(2017-08-15, 20:12)Pienoet Wrote: [ -> ]Maybe you can post your standard config.txt setting?
Mine rpi3 is also overclocked.
Yesterday i watched a 1080p hevc 8 bit and it reached 72°C and it wasn't get any higher.
Using the FLIRC aluminium kodi case.
I wonder what temperature it will reach with standard overclock settings...
I had now testet hevc1080p 8bit and had temperature not over 77°C
Here config.txt
gpu_mem=320
gpu_mem_256=112
gpu_mem_512=160
gpu_mem_1024=320
hdmi_force_hotplug=1
hdmi_ignore_cec_init=1
max_usb_current=1
boot_delay=10
That's all...
(2017-08-15, 21:12)Milhouse Wrote: [ -> ]If you want 1080p Netflix without spending a lot then a cheap Android box might be your best bet.
This will be the cheapest Dual Boot unofficial Android TV 1080p Netflix / LibreELEC device you will be able to find anywhere. Absolute bargain !
All for USD$40
http://whrl.pl/ReX678
(2017-08-14, 19:16)techie67 Wrote: [ -> ]Hi, with 813 Amazon vod on my Pi3 flickers when watching a film e.g. The infiltrator.
It works fine with 810.
When i remember it correctly, 808 worked fine too and 809 had this flicker issue too.
Regards
Chris
This is confirmed (and somewhat understood), although it only seems to affect the Sandman Amazon addon. No fix yet, developers are cogitating.
New LibreELEC.tv Leia build #0815:
RPi /
RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.12.7 #1 Tue Aug 15 23:30:16 BST 2017 armv6l GNU/Linux
# vcgencmd version
Aug 8 2017 12:05:45
Copyright (c) 2012 Broadcom
version 196063438d7bb0769861c86f948ae653727adb7e (clean) (release)
# lsb_release
LibreELEC (Milhouse): devel-20170815232906-#0815-ge67a1c9 [Build #0815]
# Kodi version
(18.0-ALPHA1 Git:50b29a1). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (e67a1c9a,
changelog) and tip of
XBMC master (50b29a1a,
- Includes newclock5 patches
- Excludes the LibreELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.12.y
- Includes latest bcm2835-driver master (e7ba7ab1, ahead +3)
- Includes latest kodi-platform master (36fb4937)
- Includes latest libcec master (8adc786b, ahead +26)
- Includes latest libnfs master (df94ae93, ahead +56)
- Includes latest p8-platform master (a822e196)
- Includes latest addons: inputstream.adaptive (54a90a49, +33), inputstream.rtmp (476bde07), peripheral.joystick (1815c0fb), pvr.argustv (310737e2), pvr.demo (f07d898c, +1), pvr.dvblink (0b66c640, +4), pvr.dvbviewer (eba6d0e9, +4), pvr.filmon (1c9d2ebe), pvr.hdhomerun (b89c2be4, +9), pvr.hts (a1de6329, +1), pvr.iptvsimple (260434e4, +5), pvr.mediaportal.tvserver (d7a9acdb), pvr.mythtv (a17a3a4f, +1), pvr.nextpvr (03a3b714), pvr.njoy (79e8e653), pvr.octonet (a77cf111), pvr.pctv (00b76689), pvr.stalker (9e28f125), pvr.vbox (44f3d04e), pvr.vdr.vnsi (07172ed0, +1), pvr.vuplus (921b14f6, +5), pvr.wmc (1d655540)
- Include [env] compare: linux: update to linux-4.12.7
- Include [env] patch: nss/nspr: include in main image [rfc][gcc7]
- Include [env] patch: rev hack for kodi
- Include [env] patch: tvheadend42: fixup ffmpeg patch
- Include [env] patch: buildsystem: update to gcc (to 7.2), glibc and binutils
- Include [env] patch: pvr addons: disable broken addons
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, other)
- Include [env] PR:1726: [WIP] lirc: update to 0.10.0
- Include [env] PR:1773: init: make break after behaviour really break after
- Include [env] PR:1776: Don't cause system to hang on halt/reboot when net-booting
- Include [env] PR:1835: add support for optional kernel modules in image and from addons
- Include [env] PR:1862: busybox: revert dd fsync change which makes no sense
- Include [env] PR:1896: config/functions: fix bash-4.4 issue, and empty 2nd param behaviour
- Include [pkg] patch: Pre-release RPi0W/RPi3 Bluetooth firmware (details) (brcmfmac_sdio-firmware-rpi)
- Include [pkg] patch: Pre-release RPi0W/RPi3 WiFi firmware (details) (kernel-firmware)
- Include [pkg] patch: Pre-release RPi0W/RPi3 WiFi firmware (details) (wlan-firmware)
- Include [pkg] patch: skin.estuary: reduce system info font size (kodi)
- Include [pkg] PR:12311: FIX: ensure real filename from videodb in playlists
Build Highlights:
- Update to gcc-7.2.0 (final) and glib-2.53.5
- More PVR cleanup and updates
- More inputstream.adaptive updates
- MMALRender: Improve quality of 10->8 bit conversion
Build Details:
- LibreELEC.tv:
- build system: use DISK_SIZE in bytes for ovf template (PR:1878, 1 commit, 2 files changed)
- XBMC:
- [addons] save skin settings after they get changed (PR:12648, 1 commit, 2 files changed)
- [PVR] Another round of code cleanup (PR:12677, 5 commits, 81 files changed)
- inputstream.adaptive:
- [HLS]default unknown media files to .ts (03cfd0bd)
- [HLS Live] wait for new segments (ec7154b5)
- Use IPosTime instead DemuxSeekTime / [HLS] interrupt fragmend polling on stopp (54a90a49)
- pvr.dvblink:
- Fixed #94: Missing compatibility with API 5.6.0 (PR:95, 3 commits, 4 files changed)
- pvr.dvbviewer:
- migrate add-on settings to settings library (68c9d42b)
- GetAddonCapabilities: add missing capabilities (44183287)
- PVR API 5.6.0 (1f318071)
- Bump version to 3.2.0 (eba6d0e9)
- pvr.vuplus:
- Fix channel playback after recent API changes. (PR:70, 1 commit, 6 files changed)
- newclock5:
- New commits in this build:
- MMALRender: Improve quality of 10->8 bit conversion (b7fb6b03)
- Updated: [env] patch: buildsystem: update to gcc (to 7.2), glibc and binutils
- Added: [env] PR:1896: config/functions: fix bash-4.4 issue, and empty 2nd param behaviour
Hi everybody
I need a little help here.
I just had a version of kodi working fine here (krypton 17.3) and I
just download this today version ( and others too ..11, 12th ).
In all, I lost access to my files in network trough samba.
The kodi did not see my shared files anymore.
Please, help me solve this
Ty
(2017-08-16, 02:26)mvlc Wrote: [ -> ]Hi everybody
Ty
If you mean you've lost access to files shared by the LibreELEC Samba server, then if you're using a custom Samba config you'll need to fix it:
https://forum.kodi.tv/showthread.php?tid...pid2599284
If your files are on a different Samba server try adjusting the Samba max protocol in System > Settings > Services > SMB Client > Maximum protocol version (needs Advanced/Expert level settings) as your server may be buggy and unable to support the latest protocols reliably.
Also be aware that anonymous access to Samba shares no longer works so use always use a username/password. Also, network browsing no longer works when SMB1 is disabled.
If none of the above helps you'll need to provide more details about your network in particular your Samba server (make, model, Samba version, what SMB protocols are enabled).
Thanks Milhouse,
now i'm able to make changes with WinSCP from my office...
Is there any chance to disable the audio description in the netflix addon?
After upgrade from #813 to #814 netflix is playing every stream with audio description very annoying.
I can't find any settings to turn that off.
If i play netflix fom my laptop i have not audio description.
Am i missing something?
EDIT:
It seems it has effect only the netflix originals streams.
If is select another audio stream while playing a stream netfllix hangs and eventually it plays the stream with selected audio but there is no audio only video.
(2017-08-15, 12:58)popcornmix Wrote: [ -> ] (2017-08-14, 21:20)Doktor-X Wrote: [ -> ]so latest build that is working for me is 504 after that all build basicly have same problem kodi and video playback frozes (with some builds after 1-2 min of playback and on some builds almost immediately after video start playing) dont ask me what that builds are i don't remember and i don't have them downloaded and i need to reboot pi to be able to revert back to previous state, im using nfs that is mounted localy on the pi itself
What happens if you disable omxplayer in video/acceleration settings?
its better (video is playing but it take long time to load it) and whole interface is slow and barely functional i think i have problem because my board is 256mb ram and this is too little for build after 504
(2017-08-16, 20:24)Pienoet Wrote: [ -> ]Is there any chance to disable the audio description in the netflix addon?
OK thanks, confirmed. Looking into it.
New LibreELEC.tv Leia build #0816:
RPi /
RPi2
# uname -a
Linux rpi512 4.12.7 #1 Thu Aug 17 00:43:29 BST 2017 armv6l GNU/Linux
# vcgencmd version
Aug 8 2017 12:05:45
# lsb_release
LibreELEC (Milhouse): devel-20170817004218-#0816-ge67a1c9 [Build #0816]
# Kodi version
(18.0-ALPHA1 Git:a90d8f9). Platform: Linux ARM 32-bit
Based on tip of
XBMC master (a90d8f98,
- Includes latest bcm2835-driver master (b9a8e6a5, ahead +4)
- Includes latest addons: inputstream.adaptive (2af963ba, +36), inputstream.rtmp (e094fa38, +1), peripheral.joystick (1815c0fb), pvr.argustv (310737e2), pvr.demo (f07d898c, +1), pvr.dvblink (0b66c640, +4), pvr.dvbviewer (a1e4bb0c, +5), pvr.filmon (1c9d2ebe), pvr.hdhomerun (b89c2be4, +9), pvr.hts (a1de6329, +1), pvr.iptvsimple (260434e4, +5), pvr.mediaportal.tvserver (d7a9acdb), pvr.mythtv (a17a3a4f, +1), pvr.nextpvr (03a3b714), pvr.njoy (79e8e653), pvr.octonet (a77cf111), pvr.pctv (00b76689), pvr.stalker (df492d27, +1), pvr.vbox (44f3d04e), pvr.vdr.vnsi (07172ed0, +1), pvr.vuplus (921b14f6, +5), pvr.wmc (1d655540)
- Include [pkg] PR:122: Fix compiler error (peripheral.joystick)
Build Highlights:
- Amazon flicker fix (PR12679)
Build Details:
- XBMC:
- [win32] Fix dxva renderer flickers at playback startup (PR:12678, 1 commit, 1 file changed)
- bool return value in Inputstream::OpenStream() to allow reset of demuxstreams (PR:12679, 1 commit, 3 files changed)
- mark constructors explicit (PR:12675, 1 commit, 217 files changed)
- [lang] remove language add-on migration code (PR:12658, 1 commit, 7 files changed)
- [utils] CLog: add Log and LogFunction function with additional component parameter (PR:12676, 4 commits, 32 files changed)
- Fix: check if we have to show simple menu only after we checked if we have a resume point (PR:12674, 1 commit, 2 files changed)
- Do not overwite codec_extra_data from manifest with maybe empty record from stream (838938dd)
- Adapt to inputstream API version 2.0.3 (36354fcb)
- [HLS] Handle initial sub playlists with end marker as VOD / seek fixes (tbc) (2af963ba)
- inputstream.rtmp:
- API change: OpenStream void -> bool (e094fa38)
- pvr.dvbviewer:
- remove legacy functions, bump to 3.2.1 (a1e4bb0c)
- pvr.stalker:
- simplify installation file (PR:85, 1 commit, 1 file changed)
- Updated: [env] patch: Bump included addon versions to prevent online updates
- Added: [pkg] PR:122: Fix compiler error (peripheral.joystick)
Didn't try Amazon Video in a long time. Glad it's working again!
But do i have to disable hardware accelleration if i want to watch Amazon Video?
I'm using hardware accelleration for BluRay images and for TV (DVB-S2 Streams) un my RasPi 3.
(2017-08-17, 12:21)start78 Wrote: [ -> ]But do i have to disable hardware accelleration if i want to watch Amazon Video?
The default (and recommended) settings of omxplayer disabled and mmal enabled should be fine.
(2017-08-16, 22:01)Doktor-X Wrote: [ -> ]its better (video is playing but it take long time to load it) and whole interface is slow and barely functional i think i have problem because my board is 256mb ram and this is too little for build after 504
A 256M Pi1 is really pushing it for running the latest version Kodi. It is just not enough memory.
Are you sure #504 is okay, and #505 is bad? There isn't anything obvious in the change list of that build that would increase memory usage significantly.
positive, all builds after 504 are problematic before build 505 i was using all nightly builds without problem and i was always up to date and now i guess it's time to upgrade hardware
