(2019-03-01, 13:09)Aux_ Wrote: [ -> ]When trying to update kodi hangs or crashes.
75 updates? Can you provide a screenshot, are you using the Milhouse-9.1 channel as there are only 19 versions available of 9.1 (at the time of writing, latest is #0228, oldest is #0210).
Can you post a crash log?
There's a crash bug introduced in #0228 by pvr.vuplus,
the fix will be in the next build.
(2019-03-01, 13:31)bmonster Wrote: [ -> ]Same here, its trying to install all sorts of addons, simpsons world, extras, and loads of repos ive never heard of.
Trying to uninstall anything just crashes kodi, cant get any logs im afraid.
Regards Bucky
(2019-03-01, 17:13)charlieroot Wrote: [ -> ]Same here, all sorts of addons I've never installed. Going back to #0227.
Regs,
Can either of you (or anyone else) provide a log of these rogue addon installations? Logs should be available from ssh...
Greetings,
I started with a "clean" version of #0227 then updated to #0228 and this is what the updates looks like (no additional repositories or add-ons installed)...
kodi.log is here...
https://paste.kodi.tv/damoxiziji.kodi
(2019-03-01, 23:19)MikeKL Wrote: [ -> ]#0228, I am currently ignoring addons requesting an update, following is what I see in my list requesting an update.
I'm getting the same as this, but with a few extras, like simpsons world, and a context addon called extras..
No problem with the windows build, only libreelec..
Regards Bucky
New LibreELEC.tv Leia build #0301:
RPi /
RPi2
(Supercedes previous build)
SHA256 Checksum:
84fd5b0393a0b9de2362bf5d65c40f2a95e5bf52e7ff967df467dcd705c7ff1e
(RPi)
SHA256 Checksum:
e6e6a2b2f61bcadd2457a3862cd5fe67e0748ee1172a446ced58043a1e50583b
(RPi2)
text:
# uname -a
Linux rpi512 4.19.25 #1 Fri Mar 1 21:51:46 GMT 2019 armv6l GNU/Linux
# vcgencmd version
Feb 22 2019 18:10:04
Copyright © 2012 Broadcom
version c32b049542c0da4e13087d1043bbfa6c50b242f3 (clean) (release) (start_x)
# lsb_release
LibreELEC (Milhouse): devel-20190301214927-#0301-g0111c1d [Build #0301]
# Kodi version
Kodi (18.2-RC1 Git:36fa50e). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (0111c1d,
changelog) and tip of
XBMC master (36fa50e,
- Includes newclock5 patches
- Includes latest commits from kernel branch rpi-4.19.y
- Includes latest bcm2835-driver master (f84820e, ahead +1)
- Includes latest kodi-platform master (e8574b8)
- Includes latest libcec master (3bbd432)
- Includes latest libnfs master (0308145)
- Includes latest p8-platform master (1eb12b1)
- Includes latest addons: inputstream.adaptive (b76c81f), inputstream.rtmp (ce68b77, +1), peripheral.joystick (6b2a4dd, +5), peripheral.xarcade (af048f5, +1), pvr.argustv (83aa1e9), pvr.demo (964686d), pvr.dvblink (b636726, +2), pvr.dvbviewer (c2c1beb, +2), pvr.filmon (e850633), pvr.hdhomerun (a9d7309), pvr.hts (8dcd62d, +3), pvr.iptvsimple (73feb2f), pvr.mediaportal.tvserver (931afab), pvr.mythtv (c954c7e), pvr.nextpvr (78c6633), pvr.njoy (4467cac), pvr.octonet (203f800), pvr.pctv (b60b971), pvr.stalker (d0170c5), pvr.teleboy (1956113), pvr.vbox (ea20464), pvr.vdr.vnsi (cbb75ab), pvr.vuplus (045d3a4, +14), pvr.wmc (7b28be3), pvr.zattoo (30868ce), vfs.libarchive (2ba1102), vfs.rar (b66c6df, +1), vfs.sftp (ab0dc82, +1)
- Include [env] compare (perma): TESTING: increase timeout to ensure OS is able to create core dump/crash log
- Include [env] patch: Add http2 support for curl
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: kodi: use upstream repo for Milhouse RPi builds
- Include [env] patch: kodi: remove annoying, excessively repetitive addon logging
- Include [env] patch: rev hack for kodi
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, peripheral.joystick/xarcade, other)
- Include [env] PR:3238 (perma): kodi/openssl: fix crash using vfs.sftp
- Include [env] PR:3316 (perma): openssh: drop support for ssh-dss keys
- Include [env] PR:3324 (perma): linux (RPi/Generic): update to linux-4.19.25/26
- Include [env] PR:3329 (perma): [RFC] add safe_remove to notify if a file doesn't exist
- Include [env] PR:3334 (perma): xf86-video-nvidia: update to xf86-video-nvidia-410.104
- Include [env] PR:3336 (perma): gcc: update to gcc-8.3.0
- Include [env] PR:3342 (perma): scripts/build: fix broken sym link after #3328
- Include [env] PR:3348 (perma): packages/{x11,print,devel}: bump packages
- Include [env] PR:3349 (perma): Packages: Miscellaneous package bumps to new minor versions
- Include [pkg] 983cf7a2: Sets the BCDC priority to constant 0 (linux)
- Include [pkg] patch: kodi: fix addon platform_tag (kodi)
- Include [pkg] PR:14571 (perma): Remove ARB postfix from GL functions
- Include [pkg] PR:15164 (perma): TexturePacker: Fix memory / resource leak the ugly way
- Include [pkg] PR:15356 (perma): Optimize locking in ApplicationMessenger
- Include [pkg] PR:15591 (perma): Fix TCP buffer parsing to find JSON statements to correctly
- Include [pkg] PR:15621 (perma): [cmake] microhttpd: only link with libraries
Build Highlights:
- Drop arm-mem NEON optimisation - add-on update chaos
- Packages: Miscellaneous package bumps to new minor versions
- Crash on addon start, fixes #191
Build Details:
- XBMC:
- [PVR] - Recording edit context menu visible when not supported (PR:15634, 1 commit, 5 files changed)
- Various fixes (PR:15633, 3 commits, 7 files changed)
- [Music]Fix collaboration album tag processing MBID matching (PR:15635, 1 commit, 1 file changed)
- [database] Verify date parsing when querying videos by year (PR:15615, 1 commit, 1 file changed)
- [videodb]fix: Return empty InfoTag when looking up non-existent music video (PR:15614, 1 commit, 1 file changed)
- Fixes a crash when a file's embedded art is invalid (PR:15605, 1 commit, 1 file changed)
- [skins] improvement & cosmetics (PR:15537, 1 commit, 12 files changed)
- wake on access: fix crash on startup (PR:15491, 1 commit, 1 file changed)
- [docs/README.Fedora] fixes and updates (PR:15510, 1 commit, 1 file changed)
- [Android] Don't flip GLES if window was destroyed (PR:15641, 1 commit, 2 files changed)
- [GraphicsContext] - add setting for only adjusting refresh rate on start (PR:15506, 1 commit, 4 files changed)
- [PVR] Fix crash on channel switch when no pvr client is enabled. (PR:15640, 1 commit, 1 file changed)
- peripheral.xarcade:
- [cleanup] remove kodiplatform dependency (af048f5)
- pvr.hts:
- 4.4.16: Fix auto close of timeshifted subscriptions if predictive tuning is activated. (PR:408, 2 commits, 6 files changed)
- pvr.vuplus:
- Crash on addon start, fixes #191 (PR:192, 1 commit, 3 files changed)
- kernel 4.19.y:
- New commits in this build:
- Updated: [env] patch: Add http2 support for curl
- Updated: [env] PR:3342 (perma): scripts/build: fix broken sym link after #3328
- Updated: [env] PR:3348 (perma): packages/{x11,print,devel}: bump packages
- Added: [env] PR:3349 (perma): Packages: Miscellaneous package bumps to new minor versions
- Updated: [pkg] PR:15621 (perma): [cmake] microhttpd: only link with libraries
I confirm that with new LibreELEC.tv Leia build #0301: RPi / RPi2 update works all werry well,
no more lots of addon updates now.
Can anyone confirm if video stuttering is fix in latest update.
(2019-03-02, 15:58)zeroq Wrote: [ -> ]Can anyone confirm if video stuttering is fix in latest update.
Note: Thread is for nightly builds of LibreELEC on a RaspberryPi and discussion of issues found by user community when using nightly builds. Can you confirm your are using a RaspberryPi, build currently installed on it and type of video (local, network, streamed etc) where stuttering occurs.
Don't forget to provide a LibreELEC
kodi log file (how-to)
(2019-03-01, 19:48)Milhouse Wrote: [ -> ] (2019-03-01, 13:09)Aux_ Wrote: [ -> ]When trying to update kodi hangs or crashes.
There's a crash bug introduced in #0228 by pvr.vuplus, the fix will be in the next build.
Milhouse What is the custom url for the Milhouse-9.1 channel? I'm still on 9.0, updating nightly builds manually via this thread.
Correction, I have no custom channel in LE settings, it was presumably removed - I don't remember doing it...
(2019-03-02, 18:14)agb2 Wrote: [ -> ] (2019-03-01, 19:48)Milhouse Wrote: [ -> ] (2019-03-01, 13:09)Aux_ Wrote: [ -> ]When trying to update kodi hangs or crashes.
@Milhouse What is the custom url for the Milhouse-9.1 channel? I'm still on 9.0, updating nightly builds manually via this thread.
See first post, note #7 for url.
Custom channel settings were not migrated during recent changes to the Update menu (I think I mentioned this in the relevant release note).
For LibreELEC 9.1 go into updates option of LibreELEC settings, toggle the "Show Custom Channels" off/on: then you should be able to select "Milhouse-9.1" as your new update channel
(2019-03-02, 18:21)Milhouse Wrote: [ -> ] (2019-03-02, 18:14)agb2 Wrote: [ -> ] (2019-03-01, 19:48)Milhouse Wrote: [ -> ]75 updates? Can you provide a screenshot, are you using the Milhouse-9.1 channel as there are only 19 versions available of 9.1 (at the time of writing, latest is #0228, oldest is #0210).
Got it, thanks! <Slaps wrist>, I guess I didn't read the release note :-}
