(2017-09-13, 07:25)polo_joe Wrote: [ -> ] (2017-09-12, 22:12)Milhouse Wrote: [ -> ] (2017-09-12, 21:22)polo_joe Wrote: [ -> ]Build #0909 is also bad for me. Last working build is #0908. So downgrading.
That's weird, and not really expected, as #0909 has no changes that should affect Kodi - the samba change is simply a validation of a config file you probably don't have, and the fpic changes affect only x86_64.
So the #0909 build is basically a clean build of #0908.
The tvheadend addon itself hasn't had any new code changes since 1 September.
Are you absolutely sure the problem starts with #0909?
I'm sure #0908 is the last working build for me. Will try today #0912 and report back.
No improvement with build #0912.
Anyone getting a pop sound after resuming playback from a paused stated? Started a few builds ago, haven’t isolated the version yet but it is very recent.
Sent from my iPhone
(2017-09-13, 07:26)polo_joe Wrote: [ -> ] (2017-09-12, 21:27)hawkeyexp Wrote: [ -> ]I can confirm - also have probs with async audio in tvheadend with dvbs.
Could you identify the last working build for you?
For me #0908 is good and #0909 is bad.
Last working build without audio issue is 0907 for me. With 0908 audio starts to begin async. 0912 has also the probs.
(2017-09-11, 07:59)ksooo Wrote: [ -> ]The crash is due to a corrupted tv database. We know this bug and it's pretty old, but no dev was able to reproduce so far and to come up with a fix, unfortunately.
There is no step by step instructions how to reproduce. That's a real problem.
The crash is not related to tvheadend, btw. Users using other pvr backends are also experiencing it.
Okay. Thanks.
I don't know if uploading the crashlog from a debug build will help or not, but here's one.
http://sprunge.us/ZQRf
This crashlog seems to have been generated at or near the same time I was using WinSCP to look to see if a crashlog existed. I was not able to stfp or ssh into the Pi. The Pi had also frozen on the home screen and I had to yank the power plug out to get it going again.
Strangely, this crashlog does not contain any of the viewing I did last night. I had watched a TV show I previously recorded, then a video from "TV Shows", then some Live TV. It's not in kodi.log.old either as that was overwritten on reboot.
I have a second Pi also running the debug build provided by Milhouse. It hasn't been used yet and it is still running fine. Here's it's kodi.log:
http://sprunge.us/CcAK
Hope this helps.
(2017-09-12, 21:22)polo_joe Wrote: [ -> ] (2017-09-12, 20:11)popcornmix Wrote: [ -> ] (2017-09-11, 18:55)polo_joe Wrote: [ -> ]Didn't test #0909 but #0908 was OK for me.
Would be useful if you could confirm if problem started with #0909 or #0910.
This is debug log from working build #0908
http://sprunge.us/ITNd
I found issues with Kodi crashing or freezing during inpupstream playback. This sporadically happens when the stream buffers and I press stop:
Here is a crash (reboot):
https://pastebin.com/qFuUabKS
and here is a freeze (time keeps saying 21:55, but even after 20 minutes no update of the screen). I sshed and rebooted: *edit: i failed to upload it to pastebin .. log has about 10 Mb - any other suggestions for uploading other than pastebin? PN / email?
I use build #911 but I am not sure when this started (going back to #907 and #909 I had the same behaviour). Issue happened during watching episode 4 of jessica jones on netflix.
New LibreELEC.tv Leia build #0913:
RPi /
RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.13.1 #1 Wed Sep 13 23:57:56 BST 2017 armv6l GNU/Linux
# vcgencmd version
Sep 12 2017 15:25:20
Copyright (c) 2012 Broadcom
version 3fbb171d1950eb3789eb8e37ba11e01079a37239 (clean) (release)
# lsb_release
LibreELEC (Milhouse): devel-20170913235646-#0913-g5e3b9a3 [Build #0913]
# Kodi version
(18.0-ALPHA1 Git:0664d6e). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (5e3b9a3,
changelog) and tip of
XBMC master (0664d6e,
- Includes newclock5 patches
- Excludes the LibreELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.13.y
- Includes latest bcm2835-driver master (2067241, ahead +4)
- Includes latest kodi-platform master (36fb493)
- Includes latest libcec master (8adc786, ahead +26)
- Includes latest libnfs master (3ba2a2c, ahead +101)
- Includes latest p8-platform master (a822e19)
- Includes latest addons: inputstream.adaptive (d417964, +5), inputstream.rtmp (e094fa3), peripheral.joystick (cc14287), pvr.argustv (23cc0e8), pvr.demo (122dedd), pvr.dvblink (816f90c), pvr.dvbviewer (8741c8b), pvr.filmon (34dca04), pvr.hdhomerun (ace19fa), pvr.hts (53118d8), pvr.iptvsimple (ac4f4bd), pvr.mediaportal.tvserver (c86ab35), pvr.mythtv (b46e5be), pvr.nextpvr (a855663), pvr.njoy (99874de), pvr.octonet (a77cf11), pvr.pctv (549f690), pvr.stalker (e15edca), pvr.vbox (b5da811), pvr.vdr.vnsi (f3f80d5, +1), pvr.vuplus (9bfd868), pvr.wmc (7e2cb4b, +1), pvr.zattoo (a24879b)
- Include [env] 22775c5: include crazycat dvb drivers addon in image
- Include [env] compare: kernel-firmware: add ar3k firmware for Asus Chromebook M004U
- Include [env] compare: linux: update to linux-4.13.1
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: libcec: don't link non-existant libtinfo
- Include [env] patch: rev hack for kodi
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, other)
- Include [env] patch: pvr addons: disable broken addons
- Include [env] PR:1776: Don't cause system to hang on halt/reboot when net-booting
- Include [env] PR:1791: nss/nspr: include in main image [rfc]
- Include [env] PR:1835: add support for optional kernel modules in image and from addons
- Include [env] PR:1919: samba: don't restart smbd in samba-autoshare
- Include [env] PR:1965: Python: add patch to use /dev/urandom instead of /dev/random
- Include [pkg] patch: skin.estuary: reduce system info font size (kodi)
- Include [pkg] PR:234: implement intensity compensation for VC-1 decoding for Ivybridge and better (intel-vaapi-driver)
- Include [pkg] PR:260: Fix Seeking with VC1 after 6702b01ee3598017f05374bfc7956493f790361c (intel-vaapi-driver)
- Include [pkg] PR:12767: Partial revert of imdb crashfix due to a introduced bug
Build Highlights:
- New 4.13.1 kernel
- PR:12797: VideoPlayer: make OpenFile asynchron
Build Details:
- LibreELEC.tv:
- init: make break after behaviour really break after (PR:1773, 1 commit, 1 file changed)
- samba: validate samba user config and don't use if legacy or incompatible (PR:1958, 2 commits, 2 files changed)
- XBMC:
- [fix] aml build after pull/12474 (PR:12793, 1 commit, 2 files changed)
- VideoPlayer: bring up busy dialog if opening stream blocks too long (PR:12792, 2 commits, 4 files changed)
- Fix Coverity CIDs 175368 and 175367 (PR:12789, 1 commit, 2 files changed)
- Mark some classes non-copyable + add default constructors (PR:12681, 3 commits, 55 files changed)
- VideoPlayer: fix video freezes (PR:12795, 5 commits, 6 files changed)
- [visualization][fix] last parameter of CVisualization::Start is song title (PR:12796, 1 commit, 1 file changed)
- AE: correct format specifier of log (c9264ea)
- newclock5:
- New commits in this build:
- Revert "omxplayer: Avoid hang when skipping to next video" (d10ebe0e)
- VideoPlayer: make OpenFile asynchron (8ec031f3)
- omxplayer: Avoid hang when skipping to next video (9bdd834d)
- Added: [env] compare: linux: update to linux-4.13.1
The channel switching is weird in the last 2 or 3 builds (after the channel switch the GUI shows up for a second).
If I set pll adjustment to off, audio and video are in sync again with latest build.
(2017-09-14, 02:49)smp1 Wrote: [ -> ]The channel switching is weird in the last 2 or 3 builds (after the channel switch the GUI shows up for a second).
Please be specific if you want issues fixed. Which build was the first with the issue?
(2017-09-14, 12:19)popcornmix Wrote: [ -> ] (2017-09-14, 02:49)smp1 Wrote: [ -> ]The channel switching is weird in the last 2 or 3 builds (after the channel switch the GUI shows up for a second).
Ive noticed with latest build, that switching channels stops playback, same with watching recordings and if you try to switch to another recording, playback also stops.
No crashing..
Regards bucky..
Edit: tried to get logs from a fresh install but couldnt recreate problem, so I guess its something ive done with my main installation, addon or something..
Edit Again: OK i managed to recreate the problem of playback stopping when switching pvr channels or recordings, only does it with omx player..
I've upped some logs of me switching channels, maybe of use....
https://drive.google.com/file/d/0BwAs5Ir...sp=sharing
(2017-09-14, 12:46)bmonster Wrote: [ -> ]Ive noticed with latest build, that switching channels stops playback, same with watching recordings and if you try to switch to another recording, playback also stops.
Again, can you be specific? Are you saying problem affects #0913 and doesn't affect #0912?
(2017-09-14, 15:47)popcornmix Wrote: [ -> ] (2017-09-14, 12:46)bmonster Wrote: [ -> ]Ive noticed with latest build, that switching channels stops playback, same with watching recordings and if you try to switch to another recording, playback also stops.
Sorry, im only seeing this issue with 0913, 0912 is switching ok although a lot slower than 0911..
Kind regards
Bucky
During a switch from one TV channel to another there is a 1-second flash of Kodi's GUI instead of a usual black screen. The first build with the issue is #0912.
Also, any changes to "Audio and subtitle settings" and "Video settings" are not saving. Not sure about the exact build but this started about a month, maybe 1,5 months ago.
Next build should contain another round of channel switch changes. Would be nice to get some feedback.
