(2017-03-18, 16:16)Milhouse Wrote: [ -> ] (2017-03-18, 15:56)indri Wrote: [ -> ]my 8bitdo nes30 controller works fine (which i use also as a tv remote), no problems at all.
The onboard RPi3 Bluetooth is 100% non-functional in the last build so presumably you're using some other hardware for Bluetooth (ie. a dongle) which may still be working. The RPi3 BT will be working again in the next build.
That's correct. Luckily I didn't try it on my Pi3. Thanks for the fix!
why from middle realeases kodi 17 and on all kodi 18 I get low power notification (top, right on screen) when play HD channels? HD channels on HW decoding. When I back to one first release of kodi 17, everything fine. My rp2 power from TV's USB.
(2017-03-19, 20:43)paulyz Wrote: [ -> ]why from middle realeases kodi 17 and on all kodi 18 I get low power notification (top, right on screen) when play HD channels? HD channels on HW decoding. When I back to one first release of kodi 17, everything fine. My rp2 power from TV's USB.
The TV's USB socket may only provide 500mA (that is all the spec guarantees).
They are often insufficient for running a Pi2 or Pi3 from.
The reason the warning appears is because the voltage has dropped below 4.63V.
You need a better power supply.
(2017-03-19, 20:52)popcornmix Wrote: [ -> ]The TV's USB socket may only provide 500mA (that is all the spec guarantees).
but this system working ~2 years. Yes, I know what TV's usb isn't power reactor , but why this begins only from one of kodi (or maybe PVR or etc update)? If, need more power, thats mean what something bad optimized?
Now installed official latest stable LibreELEC - the same.
(2017-03-19, 20:58)paulyz Wrote: [ -> ]but this system working ~2 years. Yes, I know what TV's usb isn't power reactor , but why this begins only from one of kodi (or maybe PVR or etc update)? If, need more power, thats mean what something bad optimized?
I suspect the problem has always been present. There have been issues with the warning symbols not being displayed in the past
(although processor still gets throttled, so your system wasn't running as it should).
If you can find a specific build that doesn't have the issue, I can investigate, but the real solution will be to get a power supply that can provide 5V when the processor is busy.
in old system, when I plug 4 sub devices, I get notification what low power, so, notification worked before. Maybe, in one of release minimum power value was raised?
I explain, why I powered from TV's usb, when I turn on tv, rpi2 turns on (power from USB) and start show IPTV. When I turn of TV, rpi2 tuns off (tv's USB stays powered ~15s after TV's off, it's enough for rpi to make clear shut down). This way very comfortable usage of rpi2.
this build work good: #1022, 22-Oct-2016: RPi / RPi2 -- Release post (Minors. Clean build.) (Kodi 17 - LibreELEC Testbuilds for RaspberryPi (Kodi 17.0))
(2017-03-19, 21:13)paulyz Wrote: [ -> ]I explain, why I powered from TV's usb, when I turn on tv, rpi2 turns on (power from USB) and start show IPTV. When I turn of TV, rpi2 tuns off (tv's USB stays powered ~15s after TV's off, it's enough for rpi to make clear shut down). This way very comfortable usage of rpi2.
You buy a master / slave connector, set the TV as master.
Exactly so I had solved the dilemma, if I turn on TV, AV-Receiver and RPi is also switched on.
I think is the best way and works well for a long time.
Just my 5 cent ;-)
(2017-03-19, 21:38)Aux_ Wrote: [ -> ]You buy a master / slave connector, set the TV as master.
Just my 5 cent ;-)
ok, need to think, thanks!
(2017-03-19, 21:13)paulyz Wrote: [ -> ]this build work good: #1022, 22-Oct-2016: RPi / RPi2 -- Release post (Minors. Clean build.) (Kodi 17 - LibreELEC Testbuilds for RaspberryPi (Kodi 17.0))
Did it really work though? Can you scan the library without getting the warning? Can you scroll through armwork in movies library view?
Can you play video with software decode?
Just my 5 cent ;-)
I checked amazon and google, guess I'm not searching for the right thing. Can you provide a link to such a device please.
New LibreELEC.tv Leia build #0319:
RPi /
RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.10.4 #1 Sun Mar 19 21:22:17 GMT 2017 armv6l GNU/Linux
# vcgencmd version
Mar 18 2017 14:05:55
Copyright (c) 2012 Broadcom
version 95a183d8579333fb96ba81afdc344dd74faf3bc7 (clean) (release)
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170319212112-#0319-gc8e19e7 [Build #0319]
# Kodi version
(18.0-ALPHA1 Git:93e9d69). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (c8e19e71,
changelog) and tip of
XBMC master (26d4d140,
- Includes newclock5 patches
- Excludes the LibreELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.10.y
- Includes latest bcm2835-driver master (38455935)
- Includes latest kodi-platform master (36fb4937, ahead +1)
- Includes latest libcec master (8563411d, ahead +30)
- Includes latest libnfs master (d501dc8a, ahead +55)
- Includes latest p8-platform master (2d90f986, ahead +9)
- Includes latest addons: inputstream.adaptive (aa0d5113, +1), inputstream.rtmp (6c1af46a, +7), peripheral.joystick (0c47f0e1, +9), pvr.argustv (5a36c586), pvr.demo (f2075086, +1), pvr.dvblink (bdc48989, +4), pvr.dvbviewer (9fb34b3c), pvr.filmon (5c6432db, +1), pvr.hdhomerun (98cb8d40), pvr.hts (819129d5, +2), pvr.iptvsimple (53d63cce), pvr.mediaportal.tvserver (76ae28f6, +1), pvr.mythtv (a3e4a500, +12), pvr.nextpvr (cb1b5415), pvr.njoy (3d097117, +1), pvr.octonet (8549a31c), pvr.pctv (e0d9f175, +1), pvr.stalker (ea970851, +1), pvr.vbox (dea8335a), pvr.vdr.vnsi (7033621d), pvr.vuplus (6ff2eb28), pvr.wmc (7bb31db9, +1)
- Include [env] 31a41616: linux: Enable Fair Queue packet scheduling (TEST)
- Include [env] 2447ac86: linux: Default to CONFIG_TCP_CONG_BBR (TEST)
- Include [env] patch: tvheadend42: fix ffmpeg
- Include [env] patch: rapidjson: drop yajl, add rapidjson
- Include [env] patch: linux: enable in-tree rtl8192cu for RPi/RPi2
- Include [env] patch: Add kodi binary addons (pvr, adsp, other)
- Include [env] PR:1431: scripts/mkimage: align partitions to 4MiB
- Include [env] PR:1452: Package updates
- Include [env] PR:1455: linux: update to linux-4.10.4
- Include [pkg] PR:56: bluetooth: add missing 'Connect' option when device is Trusted (service.libreelec.settings)
- Include [pkg] PR:8008: JSON: replace YAJL with RapidJSON
- Include [pkg] PR:11668: FFmpegImage: Document and change alignment
- Include [pkg] PR:11873: [Fix]Default music artist separators remove colon and "|" (ticket 17401)
Build Highlights:
- [addons] Update Chorus
- [Fix]Default music artist separators remove colon and "|" (ticket 17401)
Build Details:
- XBMC:
- [addons] Update Chorus (PR:11872, 1 commit, 6 files changed)
- FIX: [droid] force PIC (text reloc denied as of API 23) (PR:11870, 1 commit, 2 files changed)
- FIX: [depends;PIL] unzip with overwrite (PR:11876, 1 commit, 1 file changed)
- Added: [pkg] PR:11873: [Fix]Default music artist separators remove colon and "|" (ticket 17401)
3D ISO files issue.
I traced the issue with opening ISO files down to release #0316. Today's release #0319 is still not working.
#0315 is the last release opening 3D ISO files.
(2017-03-20, 01:17)3DBuff Wrote: [ -> ]3D ISO files issue.
Yep, same problem/result here. I suspect this one (introduced with #316):
[bluray] Improve Blu-ray playback (
PR:11836, 10 commits, 8 files changed)
It seems the folder BDMV/PLAYLIST won't be entered/scanned anymore, for whatever reason. Therefore it gets no *.mpls playlist(s) and no items to play.
@milhouse: Just let me know how I can be of help for debugging.
