(2019-01-07, 21:56)Milhouse Wrote: [ -> ]Berryboot is most likely your problem - there's a reason it's not supported for use with LibreELEC.
Is there anything we can do to help make it work out. Get in touch with Berryboot Owner to update or add support for something?
Or maybe new kernel in berryboot could fix this? As 4.14.x is old and LE is using 4.19.x?
(2019-01-08, 10:31)Aciel Wrote: [ -> ]Is there anything we can do to help make it work out. Get in touch with Berryboot Owner to update or add support for something?
Use NOOBS or PINN, they don't swap out the kernel and work fine with LibreELEC.
Swapping out the kernel will always cause issues, so don't use Berryboot.
so long,
Hias
No. Just don't use Berryboot, it's faulty by design, which is why you are having problems. The Berryboot owner has been contacted in the past and asked to stop distributing LibreELEC releases, which I believe he has agreed to, but someone else is continuing to release bastardised versions of LibreELEC, including my releases.
The version of LibreELEC you are using with Berryboot is not the same version I released, so it's impossible to support, and this goes for official LibreELEC releases too.
If you use Berryboot, the Berryboot developers are your first (and likely only) point of contact for any and all issues.
If you want to multiboot, then use NOOBS or PINN, as these do not butcher the LibreELEC distribution in order to work (they're also officially supported by LibreELEC).
(2019-01-08, 10:31)Aciel Wrote: [ -> ]Or maybe new kernel in berryboot could fix this? As 4.14.x is old and LE is using 4.19.x?
There's only one kernel that works with my releases, and that's the kernel I ship with each release.
If you want to randomly replace the kernel I ship with another, as Berryboot does, then ask the Berryboot developers for help as I'm not going to entertain this madness!
(2019-01-07, 01:01)Termits Wrote: [ -> ] (2019-01-07, 00:47)smp1 Wrote: [ -> ] (2019-01-07, 00:43)Termits Wrote: [ -> ]Code:
https://drive.google.com/file/d/18QdMXOLe551IixkCA7Dw-R20Euu0u31D/view?usp=sharing
It plays fine on my Pi 3.
I'm not with my raspberry now, but I try to play remote the file. now switch to correct codec:
log:
23:52:37.789 T:1456452464 NOTICE: Creating InputStream
23:52:37.809 T:1456452464 NOTICE: Creating Demuxer
23:52:38.230 T:1456452464 NOTICE: OMXPlayerUnsuitable OMXPlayer unsuitable due to video codec (ad:0/1)
23:52:38.249 T:1456452464 NOTICE: Opening stream: 0 source: 256
23:52:38.250 T:1456452464 WARNING: OpenStream - Unsupported stream 0. Stream disabled.
23:52:38.251 T:1456452464 NOTICE: Opening stream: 3 source: 256
23:52:38.251 T:1456452464 NOTICE: Finding audio codec for: 86019
23:52:38.259 T:1456452464 NOTICE: CDVDAudioCodecFFmpeg::Open() Successful opened audio decoder ac3
23:52:38.259 T:1456452464 NOTICE: Creating audio thread
23:52:38.260 T:1456452464 NOTICE: Opening stream: 6 source: 256
23:52:38.261 T:1456452464 NOTICE: Opening stream: 5 source: 256
23:52:38.261 T:1456452464 NOTICE: waiting for teletext data thread to exit
23:52:38.263 T:1418523504 NOTICE: running thread: CVideoPlayerAudio::Process()
23:52:38.269 T:1456452464 NOTICE: Creating teletext data thread
23:52:38.269 T:1426916208 NOTICE: running thread: CDVDTeletextData
23:52:38.310 T:1456452464 NOTICE: Opening stream: 0 source: 256
23:52:38.311 T:1456452464 NOTICE: Creating video codec with codec id: 173
23:52:38.312 T:1456452464 ERROR: CMMALVideo::Open : Video codec unknown: ad
23:52:38.312 T:1456452464 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: HEVC (rpi)
23:52:38.421 T:1456452464 NOTICE: Creating video thread
23:52:38.422 T:1473237872 NOTICE: running thread: video_thread
23:52:38.427 T:1456452464 NOTICE: Opening stream: 3 source: 256
23:52:38.427 T:1456452464 NOTICE: Closing stream player 3
23:52:38.427 T:1456452464 NOTICE: Opening stream: 6 source: 256
23:52:38.428 T:1456452464 NOTICE: Opening stream: 5 source: 256
23:52:38.438 T:1418523504 NOTICE: Creating audio stream (codec id: 86019, channels: 2, sample rate: 48000, no pass-through)
23:52:38.438 T:1473237872 NOTICE: CDecoder::Open - fmt:183
tvheanded problem log:
20:24:31.293 T:1937713552 NOTICE: VideoPlayer::OpenFile: pvr://channels/tv/All channels/pvr.hts_1683439791.pvr
20:24:31.295 T:1804190576 NOTICE: Creating InputStream
20:24:31.299 T:1804190576 NOTICE: Creating Demuxer
20:24:33.432 T:1804190576 NOTICE: Opening stream: 1001 source: 256
20:24:33.432 T:1804190576 ERROR: COMXVideo::Open : Video codec unknown: ad
20:24:33.432 T:1804190576 ERROR: OMXPlayerVideo : Error open video output
20:24:33.432 T:1804190576 WARNING: OpenStream - Unsupported stream 1001. Stream disabled.
20:24:33.432 T:1804190576 NOTICE: Opening stream: 1002 source: 256
20:24:33.436 T:1804190576 NOTICE: Creating audio thread
20:24:33.437 T:1804190576 NOTICE: Opening stream: 1004 source: 256
20:24:33.437 T:1804190576 NOTICE: waiting for teletext data thread to exit
20:24:33.442 T:1804190576 NOTICE: Creating teletext data thread
20:24:33.442 T:1440736112 NOTICE: running thread: CDVDTeletextData
20:24:33.446 T:1804190576 NOTICE: Opening stream: 1001 source: 256
20:24:33.447 T:1804190576 ERROR: COMXVideo::Open : Video codec unknown: ad
20:24:33.447 T:1804190576 ERROR: OMXPlayerVideo : Error open video output
20:24:33.447 T:1804190576 WARNING: OpenStream - Unsupported stream 1001. Stream disabled.
20:24:33.447 T:1804190576 NOTICE: Opening stream: 1002 source: 256
20:24:33.447 T:1804190576 NOTICE: Opening stream: 1004 source: 256
20:24:33.697 T:1804190576 NOTICE: OMXClock using audio as reference
Helo, how can set for tvheadend client decoding HEVC same as :
New LibreELEC.tv Leia build #0108:
RPi /
RPi2
(Supercedes previous build)
SHA256 Checksum:
da663d9adc482dcc74eb2947b993147a547ad85d6ed0d3e2021275cd93ffed52
(RPi)
SHA256 Checksum:
822f4fd3b5cfd27ed9bcd3b2256018b53bf866d1d10eedf9756c39ae56a61b24
(RPi2)
text:
# uname -a
Linux rpi512 4.19.13 #1 Tue Jan 8 21:25:12 GMT 2019 armv6l GNU/Linux
# vcgencmd version
Dec 18 2018 00:00:23
Copyright © 2012 Broadcom
version da468960fe03ecbaa8e3f1ee01c7217c3bd01fa8 (clean) (release)
# lsb_release
LibreELEC (Milhouse): devel-20190108212405-#0108-gdf9076a [Build #0108]
# Kodi version
(18.0-RC5 Git:adb55e2). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (df9076a,
changelog) and tip of
XBMC master (adb55e2,
- Includes newclock5 patches
- Includes latest bcm2835-driver master (e1bd9b0, ahead +1)
- Includes latest kodi-platform master (e8574b8)
- Includes latest libcec master (3bbd432)
- Includes latest libnfs master (38b62bc)
- Includes latest p8-platform master (1eb12b1)
- Includes latest addons: inputstream.adaptive (efd4b4f), inputstream.rtmp (ce7f559), peripheral.joystick (1f4225a), peripheral.xarcade (f09a0e7), pvr.argustv (83aa1e9), pvr.demo (964686d), pvr.dvblink (4ae42fe), pvr.dvbviewer (4751884, +2), pvr.filmon (e850633), pvr.hdhomerun (a9d7309), pvr.hts (a7f101b, +3), pvr.iptvsimple (90a8d6f), pvr.mediaportal.tvserver (25e3e7d), pvr.mythtv (5272219, +1), pvr.nextpvr (4d6df2f, +4), pvr.njoy (4467cac), pvr.octonet (203f800), pvr.pctv (b60b971), pvr.stalker (d0170c5, +1), pvr.teleboy (1956113), pvr.vbox (ea20464, +1), pvr.vdr.vnsi (cbb75ab), pvr.vuplus (fb822e9, +20), pvr.wmc (2697409), pvr.zattoo (d44651f), vfs.libarchive (6d39012), vfs.rar (0f56401), vfs.sftp (6749200)
- Include [env] compare (perma): kodi-next
- Include [env] compare (perma): TESTING: increase timeout to ensure OS is able to create core dump/crash log
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: kodi: use upstream repo for Milhouse RPi builds
- Include [env] patch: kodi: remove annoying, excessively repetitive addon logging
- Include [env] patch: rev hack for kodi
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, peripheral.joystick/xarcade, other)
- Include [env] PR:3164 (perma): ffmpegx: disable nonfree
- Include [env] PR:3196 (perma): linux (RPi/Generic): update to linux-4.19.13
- Include [env] PR:3202 (perma): busybox: update to busybox-1.30.0
- Include [env] PR:3209 (perma): zstd: update to 1.3.8
- Include [env] PR:3211 (perma): xf86-video-nvidia: update to xf86-video-nvidia-410.93
- Include [env] PR:3219 (perma): qemu: update to qemu-3.1.0
- Include [env] PR:3220 (perma): alsa: update 1.1.8
- Include [pkg] PR:117 (perma): improve wording of Thank You page (service.libreelec.settings)
- Include [pkg] PR:14924 (perma): [games] Fix crash in PCSX ReARMed with BIOS
- Include [pkg] PR:15164 (perma): TexturePacker: Fix memory / resource leak the ugly way
Build Highlights:
- New splash video from Sam Fisher!
- alsa: update 1.1.8
Build Details:
- XBMC:
- Fix Artist Info dialog click on discography (PR:15191, 1 commit, 1 file changed)
- pvr.nextpvr:
- More fixes for live tv tsb and seeks (PR:82, 1 commit, 13 files changed)
- Updated: [env] patch: Add experimental splash video for RPi
- Added: [env] PR:3219 (perma): qemu: update to qemu-3.1.0
- Added: [env] PR:3220 (perma): alsa: update 1.1.8
Hi, since the #0103 i have had all Series split into Seasons. So like one Series with 5 Seasons inside are now in the Series view 5 times displayed. (I have a remote MySQL DB)
A quick look in the MySQL Database i have found that now in the myvideos114 - tvshow_view there is the "GROUP BY tvshow.idShow" at the end of the SELECT missing.
I just added it there like it was in the 113 DB and now everything looks right.
I don't know if this problem was just on my side or everyone has this problem since the new 114DB...
Hi, I also had similar problem since #0103 using SQLlite. Show spanning over multiple source path, where listed multiple time (once per source path).
Deleting and re-creating the tvshow_view view as in db113, fixed the problem.
(2019-01-09, 14:22)Salamek Wrote: [ -> ]Hi, since the #0103 i have had all Series split into Seasons. So like one Series with 5 Seasons inside are now in the Series view 5 times displayed. (I have a remote MySQL DB)
I have a remote MySQL DB as well and I don't have this problem, I just switched from 1219 (113) to 0108 (114)
New LibreELEC.tv Leia build #0109:
RPi /
RPi2
SHA256 Checksum:
3935f24d7e28adf66434401515e6674caec9b510817071c8f1cc8a40e22f8fa3
(RPi)
SHA256 Checksum:
3fa201c4442ae13e6d674c3a6f77c89f69241ab1a74634437a54df6666806728
(RPi2)
text:
# uname -a
Linux rpi512 4.19.14 #1 Wed Jan 9 21:25:21 GMT 2019 armv6l GNU/Linux
# vcgencmd version
Jan 9 2019 20:07:49
version bcefbb195b77d6b9a02dfbad0e1fff3b18122585 (clean) (release)
# lsb_release
LibreELEC (Milhouse): devel-20190109211750-#0109-g1c86567 [Build #0109]
# Kodi version
(18.0-RC5 Git:7d27c5e). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (1c86567,
XBMC master (7d27c5e,
- Includes latest bcm2835-driver master (9baae76, ahead +2)
- Include [env] PR:3196 (perma): linux (RPi/Generic): update to linux-4.19.14
- Include [pkg] PR:118 (perma): Language option in first run wizard (service.libreelec.settings)
Build Highlights:
- New firmware (third transpose buffer; Reset WiFi and BT devices before expander; Fix Ethernet boot on a different subnet)
- New 4.19.14 kernel
- Language option in first run wizard
Build Details:
- Firmware (Jan 9):
- firmware: Added ability to have an third transpose buffer. See: link
- firmware: isp: Correct the conversion tables changed in adding the gamma block. See: link
- firmware: raspberrypi_full variant: Drop unused Camplus sw stages
- bootcode: Reset WiFi and BT devices before resetting the expander. See: link
- bootcode: Fix Ethernet boot on a different subnet. See: link
- LibreELEC.tv:
- zstd: update to 1.3.8 (PR:3209, 1 commit, 1 file changed)
- xf86-video-nvidia: update to xf86-video-nvidia-410.93 (PR:3211, 1 commit, 1 file changed)
- libdvdcss is building even when disabled (PR:3222, 1 commit, 1 file changed)
- XBMC:
- Prevent crash when trying to resume audiobook with no chapters (PR:15213, 1 commit, 2 files changed)
- newclock5:
- New commits in this build:
- fix for compiling with libbluray disabled (a54492d3)
- Updated: [env] PR:3164 (perma): ffmpegx: disable nonfree
- Updated: [env] PR:3196 (perma): linux (RPi/Generic): update to linux-4.19.14
- Added: [pkg] PR:118 (perma): Language option in first run wizard (service.libreelec.settings)
Hi LE team,
Latest TVheadend is not working again. TVheadend client can not connect to tvheadend server.
log -
http://ix.io/1xXz
(2019-01-10, 16:44)Aux_ Wrote: [ -> ]Hi LE team,
log - http://ix.io/1xXz
tvheadend42 seemed to be crashing in a loop, then it stopped crashing after it was stopped and restarted - did you downgrade the version of tvheadend42 to an older version?
(2019-01-10, 23:16)Milhouse Wrote: [ -> ] (2019-01-10, 16:44)Aux_ Wrote: [ -> ]Hi LE team,
Sorry my mistake I had already done that and forgot to mention.
service.tvheadend42-9.0.118-0108_milhouse-v4.2.6-122-gefefb31 works fine
(2019-01-10, 23:27)Aux_ Wrote: [ -> ] (2019-01-10, 23:16)Milhouse Wrote: [ -> ] (2019-01-10, 16:44)Aux_ Wrote: [ -> ]Hi LE team,
Sorry my mistake I had already done that and forgot to mention. service.tvheadend42-9.0.118-0108_milhouse-v4.2.6-122-gefefb31 works fine
Thanks, we've determined the issue (a missing libidn2 shared library) - will be fixed tonight in #0110.
New LibreELEC.tv Leia build #0110:
RPi /
RPi2
SHA256 Checksum:
96a14a9d82907cb71e55b4b0810a6dc9d6690b9a12dce5b7b47930347756f0e6
(RPi)
SHA256 Checksum:
3f2e548f1629d151e42df8a8c213528b07d51f9e690b9ce1d7f51a591703d558
(RPi2)
text:
# uname -a
Linux rpi512 4.19.14 #1 Thu Jan 10 21:50:15 GMT 2019 armv6l GNU/Linux
# vcgencmd version
Jan 9 2019 20:07:49
# lsb_release
LibreELEC (Milhouse): devel-20190110214911-#0110-g1c86567 [Build #0110]
# Kodi version
(18.0-RC5 Git:cb6e844). Platform: Linux ARM 32-bit
Based on tip of
XBMC master (cb6e844,
- Includes latest bcm2835-driver master (9baae76)
Build Highlights:
- Minors
Build Details:
- XBMC:
- Transparency Games for Android (PR:15225, 2 commits, 4 files changed)
