Sorry for being slightly OT, but I'm planning to upgrade my LibreELEC installation from a RPi 2 to a RPi 3. Can I just put the microSD card and USB Stick (I have /storage moved to USB) in the new Pi, or do I need to preare anything to make it work?
(2017-09-24, 13:59)dantist Wrote: [ -> ]Sorry for being slightly OT, but I'm planning to upgrade my LibreELEC installation from a RPi 2 to a RPi 3. Can I just put the microSD card and USB Stick (I have /storage moved to USB) in the new Pi, or do I need to preare anything to make it work?
Yes.
However two things to be aware of:
1) If you've been overclocking your RPi2 then your overclock will now apply to your RPi3 and may fail
2) Any codec licences won't work in the RPi3 - you'll need to purchase new licences.
You can create [pi2] and [pi3] sections in config.txt which allows you to use the same SD card to boot RPi2 and RPi3 safely, eg.
[pi2]
arm_freq=1000
gpu_freq=400
over_voltage=4
force_turbo=1
sdram_freq=600
over_voltage_sdram=5
sdram_schmoo=0x02000020
[pi3]
arm_freq=1300
gpu_freq=500
over_voltage=4
force_turbo=1
sdram_freq=580
Milhouse
Are the sections [pi2] and [pi3] automatically recognized by the boot?
(2017-09-24, 17:03)Aux_ Wrote: [ -> ]@Milhouse
They are recognised by the Pi firmware, in config.txt - they're a
conditional filter.
You can set an option so that it applies only to a certainly class of device (eg. [pi2]), or to a device with a specific serial number, or only when attached to a specific monitor (based on edid).
(2017-09-24, 17:17)Milhouse Wrote: [ -> ] (2017-09-24, 17:03)Aux_ Wrote: [ -> ]@Milhouse
They are recognised by the Pi firmware, in config.txt - they're a conditional filter.
Thank you for your answer @
Milhouse, this feature is really cool.
I did not know that until now
New LibreELEC.tv Leia build #0924:
RPi /
RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.13.3 #1 Mon Sep 25 01:03:42 BST 2017 armv6l GNU/Linux
# vcgencmd version
Sep 22 2017 21:36:43
Copyright (c) 2012 Broadcom
version f5217b8887607d0dd890a434de9c73d9aa9a7c0f (clean) (release)
# lsb_release
LibreELEC (Milhouse): devel-20170925010233-#0924-g6843ee6 [Build #0924]
# Kodi version
(18.0-ALPHA1 Git:208431e). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (6843ee6,
changelog) and tip of
XBMC master (208431e,
- Includes newclock5 patches
- Excludes the LibreELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.13.y
- Includes latest bcm2835-driver master (f8d2f54, ahead +6)
- Includes latest kodi-platform master (36fb493)
- Includes latest libcec master (8adc786, ahead +26)
- Includes latest libnfs master (3ba2a2c, ahead +101)
- Includes latest p8-platform master (a822e19)
- Includes latest addons: inputstream.adaptive (dde3921, +12), inputstream.rtmp (e094fa3), peripheral.joystick (cc14287), pvr.argustv (23cc0e8), pvr.demo (122dedd), pvr.dvblink (816f90c), pvr.dvbviewer (8741c8b), pvr.filmon (34dca04), pvr.hdhomerun (ace19fa), pvr.hts (53118d8), pvr.iptvsimple (ac4f4bd), pvr.mediaportal.tvserver (c86ab35), pvr.mythtv (8965048, +4), pvr.nextpvr (03933e9, +3), pvr.njoy (cc1cb56, +1), pvr.octonet (a77cf11), pvr.pctv (549f690), pvr.stalker (e15edca), pvr.teleboy (a799d13, +17), pvr.vbox (ff01396, +1), pvr.vdr.vnsi (f3f80d5, +1), pvr.vuplus (5e154bc, +4), pvr.wmc (7e2cb4b, +1), pvr.zattoo (dddc4b2, +18)
- Include [env] 22775c5: include crazycat dvb drivers addon in image
- Include [env] compare: dmidecode: initial package
- Include [env] compare: kodi updates (ffmpeg-3.3.4)
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: libcec: don't link non-existant libtinfo
- Include [env] patch: rev hack for kodi
- Include [env] patch: tvheadend42: fix makefile patch
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, other)
- Include [env] patch: pvr addons: disable broken addons
- Include [env] PR:1776: Don't cause system to hang on halt/reboot when net-booting
- Include [env] PR:1791: nss/nspr: include in main image [rfc]
- Include [env] PR:1835: add support for optional kernel modules in image and from addons
- Include [env] PR:1978: linux: update to linux-4.13.4
- Include [env] PR:2002: linux: include HBR and ELD fixes for Intel
- Include [pkg] e5dbcce3: X11: fix getting visual (kodi)
- Include [pkg] patch: skin.estuary: reduce system info font size (kodi)
- Include [pkg] PR:234: implement intensity compensation for VC-1 decoding for Ivybridge and better (intel-vaapi-driver)
- Include [pkg] PR:260: Fix Seeking with VC1 after 6702b01ee3598017f05374bfc7956493f790361c (intel-vaapi-driver)
- Include [pkg] PR:12715: RetroPlayer: Add renderer for Windows, OpenGL, OpenGLES and MMAL
- Include [pkg] PR:12826: Linux: add missing wrapper functions to fix playing DVD folders over network
- Revert [pkg] PR:12715/commits/940050cb1be27146d4e742830daca24e26e44899: [partial cherry-pick] MMAL: Fixup after planeOffsets change (reason: already in newclock5) (kodi)
- Revert [pkg] PR:12715/commits/fd269e5804adcf3f2953f46d3126b075e5239adb: PixelConverterRBP: Fix width/height typo (reason: already in newclock5) (kodi)
Build Highlights:
- New firmware (tvservice reference counting)
- RetroPlayer: Add renderer for Windows, OpenGL, OpenGLES and MMAL
Build Details:
- Firmware (Sep 22):
- firmware: tvservice: Avoid unmatched reference counting on attach/unplugged events. See: link
- LibreELEC.tv:
- kodi: switch to using find to avoid argument limit (PR:2034, 1 commit, 1 file changed)
- XBMC:
- VideoPlayer: fixes (PR:12828, 2 commits, 4 files changed)
- [PVR] Fix channel OSD dialog channel preselection. (PR:12823, 1 commit, 2 files changed)
- [ios/tvos] - added latest apple devices to allow retina support (PR:12832, 1 commit, 1 file changed)
- [windows][x64] add pillow (PR:12830, 1 commit, 1 file changed)
- pvr.mythtv:
- [lang] automatic syntax corrections for the en_GB language file (9553cd2)
- [lang] updated language files from Transifex (d9b517a)
- fix compilation warning since g++ 7.2.0 (738c8f4)
- bump version 5.4.1 (8965048)
- pvr.teleboy:
- pvr.zattoo:
- ubuntu/debian packaging fixes (PR:8, 4 commits, 4 files changed)
- [debian packaging] add pkg-config dependency (PR:9, 1 commit, 1 file changed)
- Remove tinyxml2 (aa7eca8)
- Update version and changelog (dddc4b2)
Quote: Build Highlights:
2.RetroPlayer: Add renderer for Windows, OpenGL, OpenGLES and MMAL
That sounds like a big step forward - thanks!
@garbear: does this mean n64 emulation is possible on arm devices?
Are you aware, that the game support addon (game compatibility core) is still incompatible in this build?
(2017-09-25, 06:50)linkinsoldier Wrote: [ -> ]That sounds like a big step forward - thanks!
Currently the renderer only does one thing, draws a rectangle. However, separating the renderer from VideoPlayer means we can build on top of it, and N64 emulation is one step closer to reality.
I've asked the LE team to recompile the game add-on so games should be working soon. I haven't yet tested the renderer on arm devices so I'm excited to see if it works.
(2017-09-24, 15:27)Milhouse Wrote: [ -> ]Yes.
[pi2]
arm_freq=1000
gpu_freq=400
over_voltage=4
force_turbo=1
sdram_freq=600
[pi3]
arm_freq=1300
gpu_freq=500
over_voltage=4
force_turbo=1
sdram_freq=580
Thanks for the info and the really cool conditional-feature. I didn't know about that. Will test the new Pi this evening
(2017-09-25, 07:13)garbear Wrote: [ -> ] (2017-09-25, 06:50)linkinsoldier Wrote: [ -> ]That sounds like a big step forward - thanks!
Thanks! I am looking forward to test it!
I remember that support for 10-bit video was added in firmware some releases ago. I did some tests with 1080p 10-bit H.264 files, but it was jerky with MMAL (but better than OMX with green overlay). Is overclocking needed? Any recommendations here for Pi3 with FLIRC case?
I don't know if this has anything to do with LibreELEC, but I just tried to install some addons, and none of them works. Manually installing from a ZIP file doesn't help. The log says:
20:07:16.280 T:1793344400 ERROR: Delete - Error deleting file /storage/.kodi/addons/packages/plugin.video.southpark_unofficial-0.4.6.zip
20:07:16.280 T:1793344400 ERROR: Delete - Error deleting file special://home/addons/packages/plugin.video.southpark_unofficial-0.4.6.zip
20:07:16.280 T:1793344400 ERROR: CAddonInstallJob[plugin.video.southpark_unofficial]: MD5 mismatch after download. Expected e2a05430d77e71fbf6c4b05b96e7a108, was
20:11:42.538 T:1783624592 ERROR: CAddonMgr: failed to unload plugin.video.southpark_unofficial
20:11:42.538 T:1783624592 ERROR: CAddonInstallJob[plugin.video.southpark_unofficial]: failed to unload addon.
20:12:32.992 T:1783624592 ERROR: CAddonMgr: failed to unload plugin.video.tagesschau
20:12:32.992 T:1783624592 ERROR: CAddonInstallJob[plugin.video.tagesschau]: failed to unload addon.
Is there anything I can do about it? All existing plugins are working fine, I just cannot add new ones.
(2017-09-25, 20:16)dantist Wrote: [ -> ]Is there anything I can do about it? All existing plugins are working fine, I just cannot add new ones.
Add-on installs have been broken since #0923 - try installing with #0922.
Couple of my usual kodi crashes immediately after an install and boot of a latest nightly, following are after install of #0924
kodi crashlog 1
kodi crashlog 2
As with previous, crash appears to occur during tvheadened backend/frontend Channel & EPG updates.
(Note: tvheadend frontend and backend are running on same rpi2 if this is relevant, DVB-T tuner powered by external usb hub)
Normal kodi start occurred and completed at third attempt...
New LibreELEC.tv Leia build #0925:
RPi /
RPi2
# uname -a
Linux rpi512 4.13.3 #1 Mon Sep 25 21:04:58 BST 2017 armv6l GNU/Linux
# vcgencmd version
# lsb_release
LibreELEC (Milhouse): devel-20170925210347-#0925-g6843ee6 [Build #0925]
# Kodi version
(18.0-ALPHA1 Git:617a394). Platform: Linux ARM 32-bit
Based on tip of
XBMC master (617a394,
- Includes latest addons: inputstream.adaptive (dde3921), inputstream.rtmp (e094fa3), peripheral.joystick (cc14287), pvr.argustv (23cc0e8), pvr.demo (122dedd), pvr.dvblink (816f90c), pvr.dvbviewer (8741c8b), pvr.filmon (34dca04), pvr.hdhomerun (ace19fa), pvr.hts (53118d8), pvr.iptvsimple (ac4f4bd), pvr.mediaportal.tvserver (c86ab35), pvr.mythtv (8965048), pvr.nextpvr (03933e9), pvr.njoy (cc1cb56), pvr.octonet (a77cf11), pvr.pctv (549f690), pvr.stalker (e15edca), pvr.teleboy (fd032f1, +2), pvr.vbox (ff01396), pvr.vdr.vnsi (f3f80d5), pvr.vuplus (5e154bc), pvr.wmc (7e2cb4b), pvr.zattoo (dddc4b2)
- Include [env] PR:2037: samba: update to samba-4.7.0
Build Highlights:
- samba: update to samba-4.7.0
Build Details:
- XBMC:
- X11: fix getting visual (PR:12835, 1 commit, 1 file changed)
- [music] SortByTrackNumber as default sort for "songs" (PR:12834, 1 commit, 1 file changed)
- [windows][x64] add pycryptodome (PR:12836, 1 commit, 1 file changed)
- pvr.teleboy:
- Added: [env] PR:2037: samba: update to samba-4.7.0
