34d, +1), pvr.wmc (ce4b47a, +1), pvr.zattoo (4fa0f72, +6), vfs.libarchive (84a4876)
- Exclude [env] kodi-0100-temp-add-pr13594.patch: merged upstream
- Include [env] compare (perma): init: strip leading / from BOOT_IMAGE & DISK_IMAGE, normalising for all projects
- Include [env] compare (perma): dmidecode: initial package
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: libcec: fix PR390
- Include [env] patch: libcec: don't link non-existant libtinfo
- Include [env] patch: mesa 18.1.1/xorg 1.20
- Include [env] patch: kodi: remove annoying, excessively repetitive addon logging
- Include [env] patch: rev hack for kodi
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, other)
- Include [env] PR:2449 (perma): Adding support for AMD GPUs
- Include [env] PR:2696 (perma): linux: update ouya patch
- Include [env] PR:2725 (perma): Python2: update to Python2-2.7.15, bump Python-related packages
- Include [env] PR:2742 (perma): scripts/image: add BUILDER_NAME, BUILDER_VERSION support
- Include [env] PR:2760 (perma): sqlite build shared
- Include [pkg] patch: skin.estuary: reduce system info font size (kodi)
- Include [pkg] PR:100 (perma): stats: Replace CPU 32/64 bit flag with GPU enumeration (service.libreelec.settings)
Build Highlights:
- sqlite: update to sqlite-autoconf-3240000 (plus fix)
- [PVR] Addon API 5.10.0: New API function GetStreamReadChunkSize (and associated PVR addon updates)
Build Details:
- LibreELEC.tv:
- device-tree-amlogic: add LePotato dts files to EXTRA_TREE (PR:2745, 1 commit, 1 file changed)
- kmscube: add package (PR:2727, 1 commit, 1 file changed)
- sqlite: update to sqlite-autoconf-3240000 (PR:2759, 1 commit, 1 file changed)
- XBMC:
- Games window: Fix error playing standalone cores (PR:13989, 1 commit, 1 file changed)
- Games: Fix standalone games creating savestate files in app dir (PR:13990, 1 commit, 2 files changed)
- Various copy operator optimizations (and several small cleanups) (PR:14005, 8 commits, 7 files changed)
- [PVR] Addon API 5.10.0: New API function GetStreamReadChunkSize. (PR:14002, 1 commit, 9 files changed)
- Do not use CURL::proxy for localhost (PR:13995, 1 commit, 1 file changed)
- peripheral.joystick:
- Add NDO SW Pro Controller and 8bitdo NES30 Arcade (PR:145, 1 commit, 2 files changed)
- pvr.argustv:
- PVR API 5.10.0 (PR:80, 1 commit, 3 files changed)
- pvr.demo:
- PVR API 5.10.0 (PR:62, 1 commit, 2 files changed)
- pvr.dvblink:
- PVR API 5.10.0 (PR:103, 1 commit, 3 files changed)
- pvr.dvbviewer:
- PVR API 5.10.0 (PR:73, 1 commit, 3 files changed)
- pvr.filmon:
- PVR API 5.10.0 (PR:83, 1 commit, 3 files changed)
- pvr.hdhomerun:
- PVR API 5.10.0 (PR:78, 1 commit, 3 files changed)
- pvr.hts:
- PVR Addon API 5.10.0: Implement stream read chunk size as addon setting. (PR:366, 1 commit, 7 files changed)
- pvr.iptvsimple:
- PVR API 5.10.0 (PR:186, 1 commit, 3 files changed)
- pvr.mediaportal.tvserver:
- PVR API 5.10.0 (PR:87, 1 commit, 3 files changed)
- pvr.mythtv:
- PVR API 5.10.0 (PR:100, 1 commit, 3 files changed)
- pvr.nextpvr:
- PVR API 5.10.0 (PR:74, 1 commit, 3 files changed)
- pvr.njoy:
- PVR API 5.10.0 (PR:47, 1 commit, 3 files changed)
- pvr.octonet:
- pvr.pctv:
- PVR API 5.10.0 (PR:59, 1 commit, 3 files changed)
- pvr.stalker:
- PVR API 5.10.0 (PR:113, 1 commit, 3 files changed)
- pvr.teleboy:
- PVR API 5.10.0 (PR:10, 1 commit, 3 files changed)
- pvr.vbox:
- PVR API 5.10.0 (PR:209, 1 commit, 3 files changed)
- pvr.vdr.vnsi:
- add chunk size for recordings (PR:16, 3 commits, 6 files changed)
- pvr.vuplus:
- pvr.wmc:
- PVR API 5.10.0 (PR:62, 1 commit, 4 files changed)
- pvr.zattoo:
- PVR API 5.10.0 (PR:19, 1 commit, 3 files changed)
- Login v2 (PR:20, 4 commits, 4 files changed)
- Added: [env] patch: mesa 18.1.1/xorg 1.20
- Added: [env] PR:2760 (perma): sqlite build shared
Is there still problems with search function or is it fixed? Does LE freeze/crash if use search?
(2018-06-10, 12:34)Jezze Wrote: [ -> ]Is there still problems with search function or is it fixed? Does LE freeze/crash if use search?
Search local library
Search add-ons
Both working for me. No freeze, no crash.
New LibreELEC.tv Leia build #0610:
RPi /
RPi2
SHA256 Checksum:
eddf5f00beffd0f1456407f2edefd0bd71f89daaa999061d85cb5697810ac348
(RPi)
SHA256 Checksum:
fa4884ad665769be5c7c35f23db844e0a9cb62924c4e7c2ab4aa27f2e66a9f79
(RPi2)
text:
# uname -a
Linux rpi512 4.14.48 #1 Sun Jun 10 21:08:40 BST 2018 armv6l GNU/Linux
# vcgencmd version
Jun 7 2018 15:37:30
# lsb_release
LibreELEC (Milhouse): devel-20180610210406-#0610-g783ddf0 [Build #0610]
# Kodi version
(18.0-ALPHA2 Git:e6f78cb). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (783ddf0,
XBMC master (abbd062,
- Include [env] PR:2764 (perma): kodi: June 2018
Build Highlights:
- Minors
Build Details:
- LibreELEC.tv:
- kmscube: cleanup (PR:2762, 1 commit, 1 file changed)
- XBMC:
- RetroPlayer: Fix memory leak on Windows (PR:13999, 1 commit, 1 file changed)
- Rename GL_INTERFACE to KODIGL_INTERFACE (PR:13700, 3 commits, 8 files changed)
- [addons] implement path attribute (PR:13991, 1 commit, 2 files changed)
- Refine Video::Autoplay options (PR:13992, 1 commit, 12 files changed)
- GUIDialogSubtitles: close SUBTITLE_OSD_SETTINGS after a subtitle download (PR:13975, 1 commit, 4 files changed)
- Clear EDL when opening a new FileItem (PR:13996, 1 commit, 1 file changed)
Hi.
From build #0404, my TV is no more switching, to the movie souce framerate.
Ex. if I playback a BR iso in 24fps, the TV is in 60Hz ?
The build #0403 is working fine.
RPi3 using OMXplayback only and "Adjust display refresh rate = Always"
Best regards
(2018-06-11, 08:50)delinend Wrote: [ -> ]From build #0404, my TV is no more switching, to the movie souce framerate.
Have you got the frame rate whitelist set up correctly?
There is a new setting now that let's you specify for which refresh rates you would like the switches to happen. Like when your UI is running at 60Hz and you are playing a 30fps video, you might not necessarily want to do a switch etc. You can find this setting in Settings -> System - > Display -> "Whitelist"
(2018-06-11, 08:58)da-anda Wrote: [ -> ] (2018-06-11, 08:50)delinend Wrote: [ -> ]From build #0404, my TV is no more switching, to the movie souce framerate.
wow.. Thanks. That works now, with the Whitelist settings :-)
