New LibreELEC.tv Leia build #0322:
RPi /
RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.10.4 #1 Wed Mar 22 23:33:49 GMT 2017 armv6l GNU/Linux
# vcgencmd version
Mar 21 2017 20:31:08
Copyright (c) 2012 Broadcom
version 3fd9e96ec97d387f230e66872443c1ecf44c04c6 (clean) (release)
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170322233240-#0322-gbdbe578 [Build #0322]
# Kodi version
(18.0-ALPHA1 Git:badda83). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (bdbe5783,
changelog) and tip of
XBMC master (5ad6cea3,
- Includes newclock5 patches
- Excludes the LibreELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.10.y
- Includes latest bcm2835-driver master (3e82d901, ahead +1)
- Includes latest kodi-platform master (36fb4937)
- Includes latest libcec master (8563411d, ahead +11)
- Includes latest libnfs master (d501dc8a, ahead +55)
- Includes latest p8-platform master (2d90f986)
- Includes latest addons: inputstream.adaptive (aa0d5113), inputstream.rtmp (6c1af46a), peripheral.joystick (0c47f0e1), pvr.argustv (5a36c586), pvr.demo (f2075086), pvr.dvblink (bdc48989), pvr.dvbviewer (9fb34b3c), pvr.filmon (5c6432db), pvr.hdhomerun (98cb8d40), pvr.hts (819129d5), pvr.iptvsimple (53d63cce), pvr.mediaportal.tvserver (76ae28f6), pvr.mythtv (a3e4a500), pvr.nextpvr (cb1b5415), pvr.njoy (3d097117), pvr.octonet (8549a31c), pvr.pctv (e0d9f175), pvr.stalker (ea970851), pvr.vbox (4215450f, +1), pvr.vdr.vnsi (9ede401c), pvr.vuplus (6ff2eb28), pvr.wmc (7bb31db9)
- Include [env] patch: tvheadend42: fix ffmpeg
- Include [env] patch: iwlwifi-firmware: update to iwlwifi-firmware-ba301aa
- Include [env] patch: rapidjson: drop yajl, add rapidjson
- Include [env] patch: linux: enable in-tree rtl8192cu for RPi/RPi2
- Include [env] patch: Add kodi binary addons (pvr, adsp, other)
- Include [env] PR:1431: scripts/mkimage: align partitions to 4MiB
- Include [env] PR:1459: support for ip advanced router and add multiple tcp congestion algorithms
- Include [env] PR:1465: Package updates: update kodi, ffmpeg, libcec
- Include [env] PR:1469: samba: update to samba-4.6.0
- Include [pkg] PR:56: bluetooth: add missing 'Connect' option when device is Trusted (service.libreelec.settings)
- Include [pkg] PR:62: #change smbd and nmbd location (service.libreelec.settings)
- Include [pkg] PR:8008: JSON: replace YAJL with RapidJSON
- Include [pkg] PR:11668: FFmpegImage: Document and change alignment
Build Highlights:
- New firmware (allow top 16M of sdram to be used if enabled with total_mem=1024 - disabled by default)
- Update to samba 4.6.0, with SMB3 support - if you're using a custom samba.conf please rebase on /etc/samba/smb.conf
- bluray - restore "Play main title" menu item
Build Details:
- Firmware (Mar 21):
- bootcode: Allow top 16M if sdram to be used
- Disabled by default, but can be enabled with total_mem=1024
- LibreELEC.tv:
- Fix file system resize script hang (PR:1369, 2 commits, 3 files changed)
- XBMC:
- [bluray] Fix CID 1403183: Control flow issues (NO_EFFECT). (PR:11889, 1 commit, 1 file changed)
- [cmake] Fix compiling of Android-X86 after 742cc3c31b by checking SSE support again (PR:11888, 1 commit, 1 file changed)
- depends: remove libsdl_image and libsdl2 (PR:11881, 5 commits, 14 files changed)
- [Fix] adapt gitignore for depends after da63933 (PR:11890, 1 commit, 1 file changed)
- Revert "[bluray] Early return if requested "dir" is in fact a file." (PR:11891, 1 commit, 1 file changed)
- pvr.vbox:
- Fix path to CMakeLists.txt (PR:187, 1 commit, 1 file changed)
- pvr.vdr.vnsi:
- Fix path to CMakeLists.txt (PR:1, 1 commit, 1 file changed)
- Added: [env] PR:1469: samba: update to samba-4.6.0
- Added: [pkg] PR:62: #change smbd and nmbd location (service.libreelec.settings)
RPi3b.
I have a custom samba.conf in .kodi/.config. /etc/samba/smb.conf does not appear to reflect this.
With #322 the share on the Pi is no longer accessible from Windows.
Revert to #321 and the share is accessible again.
Any ideas?
(2017-03-23, 19:01)agb2 Wrote: [ -> ]> Update to samba 4.6.0, with SMB3 support - if you're using a custom samba.conf please rebase on /etc/samba/smb.conf
RPi3b.
Any ideas?
Is the share available when using the stock /etc/samba/smb.conf (ie. remove your custom /storage/.config/samba.conf)?
Have you confirmed samba is enabled in LE Settings addon?
New LibreELEC.tv Leia build #0323:
RPi /
RPi2
# uname -a
Linux rpi512 4.10.5 #1 Thu Mar 23 21:04:16 GMT 2017 armv6l GNU/Linux
# vcgencmd version
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170323210311-#0323-ga339aa7 [Build #0323]
# Kodi version
Based on tip of
LibreELEC.tv master (a339aa7a,
XBMC master (bae219a8,
- Includes latest addons: inputstream.adaptive (aa0d5113), inputstream.rtmp (6c1af46a), peripheral.joystick (b4642600, +2), pvr.argustv (7135b279, +1), pvr.demo (1606b612, +1), pvr.dvblink (7296c5b5, +1), pvr.dvbviewer (13c6e5e7, +1), pvr.filmon (e026519d, +1), pvr.hdhomerun (98cb8d40), pvr.hts (819129d5), pvr.iptvsimple (53d63cce), pvr.mediaportal.tvserver (d4dad613, +1), pvr.mythtv (08d609b2, +1), pvr.nextpvr (bb21826b, +1), pvr.njoy (1ce9aba1, +1), pvr.octonet (8549a31c), pvr.pctv (e3b2b845, +1), pvr.stalker (0466af9d, +1), pvr.vbox (4215450f, +1), pvr.vdr.vnsi (9ede401c), pvr.vuplus (12930650, +1), pvr.wmc (5aa3b1ca, +1)
- Include [env] compare: linux: update to linux-4.10.5
- Include [env] PR:1474: scripts: revert changes that led to accumulation of old packages
- Include [env] PR:1477: config/path: addons need kodi
- Include [env] PR:1478: userconfig: overwrite our sample files
- Include [pkg] PR:11879: [PVR] Guide window: Fix selection after channelgroup switching
Build Highlights:
- New 4.10.5 kernel
- [PVR] Guide window: Fix selection after channelgroup switching
Build Details:
- LibreELEC.tv:
- XBMC:
- [docs] Update README.android (PR:11854, 1 commit, 1 file changed)
- peripheral.joystick:
- [sdl] Fix hang when rescanning for joysticks (PR:92, 1 commit, 1 file changed)
- Bump peripheral.joystick to v1.3.2 for SDL fix (PR:93, 1 commit, 1 file changed)
- pvr.argustv:
- Fix path to CMakeLists.txt (PR:63, 1 commit, 1 file changed)
- pvr.demo:
- Fix path to CMakeLists.txt (PR:41, 1 commit, 1 file changed)
- pvr.dvblink:
- Fix path to CMakeLists.txt (PR:80, 1 commit, 1 file changed)
- pvr.dvbviewer:
- Fix path to CMakeLists.txt (PR:55, 1 commit, 1 file changed)
- pvr.filmon:
- Fix path to CMakeLists.txt (PR:66, 1 commit, 1 file changed)
- pvr.mediaportal.tvserver:
- Fix path to CMakeLists.txt (PR:61, 1 commit, 1 file changed)
- pvr.mythtv:
- Fix path to CMakeLists.txt (PR:107, 1 commit, 1 file changed)
- pvr.nextpvr:
- pvr.njoy:
- Fix path to CMakeLists.txt (PR:34, 1 commit, 1 file changed)
- pvr.pctv:
- Fix path to CMakeLists.txt (PR:43, 1 commit, 1 file changed)
- pvr.stalker:
- Fix path to CMakeLists.txt (PR:86, 1 commit, 1 file changed)
- pvr.vuplus:
- pvr.wmc:
- Fix path to CMakeLists.txt (PR:49, 1 commit, 1 file changed)
- kernel 4.10.y:
- New commits in this build:
- ASoC: Add prompt for ICS43432 codec (b9503a4a)
- bcm2835-aux: Add aux interrupt controller (804636a1)
- BCM270X_DT: Enable AUX interrupt controller in DT (39c6ddfc)
- Added: [env] compare: linux: update to linux-4.10.5
- Added: [env] PR:1474: scripts: revert changes that led to accumulation of old packages
- Added: [env] PR:1477: config/path: addons need kodi
- Added: [env] PR:1478: userconfig: overwrite our sample files
- Added: [pkg] PR:11879: [PVR] Guide window: Fix selection after channelgroup switching
(2017-03-23, 20:37)Milhouse Wrote: [ -> ] (2017-03-23, 19:01)agb2 Wrote: [ -> ]> Update to samba 4.6.0, with SMB3 support - if you're using a custom samba.conf please rebase on /etc/samba/smb.conf
RPi3b.
Any ideas?
[scrapes egg off face]
Yes, Samba is enabled.
I renamed the custom samba.conf and all works!
The custom parts were there because I wanted to change the workgroup name and 'master browser' settings.
Presumably what I need to do is copy /run/samba/smb.conf to .config and edit it there?
I guess this is what "rebase on /etc/samba/smb.conf" means.
This is on #323 by the way.
Thanks for the help :-}
Edit.
Yep, did that, changed workgroup name and master browser settings, working fine.
(2017-03-24, 11:30)agb2 Wrote: [ -> ]I renamed the custom samba.conf and all works!
Edit.
Thanks for the update.
With #0323 there's a fix so that the previously static (and potentially stale) *.conf.sample files in /storage/.config now update to latest sample files shipped with the system, so you should be able to copy /storage/.config/samba.conf.sample to /storage/.config/samba.conf and then edit the latter.
Using /run/samba/smb.conf isn't actually a good idea as that is an automatically generated file based on your config file (either /etc/samba/smb.conf, or /storage/.config/samba.conf). Several modifications are made, including the addition of automounted shares, and enabling passwords (if configured).
(2017-03-24, 14:06)Milhouse Wrote: [ -> ] (2017-03-24, 11:30)agb2 Wrote: [ -> ]I renamed the custom samba.conf and all works!
Edit.
OK, I'll have a look at the sample, and so as you suggest. Thanks for the info.
Build #0322 and "Update to samba 4.6.0, with SMB3 support - if you're using a custom samba.conf please rebase on /etc/samba/smb.conf"
Just a heads up that like agb2 this inclusion initially caught me off guard as well; as I had completely forgotten, that I had created a samba.conf from samba.conf.sample in order to enable quick access from Windows to [Storage] path = /storage
I removed existing samba.conf from .config folder then used new samba.conf.sample to re-create my custom samba.conf and all is working correctly again
Thank you for clear warning in build #0322 notes Milhouse
New LibreELEC.tv Leia build #0324:
RPi /
RPi2
# uname -a
Linux rpi512 4.10.5 #1 Fri Mar 24 21:04:05 GMT 2017 armv6l GNU/Linux
# vcgencmd version
Mar 24 2017 13:57:27
version 7e9eb8ef90a1cfb42aca39c27807d2d145a403a1 (clean) (release)
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170324210301-#0324-g0ee76f6 [Build #0324]
# Kodi version
(18.0-ALPHA1 Git:b877760). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (0ee76f6d,
XBMC master (414c0591,
- Includes latest bcm2835-driver master (9385e1a7, ahead +2)
- Includes latest addons: inputstream.adaptive (aa0d5113), inputstream.rtmp (6c1af46a), peripheral.joystick (b4642600), pvr.argustv (7135b279), pvr.demo (1606b612), pvr.dvblink (7296c5b5), pvr.dvbviewer (13c6e5e7), pvr.filmon (e026519d), pvr.hdhomerun (98cb8d40), pvr.hts (819129d5), pvr.iptvsimple (53d63cce), pvr.mediaportal.tvserver (d4dad613), pvr.mythtv (08d609b2), pvr.nextpvr (bb21826b), pvr.njoy (1ce9aba1), pvr.octonet (8549a31c), pvr.pctv (e3b2b845), pvr.stalker (0466af9d), pvr.vbox (4215450f), pvr.vdr.vnsi (9ede401c), pvr.vuplus (12930650), pvr.wmc (5aa3b1ca)
Build Highlights:
- New firmware (gpu_server/qpu fixes)
Build Details:
- Firmware (Mar 24):
- firmware: gpu_server: unreserve the qpu user shaders at end of each job
- firmware: gpu_server: Only enable/disable qpus at start/end of service connection
- LibreELEC.tv:
- scripts: revert changes that led to accumulation of old packages (PR:1474, 4 commits, 2 files changed)
- config/path: addons need kodi (PR:1477, 1 commit, 1 file changed)
- libdvbcsa: use enable-neon for Aarch64 (PR:1453, 1 commit, 1 file changed)
- userconfig: overwrite our sample files (PR:1478, 1 commit, 3 files changed)
- Re-enable lirc_serial driver (#1454) (cf13c269)
- cosmetics: misc. https URL replacements (d3430d31)
- config: remove unused/outdated file (0ee76f6d)
- XBMC:
- [Peripherals] Fix segfault by adding some synchronization to peripheral add-ons (PR:11824, 6 commits, 70 files changed)
- JSON: replace YAJL with RapidJSON (PR:8008, 4 commits, 30 files changed)
- [pvr] cleanups in PVR manager (PR:11887, 5 commits, 55 files changed)
- [cmake] change RapidJSON_INCLUDE_DIRS to capital letters to get added to SYSTEM_INCLUDES (PR:11896, 1 commit, 1 file changed)
Just updated from #323 to #324. Now the pvr manager can't get the channel list from tvheadend 4.2 service running on 127.0.0.1. It stays at 0%. I also tried both service versions , #323 and #324, just to make sure. According to tvheadend service the client is connected.Guess the latest pvr cleanup needs to be revisited?
(2017-03-25, 12:38)-DH- Wrote: [ -> ]Just updated from #323 to #324. Now the pvr manager can't get the channel list from tvheadend 4.2 service running on 127.0.0.1. It stays at 0%. I also tried both service versions , #323 and #324, just to make sure. According to tvheadend service the client is connected.Guess the latest pvr cleanup needs to be revisited?
I think there'll be a fix for that in tonight's build, PR11898
Same for me, after cleaning all data in pvr settings it's working.
(2017-03-25, 17:30)polo_joe Wrote: [ -> ] (2017-03-25, 12:38)-DH- Wrote: [ -> ]Just updated from #323 to #324. Now the pvr manager can't get the channel list from tvheadend 4.2 service running on 127.0.0.1. It stays at 0%. I also tried both service versions , #323 and #324, just to make sure. According to tvheadend service the client is connected.Guess the latest pvr cleanup needs to be revisited?
Yep, that worked. Thanks a lot.
New LibreELEC.tv Leia build #0325:
RPi /
RPi2
# uname -a
Linux rpi512 4.10.5 #1 Sat Mar 25 21:04:32 GMT 2017 armv6l GNU/Linux
# vcgencmd version
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170325210326-#0325-g0ee76f6 [Build #0325]
# Kodi version
(18.0-ALPHA1 Git:78cce57). Platform: Linux ARM 32-bit
Based on tip of
XBMC master (78cce573,
- Includes latest bcm2835-driver master (76fc4dde, ahead +3)
- Includes latest libnfs master (e22538c7, ahead +56)
Build Highlights:
- Fix for PVR Manager
Build Details:
- XBMC:
- [PVR] Follow PR11887: Fix CPVRManager::ConnectionStateChange not to c… (PR:11898, 1 commit, 1 file changed)
- libnfs:
- Cygwin should not use winsock2 (PR:177, 1 commit, 1 file changed)
I am finding that the "clean library" function is not working properly.
For example if I have a movie "50.first.dates.2004.mp4" which successfully gets scanned in, then I rename it "50 First Dates (2004).mp4" and rescan it, I get two duplicate entries.
Running "clean library" does not delete the old entry. Running version 334.
