(2017-11-09, 21:45)maart84 Wrote: [ -> ]Is there somewhere some explenation on how these builds are made? I've been building my own because I need this libcec fix for my LG tv, but in the regular libreelec git HEVC is not working yet. Is there an easy way for adding that libcec commit in one of these builds?
http://forum.kodi.tv/showthread.php?tid=...pid2092814
These builds use a lot of custom build scripts in order to as much as possible automate the collection of patches from numerous locations into a single build.
If all you want to is build LE master with extra libcec patches then just put the additional patches in the patches folder within the libcec package.
I don't really follow your "libreelec git HEVC is not working" comment - LE master is fairly up to date as far as RPi, ffmpeg and kodi is concerned - updated a week or so ago. Start a new thread in the LibreELEC forum if you are having build issues or stuff isn't working.
New LibreELEC.tv Leia build #1109:
RPi /
RPi2
(Supercedes previous build)
SHA256 Checksum:
a337f5b45a7b525a9961c5592aba530afc75814aba0d2bf397430f72175a01d1 (RPi)
SHA256 Checksum:
48538ad8fd5095a85cecf51ae6391a51be3f1dbfa82b668b70dc9140687cfb24 (RPi2)
# uname -a
Linux rpi512 4.13.11 #1 Thu Nov 9 22:48:35 GMT 2017 armv6l GNU/Linux
# vcgencmd version
Nov 3 2017 17:05:40
Copyright (c) 2012 Broadcom
version 1bcf9152e3b2ab5c67dcb9c7c1f6d9256d9a6f38 (clean) (release)
# lsb_release
LibreELEC (Milhouse): devel-20171109224730-#1109-g1b05386 [Build #1109]
# Kodi version
(18.0-ALPHA1 Git:32924b7). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (1b05386,
changelog) and tip of
XBMC master (32924b7,
- Includes newclock5 patches
- Excludes the LibreELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.13.y
- Includes latest bcm2835-driver master (d9733df, ahead +4)
- Includes latest kodi-platform master (36fb493)
- Includes latest libcec master (8adc786, ahead +26)
- Includes latest libnfs master (7c68a3d, ahead +106)
- Includes latest p8-platform master (a822e19)
- Includes latest addons: inputstream.adaptive (a8ecd4d, +9), inputstream.rtmp (0702f7e), peripheral.joystick (b07d81c, +9), pvr.argustv (23cc0e8), pvr.demo (122dedd), pvr.dvblink (816f90c), pvr.dvbviewer (6129441, +1), pvr.filmon (f67f905), pvr.hdhomerun (7721ce6, +1), pvr.hts (9e58cbb, +9), pvr.iptvsimple (ac4f4bd), pvr.mediaportal.tvserver (fa1069d), pvr.mythtv (d5a6aa3), pvr.nextpvr (5b7caa2), pvr.njoy (cc1cb56), pvr.octonet (f1f8d44), pvr.pctv (eddee4e, +1), pvr.stalker (3b6f231, +1), pvr.teleboy (2d092c4), pvr.vbox (8abcab3, +1), pvr.vdr.vnsi (69ed6ed, +1), pvr.vuplus (eb0d16d), pvr.wmc (55e701b, +1), pvr.zattoo (d5db140, +4)
- Include [env] compare (perma): connman: timeserver: Retry NTP servers periodically on startup
- Include [env] compare (perma): dmidecode: initial package
- Include [env] compare (perma): kodi: add safety mode
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: libcec: don't link non-existant libtinfo
- Include [env] patch: rev hack for kodi
- Include [env] patch: media_build: disable due to conflicts
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, other)
- Include [env] patch: pvr addons: disable broken addons
- Include [env] PR:2002 (perma): linux: include HBR and ELD fixes for Intel
- Include [env] PR:2138 (perma): removed OE mirror links
- Include [env] PR:2144 (perma): Tvheadend 4.2 rework to use ffmpegx
- Include [env] PR:2167 (perma): Fix parsing settings.xml in oe_setup_addon
- Include [env] PR:2172 (perma): llvm: fix output of llvm-config
- Include [env] PR:2182 (perma): kodi: updates for Dec 2017
- Include [env] PR:2183 (perma): giflib: fix reallocarray exception build failure
- Include [env] PR:2196 (perma): ova: bump virtual hw version to 12
- Include [pkg] patch: skin.estuary: reduce system info font size (kodi)
- Include [pkg] PR:86 (perma): connman.py: More secure default password for tethering (service.libreelec.settings)
- Revert [pkg] PR:13007: [depends] fix rbpi toolchain usage (reason: needs newclock5 rebase)
Build Highlights:
- [LE9] samba: fix misleading "file exists" message on login error
Build Details:
- LibreELEC.tv:
- brcmfmac_sdio-firmware-aml: Fix install of binaries (PR:2190, 1 commit, 2 files changed)
- [LE9] samba: fix misleading "file exists" message on login error (PR:2195, 1 commit, 1 file changed)
- [LE9] macmini IR wakeup-from-suspend fixes (PR:2188, 2 commits, 2 files changed)
- mono: update to 5.4.1.6 (PR:2191, 1 commit, 2 files changed)
- touchscreen: fix addon version (PR:2184, 1 commit, 1 file changed)
- XBMC:
- [win32][fix] Fix downloading of dependencies to error out if a package fails (PR:13020, 1 commit, 1 file changed)
- [depends] fix rbpi toolchain usage (PR:13007, 4 commits, 5 files changed)
- [cmake] iconv is a required dependency (PR:11665, 1 commit, 3 files changed)
- RetroPlayer: Fix keyboard input (PR:12996, 4 commits, 5 files changed)
- TexturePacker: exception fix (PR:13015, 3 commits, 7 files changed)
- Sync scrapers (PR:13029, 1 commit, 17 files changed)
- inputstream.adaptive:
- [TTML] postponed subtitle seek / reset subtitles on codec reset (3e98c6e)
- version bump (2.1.7 -> 2.1.8) (a8d5f0b)
- [TTML] add ptsOffset from fragment info (0710667)
- [TTML] ignore namespace on attributes / implement h:m:ms convention (a8ecd4d)
- pvr.zattoo:
- Revert "Allow playing current program from start without recall" (d5db140)
- Updated: [env] PR:2182 (perma): kodi: updates for Dec 2017
- Added: [env] compare (perma): kodi: add safety mode
- Added: [env] PR:2172 (perma): llvm: fix output of llvm-config
- Added: [env] PR:2196 (perma): ova: bump virtual hw version to 12
- Reverted: [pkg] PR:13007: [depends] fix rbpi toolchain usage (reason: needs newclock5 rebase)
The mode from page 1, " Migrating LibreELEC from RPi1 to RPi2, and back again "
didn't work for me.
I've sent the .tar file to the Pi2 update folder, shut down and put the SD card in the Pi1 - nothing happens.
Sending the .tar file to the Pi2 update folder, reboot the pi2 - message after unpacking and md5 checks: Error ... is not compatible with RPI2 arm hardware.
After that the P2 system is restarting as before.
What went wrong?
(2017-11-04, 12:52)MikeKL Wrote: [ -> ]Anyone noticing/having "pausing issue" with iplayer www and live HLS streams?
Using #1102 on rpi2 with an iplayer www livestream, switched on additional Video codec information (ctrl + shift + o) and noted that at time of pauses "Pullup correction pattern length pc:1 change to p:none" is occurring
(all other values looking reasonably consistent to the naive eye)
Since #1108, and inputstream.adaptive fixes it appears that pausing issue I was noticing/having when playing livestreams using iplayer www may be resolved.
Will continue to use addon over weekend and report back if issue still present.
(2017-11-10, 14:45)RappaSan Wrote: [ -> ]The mode from page 1, " Migrating LibreELEC from RPi1 to RPi2, and back again "
didn't work for me.
What went wrong?
Ah yes, the compatibility check was added to LibreELEC after I wrote those instructions.
When you intentionally want to upgrade an RPi2 with the RPi1 tar file, you'll need to create the "nocompat" flag file - this will require ssh:
touch /storage/.update/.nocompat
then copy the RPi1 tar file into the Update (or .update) folder on the RPi2, and then reboot.
The RPi2 will upgrade to the RPi1 firmware, and when it reboots after the upgrade you should see the "rainbow splash" (as you are now booting the RPi2 with RPi1 firmware). I'll update the note in the first post, thanks.
I have bug, after I watch movie (fully) in play list sometimes show icon "watched", but sometimes no. I tested a couple times, let player to complete play movie, but sometimes show correct, sometimes no. Where can be a problem?
Mh, I am trying to get Netflix Addon to run. But always terminates when trying to start a video.
Can u give me a hint? Here is the log:
http://sprunge.us/ZeWS
New LibreELEC.tv Leia build #1110:
RPi /
RPi2
SHA256 Checksum:
385cd78cea3d27311e7cd3875c79e58dfbe40703f37287f72cea1b119f9b28f1 (RPi)
SHA256 Checksum:
2136722c12f009aec63569794213636ec25542f70177486959935fa0615c4303 (RPi2)
# uname -a
Linux rpi512 4.13.12 #1 Fri Nov 10 21:13:14 GMT 2017 armv6l GNU/Linux
# vcgencmd version
Nov 3 2017 17:05:40
# lsb_release
LibreELEC (Milhouse): devel-20171110210354-#1110-g9364279 [Build #1110]
# Kodi version
(18.0-ALPHA1 Git:9677276). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (9364279,
XBMC master (9677276,
- Includes latest bcm2835-driver master (008700b)
- Includes latest addons: inputstream.adaptive (d2081b2, +5), inputstream.rtmp (0702f7e), peripheral.joystick (b07d81c, +9), pvr.argustv (23cc0e8), pvr.demo (122dedd), pvr.dvblink (816f90c), pvr.dvbviewer (6129441, +1), pvr.filmon (f67f905), pvr.hdhomerun (7721ce6, +1), pvr.hts (9e58cbb, +9), pvr.iptvsimple (ac4f4bd), pvr.mediaportal.tvserver (fa1069d), pvr.mythtv (d5a6aa3), pvr.nextpvr (5b7caa2), pvr.njoy (cc1cb56), pvr.octonet (f1f8d44), pvr.pctv (eddee4e, +1), pvr.stalker (3b6f231, +1), pvr.teleboy (2d092c4), pvr.vbox (8abcab3, +1), pvr.vdr.vnsi (69ed6ed, +1), pvr.vuplus (eb0d16d), pvr.wmc (55e701b, +1), pvr.zattoo (d5db140, +4)
- Include [env] PR:2198 (perma): linux: update to linux-4.13.12
Build Highlights:
- New 4.13.12 kernel
Build Details:
- LibreELEC.tv:
- llvm: fix output of llvm-config (PR:2172, 2 commits, 1 file changed)
- XBMC:
- Fix missing add-on description for repo add-ons (PR:13021, 2 commits, 1 file changed)
- Controller dialog: Fix race condition when stopping/starting button mapping (PR:13027, 1 commit, 1 file changed)
- Pictures: fix video in slideshow (PR:13031, 1 commit, 1 file changed)
- [TTML] Fix subtitles / Hack HBO / Version bump ->2.1.8 (d2081b2)
- newclock5:
- New commits in this build:
- giflib: don't export reallocarray function (6ada11f5)
- Commits no longer in build:
- [build] Remove optimisation flags (5f04cfb2)
- Added: [env] PR:2198 (perma): linux: update to linux-4.13.12
I updatet yesterday to the latest Release and found, that I can no longer enter the local file browser for R0Ms. I guess the corresponding change is this:
https://github.com/xbmc/xbmc/pull/12909
I set the Folders before, but I guess games are not integrated (as are movies and tv shows) yet, due to the missing (?) game scraper.
@garbear: Is there any other way then to remove all game addons to still access the local R0Ms to start retro-gaming?
(2017-11-11, 15:09)linkinsoldier Wrote: [ -> ]I updatet yesterday to the latest Release and found, that I can no longer enter the local file browser for R0Ms. I guess the corresponding change is this:
Yes, clicking on "Games" should have the same effect as the missing "Enter files section" button
Thank you, that worked... Should have thought of that, sorry...
Any idea of a scrapper for games similar to movies will be in kodi 18?
(2017-11-11, 20:42)linkinsoldier Wrote: [ -> ]Any idea of a scrapper for games similar to movies will be in kodi 18?
Nope. A scraper is useless if you don't have a database to scrape into. And we don't have a game database. Kodi's database code is in really bad shape. Work is in progress to replace this (see the
feature_odb feature branch) but this won't make it into v18.
