Hej Guys,
it give bad news for me with the Image #308 and the Tvheadend package #308.
My IP TV with Tvheadend will not work anymore...
When i tune a chanel on kodi i get a black screen
2018-03-09 21:23:27.860 mpegts: ZDF HD in Entertain - tuning on IPTV
2018-03-09 21:23:27.861 subscription: 0008: "127.0.0.1 [ | Kodi Media Center ]" subscribing on channel "ZDF", weight: 100, adapter: "IPTV", network: "Entertain", mux: "ZDF HD", service: "ZDF HD", profile="htsp", hostname="127.0.0.1", username="127.0.0.1", client="Kodi Media Center"
2018-03-09 21:23:27.866 mpegts: NDR HD in Entertain - tuning on IPTV
2018-03-09 21:23:27.867 subscription: 0009: "127.0.0.1 [ | Kodi Media Center ]" subscribing on channel "NDR HD", weight: 40, adapter: "IPTV", network: "Entertain", mux: "NDR HD", service: "NDR HD", profile="htsp", hostname="127.0.0.1", username="127.0.0.1", client="Kodi Media Center"
2018-03-09 21:23:39.341 subscription: 0009: "127.0.0.1 [ | Kodi Media Center ]" unsubscribing from "NDR HD", hostname="127.0.0.1", username="127.0.0.1", client="Kodi Media Center"
2018-03-09 21:23:53.344 subscription: 0008: service instance is bad, reason: No input detected
2018-03-09 21:23:55.344 subscription: 0008: No input source available for subscription "127.0.0.1 [ | Kodi Media Center ]" to channel "ZDF"
2018-03-09 21:23:57.344 subscription: 0008: No input source available for subscription "127.0.0.1 [ | Kodi Media Center ]" to channel "ZDF"
2018-03-09 21:23:57.346 subscription: 0008: "127.0.0.1 [ | Kodi Media Center ]" unsubscribing from "ZDF", hostname="127.0.0.1", username="127.0.0.1", client="Kodi Media Center"
When i go to the Webinterface from tvheadend and order a rescan for a chanel:
2018-03-09 21:22:06.316 mpegts: DasErste in Entertain - tuning on IPTV
2018-03-09 21:22:06.318 subscription: 0007: "scan" subscribing to mux "DasErste", weight: 6, adapter: "IPTV", network: "Entertain", service: "Raw PID Subscription"
2018-03-09 21:22:31.316 mpegts: DasErste in Entertain - scan no data, failed
2018-03-09 21:22:31.316 subscription: 0007: "scan" unsubscribing
(2018-03-09, 22:28)fritz_hh Wrote: [ -> ]Hej Guys,
You mean it worked fine with #0307, and has stopped working with #0308?
(2018-03-09, 21:37)popcornmix Wrote: [ -> ]@J_E_F_F Does it only crash with HEVC? Is HEVC 10-bit?
I only play hevc content, this is 8 bit
General
Unique ID : 205546229452379980289212721123395720337 (0x9AA2C38A16D0D9AD9386640A839D5491)
Complete name : \Blindspot S03E13.mkv
Format : Matroska
Format version : Version 4 / Version 2
File size : 199 MiB
Duration : 43mn 3s
Overall bit rate : 646 Kbps
Movie name : Blindspot S03E13
Encoded date : UTC 2018-03-03 18:52:53
Writing application : mkvmerge v21.0.0 64-bit
Writing library : libebml v1.3.5 + libmatroska v1.4.8
Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : [email protected]@Main
Codec ID : V_MPEGH/ISO/HEVC
Duration : 43mn 3s
Bit rate : 572 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.026
Stream size : 176 MiB (89%)
Default : Yes
Forced : No
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : HE-AAC / LC
Codec ID : A_AAC
Duration : 43mn 2s
Bit rate : 72.0 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz / 24.0 KHz
Frame rate : 23.438 fps (1024 spf)
Compression mode : Lossy
Delay relative to video : 23ms
Stream size : 22.1 MiB (11%)
Default : Yes
Forced : No
Text
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Duration : 42mn 55s
Bit rate : 100 bps
Count of elements : 1068
Stream size : 31.6 KiB (0%)
Default : Yes
Forced : No
(2018-03-09, 22:49)Milhouse Wrote: [ -> ] (2018-03-09, 22:28)fritz_hh Wrote: [ -> ]Hej Guys,
I have not installed #307 it was to fast the updates in the past...
My last wars #302
When i go back to LibreElec 8.2.3 it will be work fine, so i have uppt the #228 package but now i have the same problem!?
New LibreELEC.tv Leia build #0309:
RPi /
RPi2
(Supercedes previous build)
SHA256 Checksum:
d5540c8c4fc504b8ee353bc74706c61dae2af64d1a56adbf7a6d4764558e5cc3
(RPi)
SHA256 Checksum:
5ca60e1ee67708b9057bc5f6f5678f4d90aaed91aed70f4b6bc4aa417261340c
(RPi2)
text:
# uname -a
Linux rpi512 4.14.24 #1 Fri Mar 9 21:08:36 GMT 2018 armv6l GNU/Linux
# vcgencmd version
Mar 9 2018 20:00:26
Copyright © 2012 Broadcom
version a113099ad5cf63c7ce12c4f579655b258ba33ebe (clean) (release)
# lsb_release
LibreELEC (Milhouse): devel-20180309210542-#0309-g320fe14 [Build #0309]
# Kodi version
(18.0-ALPHA2 Git:89a53e4). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (320fe14,
changelog) and tip of
XBMC master (ce030f8,
- Includes newclock5 patches
- Includes latest commits from kernel branch rpi-4.14.y
- Includes latest bcm2835-driver master (6e3c5f8, ahead +2)
- Includes latest kodi-platform master (e8574b8)
- Includes latest libcec master (8adc786, ahead +26)
- Includes latest libnfs master (54405d9, ahead +120)
- Includes latest p8-platform master (a822e19)
- Includes latest addons: inputstream.adaptive (242828c, +3), inputstream.rtmp (9c398d9, +2), peripheral.joystick (d68e78c, +2), pvr.argustv (a4d3ec7), pvr.demo (8f62053), pvr.dvblink (89d1687), pvr.dvbviewer (64c4356), pvr.filmon (2721611), pvr.hdhomerun (7379fbc), pvr.hts (095784b), pvr.iptvsimple (933a5c4), pvr.mediaportal.tvserver (dec444f), pvr.mythtv (85c33c4, +1), pvr.nextpvr (aa1c8d2), pvr.njoy (67b837d), pvr.octonet (689afbf), pvr.pctv (5b47d9f), pvr.stalker (77eec69), pvr.teleboy (3ae0297), pvr.vbox (57f3198), pvr.vdr.vnsi (4db947c), pvr.vuplus (f05f158), pvr.wmc (38e670a), pvr.zattoo (3c46173), vfs.libarchive (e74a3ab, +2)
- Exclude [env] kodi-0100-temp-add-pr13594.patch: merged upstream
- Include [env] compare (perma): dmidecode: initial package
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: libcec: fix PR390
- Include [env] patch: libcec: don't link non-existant libtinfo
- Include [env] patch: rev hack for kodi
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, other)
- Include [env] PR:2511 (perma): kernel-firmware: use project specific firmwares and cleanup
- Include [env] PR:2521 (perma): buildsystem: add BUILD_FLAG support
- Include [env] PR:2529 (perma): buildsystem: support get handlers (archive, file, git)
- Include [env] PR:2533 (perma): graphics package updates
- Include [env] PR:2536 (perma): kodi: libinput fixes
- Include [env] PR:2565 (perma): kodi: mid-March update
- Include [env] PR:2566 (perma): linux: switch to Raspberry Pi vendor kernel
- Include [pkg] patch: skin.estuary: reduce system info font size (kodi)
- Include [pkg] PR:97 (perma): iptables: Fix "off" setting (service.libreelec.settings)
- Include [pkg] PR:13176 (perma): [RFC] [Linux] add libinput backend for non window system platforms
- Include [pkg] PR:13274 (perma): Mode whitelist
Build Highlights:
- New firmware (limit sdram voltage, increase vcsm limit)
- Kodi 18.0a2
- Fix "firewall off" setting
Build Details:
- Firmware (Mar 9):
- firmware: Rebuild from correct tree
- firmware: platform: Should limit sdram voltage when turbo is throttled
- firmware: video_decode: Allow setting the output format twice
- firmware: vmcs: Increase service limit for vcsm to 2
- LibreELEC.tv:
- distro-tool: fixup after server migration (PR:2568, 1 commit, 1 file changed)
- Snapcast (PR:2551, 8 commits, 26 files changed)
- XBMC:
- VideoPlayer / pvr: set playing times to zero when opening a new file (PR:13630, 2 commits, 2 files changed)
- bump to v18 alpha2 (PR:13632, 1 commit, 1 file changed)
- inputstream.adaptive:
- Allow #EXT-X-KEY:METHOD:NONE (issue 105 / 120) (9089703)
- Don't expose invalid streams (codec) (242828c)
- vfs.libarchive:
- [windows] fix building for UWP with Visual Studio (PR:15, 1 commit, 4 files changed)
- add uwp builds on appveyor (d35bdd1)
- Updated: [env] PR:2566 (perma): linux: switch to Raspberry Pi vendor kernel
- Added: [pkg] PR:97 (perma): iptables: Fix "off" setting (service.libreelec.settings)
x264 seems to play fine even with everything overclocked.
Hi
I'm using a wired rpi3. With build 0307 I tried several times to get an IP. Tried Firmware downgrade with no success. Build 0306 was OK an now build 0308 is also working again as expected.
(2018-03-09, 21:07)Milhouse Wrote: [ -> ] (2018-03-09, 17:00)MidKnight Wrote: [ -> ]Using a logitech elite remote, the long press on the enter key used to bring up the context menu, but at some point past,
LibreELEC-RPi2.arm-9.0-Milhouse-20180218010737-#0217-gc2fd843
till the lastest release i just tried, it no longer working, but insteads just fires enter cmd untill button released.
how can i change this back?
thanks
Most likely the libinput change in #0302 - see if #0301 works. This is still something we're trying to work out a fix for.
thanks mate, #301 works fine, so ill have to sit at this build until fixed.
popcornmix I'm chiming in here. About HEVC 10 bit and crashes.
I do have a lot of content in HEVC 10bit that I try to play using my RPi3 (not overclocked)
Nearly all of them end in a blank screen, audio for a couple of seconds and then it crashes (splash screen)
The oddest thing is that I have an early January OSMC Leia build (That always is behind LibreELEC) in commits and such on a
RPi2 and it plays everything I throw at it (HEVC 10bit)
Certainly, RPi 3 should be doing a better job software decoding HEVC 10bit than RPi 2
Regarding HEVC 8bit. LibreELEC plays effortlessly. With a lower CPU usage.
Hope that helps.
Hi together,
since the recent 6 to 8 testbuilds the mouse cursor is not working perfect.
It is difficult to sroll in a large folder (and to select).
The scrollbar in a video or audio moves immediately if a move the mouse.
Also the Logitech k400 (touch) would not work satisfactory.
Thanks @ milhouse und popcornmix
Harald
@hbbs- I think the issue you indicated started between 0126 and the 0127 builds. It seems the video play back issues in my system all started there.
Hello Milhouse,
today i look like a owl with realy smokie eyes *rofl* the night was really short but i must get up to check witch build makes trouble :-D
So i have mak a complet new set up from LibreElec 8.23 and start with your Build #302 that works fine allso the Build #303.
But with #304 comes the trouble again, iptv will doesen't work
I hope that can help to find the cause.
A general Problem with LE 9 is that it will not accept blank fields in the Addon Settings / Configuration.
So it can give a download loop with WebGrabb ++ but he have a trigger for "on-activ", so it's start every reboot the job.
I have try to set the value "0" but that do start the download directly after a reboot so now i have set to "360000" seconds.
I have seen that you also work on a build for the Odroid C2 from witch general LE Image can i start?
Also the Inputstreams with amazon will work?
(2018-03-09, 19:56)lrusak Wrote: [ -> ]@doug try stoping kodi first
Okay, now there are events recorded...
Kodi-FR:~ # libinput-list-devices
Device: flirc.tv flirc
Kernel: /dev/input/event0
Group: 1
Seat: seat0, default
Capabilities: keyboard
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: n/a
Nat.scrolling: n/a
Middle emulation: n/a
Calibration: n/a
Scroll methods: none
Click methods: none
Disable-w-typing: n/a
Accel profiles: n/a
Rotation: n/a
Here is the Enter key with a normal press and then a long press.
Kodi-FR:~/.update # libinput-debug-events --device /dev/input/event0
-event0 DEVICE_ADDED flirc.tv flirc seat0 default group1 cap:kp scroll-nat
event0 KEYBOARD_KEY +2.11s *** (-1) pressed
event0 KEYBOARD_KEY +2.30s *** (-1) released
event0 KEYBOARD_KEY +3.14s *** (-1) pressed
event0 KEYBOARD_KEY +4.83s *** (-1) released
I didn't include them above, but there are several keypresses (skip back, skip forward, ffd, rwd, stop, menu/guide, back ) that generate the exact same generic "*** (-1)" event output. Other keys generate unique events such as "KEY_UP (103)". My keys that generate unique events include, up, down, left right, play/pause, ctrl-F11, ctrl-F12.
Edit: the ctrl-F11 and ctrl-F12 are odd. They generate:
event0 KEYBOARD_KEY +722.88s *** (-1) pressed
event0 KEYBOARD_KEY +722.88s KEY_F11 (87) pressed
event0 KEYBOARD_KEY +723.07s *** (-1) released
event0 KEYBOARD_KEY +723.07s KEY_F11 (87) released
So it appears the ctrl isn't uniquely identified. I use the ctrl-XX kepresses with python scripts to change inputs, power on/off, etc. The scripts still run fine with the libinput changes.
New LibreELEC.tv Leia build #0310:
RPi /
RPi2
SHA256 Checksum:
ea6ff45809b83a115fa47428883135dd3d489216b0c73ae77b990a476dac1e23
(RPi)
SHA256 Checksum:
2e14d9e4a90ec220ac51fb8ee256f3bac75f509774d1fb4ac2a2529a3d5dee0a
(RPi2)
text:
# uname -a
Linux rpi512 4.14.24 #1 Sat Mar 10 23:29:07 GMT 2018 armv6l GNU/Linux
# vcgencmd version
Mar 9 2018 20:00:26
# lsb_release
LibreELEC (Milhouse): devel-20180310232723-#0310-g36e6b0d [Build #0310]
# Kodi version
Based on tip of
LibreELEC.tv master (36e6b0d,
XBMC master (872c850,
- Includes latest addons: inputstream.adaptive (7cad17d, +4), inputstream.rtmp (9c398d9, +2), peripheral.joystick (d68e78c, +2), pvr.argustv (a4d3ec7), pvr.demo (8f62053), pvr.dvblink (89d1687), pvr.dvbviewer (64c4356), pvr.filmon (2721611), pvr.hdhomerun (7379fbc), pvr.hts (095784b), pvr.iptvsimple (933a5c4), pvr.mediaportal.tvserver (dec444f), pvr.mythtv (85c33c4, +1), pvr.nextpvr (aa1c8d2), pvr.njoy (67b837d), pvr.octonet (689afbf), pvr.pctv (5b47d9f), pvr.stalker (77eec69), pvr.teleboy (3ae0297), pvr.vbox (57f3198), pvr.vdr.vnsi (4db947c), pvr.vuplus (f05f158), pvr.wmc (38e670a), pvr.zattoo (3c46173), vfs.libarchive (e74a3ab, +2)
- Include [pkg] PR:13631 (perma): GUIInfoManager: revert 8809df940d265f79e3d529b6591a2c8333ed06d6, this reverts #8766
Build Highlights:
- Revert change that leads to crash at end of playback
Build Details:
- LibreELEC.tv:
- linux: build perf on all kernels except amlogic-3.x (PR:2561, 1 commit, 1 file changed)
- XBMC:
- [wayland] Add and use dummy OS screen saver implementation (PR:13623, 1 commit, 2 files changed)
- Fix crash on exit (PR:13628, 2 commits, 5 files changed)
- Added: [pkg] PR:13631 (perma): GUIInfoManager: revert 8809df940d265f79e3d529b6591a2c8333ed06d6, this reverts #8766
I upgraded from #0308 to #0310 and it looks like channel zapping with VDR VSNI is litte more fast
