Weekly Linux 5.0 build #0306x:
RPi /
RPi2
Known issues:
text:
No dvb-latest or crazycat drivers
Milhouse
I'm running LibreElec Kodi Leia on Raspi2. Since version #304 (#305, #306) it takes a long time to boot, the time between the LibreElec splash screen and the Kodi splash screen is around 90 sec. Before (until version #303) it took only seconds so I downgraded to this version.
How can I reduce the boot time on newer versions?
Thanx for your support,
oliaros
New LibreELEC.tv Leia build #0307:
RPi /
RPi2
(Supercedes previous build)
SHA256 Checksum:
c1025c216fb77b47dc2524796f33264dbfba9667bba4708478ce6c708a5d92b4
(RPi)
SHA256 Checksum:
e9c7e3cc62524897f5564c08c01757ecd26ef0b2d2377ae69526ca7ba4aeab83
(RPi2)
text:
# uname -a
Linux rpi512 4.19.27 #1 Thu Mar 7 23:44:47 GMT 2019 armv6l GNU/Linux
# vcgencmd version
Feb 22 2019 18:10:04
Copyright © 2012 Broadcom
version c32b049542c0da4e13087d1043bbfa6c50b242f3 (clean) (release) (start_x)
# lsb_release
LibreELEC (Milhouse): devel-20190307234337-#0307-gfa3c855 [Build #0307]
# Kodi version
Kodi (18.2-RC1 Git:089d357). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (fa3c855,
changelog) and tip of
XBMC master (089d357,
- Includes newclock5 patches
- Includes latest commits from kernel branch rpi-4.19.y
- Includes latest bcm2835-driver master (f84820e, ahead +1)
- Includes latest kodi-platform master (e8574b8)
- Includes latest libcec master (3bbd432)
- Includes latest libnfs master (0308145)
- Includes latest p8-platform master (1eb12b1)
- Includes latest addons: inputstream.adaptive (b76c81f), inputstream.rtmp (ce68b77, +1), peripheral.joystick (6b2a4dd, +5), peripheral.xarcade (d218f0d, +2), pvr.argustv (83aa1e9), pvr.demo (964686d), pvr.dvblink (ecc9cfd, +4), pvr.dvbviewer (c2c1beb, +2), pvr.filmon (e850633), pvr.hdhomerun (a9d7309), pvr.hts (8dcd62d, +3), pvr.iptvsimple (73feb2f), pvr.mediaportal.tvserver (931afab), pvr.mythtv (c954c7e), pvr.nextpvr (78c6633), pvr.njoy (4467cac), pvr.octonet (203f800), pvr.pctv (b60b971), pvr.stalker (d0170c5), pvr.teleboy (1956113), pvr.vbox (ea20464), pvr.vdr.vnsi (cbb75ab), pvr.vuplus (97c67ae, +23), pvr.wmc (7b28be3), pvr.zattoo (30868ce), vfs.libarchive (2ba1102), vfs.rar (b66c6df, +1), vfs.sftp (ab0dc82, +1)
- Include [env] compare (perma): TESTING: increase timeout to ensure OS is able to create core dump/crash log
- Include [env] compare (perma): kodi: fix patch
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: kodi: use upstream repo for Milhouse RPi builds
- Include [env] patch: kodi: remove annoying, excessively repetitive addon logging
- Include [env] patch: rev hack for kodi
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, peripheral.joystick/xarcade, other)
- Include [env] PR:2471 (perma): openssl: update to 1.1.1b
- Include [env] PR:3238 (perma): kodi/openssl: fix crash using vfs.sftp
- Include [env] PR:3324 (perma): linux (RPi/Generic): update to linux-4.19.27
- Include [env] PR:3336 (perma): gcc: update to gcc-8.3.0
- Include [env] PR:3356 (perma): brcmfmac_sdio-firmware-rpi: fix delay on non-wifi enabled devices
- Include [env] PR:3357 (perma): Add nghttp2 support
- Include [pkg] 983cf7a2: Sets the BCDC priority to constant 0 (linux)
- Include [pkg] patch: kodi: fix addon platform_tag (kodi)
- Include [pkg] PR:14571 (perma): Remove ARB postfix from GL functions
- Include [pkg] PR:15164 (perma): TexturePacker: Fix memory / resource leak the ugly way
- Include [pkg] PR:15356 (perma): Optimize locking in ApplicationMessenger
- Include [pkg] PR:15644 (perma): [curl] Accept all supported content encodings by default
Build Highlights:
- brcmfmac_sdio-firmware-rpi: fix delay on non-wifi enabled devices
- [PVR] Speedup close of Guide window
- [videoplayer][pvr] Use audio stream to determine start time of programs with no video
- video: bcm2708_fb: Try allocating on the ARM and passing to VPU
Build Details:
- LibreELEC.tv:
- openssh: drop support for ssh-dss keys (PR:3316, 1 commit, 1 file changed)
- Packages: Miscellaneous package bumps to new minor versions (PR:3349, 11 commits, 11 files changed)
- [RFC] add safe_remove to notify if a file doesn't exist (PR:3329, 2 commits, 2 files changed)
- brcmfmac_sdio-firmware-rpi: fix race between service and /dev/serial1 (PR:3354, 1 commit, 1 file changed)
- packages/{x11,print,devel}: bump packages (PR:3348, 16 commits, 17 files changed)
- xf86-video-nvidia: update to xf86-video-nvidia-410.104 (PR:3334, 1 commit, 1 file changed)
- scripts/build: fix broken sym link after #3328 (PR:3342, 7 commits, 7 files changed)
- config/options: ban spaces in paths (PR:3351, 1 commit, 1 file changed)
- XBMC:
- [PVR] Speedup close of Guide window. (PR:15683, 1 commit, 1 file changed)
- [PVR] Fixes for broken timer handling (PR:15689, 3 commits, 3 files changed)
- [videoplayer][pvr] Use audio stream to determine start time of programs with no video (PR:15596, 1 commit, 1 file changed)
- kernel 4.19.y:
- New commits in this build:
- video: bcm2708_fb: Try allocating on the ARM and passing to VPU (c0e09b34)
- Updated: [env] PR:2471 (perma): openssl: update to 1.1.1b
- Added: [env] PR:3356 (perma): brcmfmac_sdio-firmware-rpi: fix delay on non-wifi enabled devices
- Updated: [env] PR:3357 (perma): Add nghttp2 support
The latest 5.0 release isn't available? 404 not found
(2019-03-08, 19:47)Smultie Wrote: [ -> ]The latest 5.0 release isn't available? 404 not found
Sorry about that, should be there now!
New LibreELEC.tv Leia build #0308:
RPi /
RPi2
SHA256 Checksum:
5423a6b6a440678ec146fedd5c3beae6c5dbb425fb7e8352e4ab4e0a734a7e7f
(RPi)
SHA256 Checksum:
c5f980dcef503c085e560514712620c211ce944a84f2ba9f94f7f9c4854b6460
(RPi2)
text:
# uname -a
Linux rpi512 4.19.27 #1 Fri Mar 8 21:04:47 GMT 2019 armv6l GNU/Linux
# vcgencmd version
Mar 6 2019 14:47:17
version b403ee6ed819f9ac7a96834ac437b6cfdd4512ad (clean) (release) (start_x)
# lsb_release
LibreELEC (Milhouse): devel-20190308210338-#0308-g955c01b [Build #0308]
# Kodi version
Kodi (18.2-RC1 Git:386045c). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (955c01b,
XBMC master (386045c,
- Includes latest bcm2835-driver master (fd15e07, ahead +2)
Build Highlights:
- New firmware
- [PVR] Guide window: Fix gap tags information.
- staging: vc_sm_cma: Remove erroneous misc_deregister
Build Details:
- Firmware (Mar 6):
- firmware: raspivid: Stop --raw option resetting --raw-format to YUV. See: link
- firmware: Fixed up overflow in microsecond timer. See: link
- LibreELEC.tv:
- openssl: update to 1.1.1+ (PR:2471, 7 commits, 7 files changed)
- XBMC:
- [PVR] Guide window: Fix gap tags information. (PR:15697, 2 commits, 5 files changed)
- kernel 4.19.y:
- staging: vc_sm_cma: Remove erroneous misc_deregister (089ae6dd)
Hi Milhosue,
since 302 version, tvheadend stopped working with next error:
Quote:error while loading shared libraries: libssl.so.1.0.0
I'm using CvH tvheadnend latest version.
regards
(2019-03-09, 04:50)were55 Wrote: [ -> ]Hi Milhosue,
regards
You need to use my version with updated openssl or wait until cvh updates his version (the openssl bump merged last night so shouldn't be long).
New LibreELEC.tv Leia build #0309:
RPi /
RPi2
SHA256 Checksum:
23409de8608bcedad28662979203f60ee6ed105e9a543638ef0bb88d377feb06
(RPi)
SHA256 Checksum:
69964b594540564420dcabc16d95bf1175fd63ce0cc06fd45a294ea3cc9de3d5
(RPi2)
text:
# uname -a
Linux rpi512 4.19.27 #1 Sat Mar 9 22:19:59 GMT 2019 armv6l GNU/Linux
# vcgencmd version
Mar 6 2019 14:47:17
# lsb_release
LibreELEC (Milhouse): devel-20190309221243-#0309-ge738c7b [Build #0309]
# Kodi version
Kodi (18.2-RC1 Git:1eb3bdb). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (e738c7b,
XBMC master (1eb3bdb,
- Includes latest bcm2835-driver master (fd15e07)
- Includes latest addons: inputstream.adaptive (b76c81f), inputstream.rtmp (ce68b77, +1), peripheral.joystick (6b2a4dd, +5), peripheral.xarcade (d218f0d, +2), pvr.argustv (83aa1e9), pvr.demo (964686d), pvr.dvblink (ecc9cfd, +4), pvr.dvbviewer (c2c1beb, +2), pvr.filmon (e850633), pvr.hdhomerun (a9d7309), pvr.hts (8dcd62d, +3), pvr.iptvsimple (73feb2f), pvr.mediaportal.tvserver (931afab), pvr.mythtv (c954c7e), pvr.nextpvr (edc0741, +10), pvr.njoy (4467cac), pvr.octonet (203f800), pvr.pctv (b60b971), pvr.stalker (d0170c5), pvr.teleboy (1956113), pvr.vbox (ea20464), pvr.vdr.vnsi (cbb75ab), pvr.vuplus (97c67ae, +23), pvr.wmc (7b28be3), pvr.zattoo (30868ce), vfs.libarchive (2ba1102), vfs.rar (b66c6df, +1), vfs.sftp (ab0dc82, +1)
- Include [env] PR:3358 (perma): Python2: don't install 2to3, clashes with Python3 equivalent
Build Highlights:
- [Music]Fix listing scraped artist art when choose art on Artist Info dialog
- Fix localised "various arists" missing from some artist lists
Build Details:
- LibreELEC.tv:
- gcc: update to gcc-8.3.0 (PR:3336, 4 commits, 4 files changed)
- XBMC:
- [Music]Fix listing scraped artist art when choose art on Artist Info dialog (PR:15701, 1 commit, 1 file changed)
- Fix localised "various arists" missing from some artist lists (PR:15657, 1 commit, 1 file changed)
- [Estouchy] fix missing weather temps (PR:15685, 1 commit, 1 file changed)
- pvr.nextpvr:
- Add extended timeshift and several fixes (PR:87, 14 commits, 18 files changed)
- Updated: [env] PR:3324 (perma): linux (RPi/Generic): update to linux-4.19.27
- Added: [env] PR:3358 (perma): Python2: don't install 2to3, clashes with Python3 equivalent
Hey, just experienced a crash right after updating the widevine library:
http://ix.io/1D6o
I saw the "success" notify, then crashed when the series started.
Hi there,
- if im trying to play some high-quality .mkv-videos via UPnP Media Server (Universal Media Server) from my PC
or
Kodi/LibreElec/Raspberry crashes without a message --> Immediate black screen followed by reboot
If i had to guess i think its only happening with big video-files or with high-res-videos ...
Logging-files:
Via UPnP:
Last comments in Crash-Log before reboot:
Quote:2019-03-10 16:01:57.308 T:1478296432 DEBUG: CDVDDemuxFFmpeg::AddStream ID: 0 2019-03-10 16:01:57.308 T:1478296432 DEBUG: CDVDDemuxFFmpeg::AddStream ID: 1 2019-03-10 16:01:57.308 T:1478296432 DEBUG: CDVDDemuxFFmpeg::AddStream ID: 2 2019-03-10 16:01:57.308 T:1478296432 DEBUG: CDVDDemuxFFmpeg::AddStream ID: 3 2019-03-10 16:01:57.308 T:1478296432 DEBUG: CDVDDemuxFFmpeg::AddStream ID: 4 2019-03-10 16:01:57.308 T:1478296432 DEBUG: CDVDDemuxFFmpeg::AddStream ID: 5 2019-03-10 16:01:57.308 T:1478296432 DEBUG: CDVDDemuxFFmpeg::AddStream ID: 6 2019-03-10 16:01:57.308 T:1478296432 DEBUG: CDVDDemuxFFmpeg::AddStream ID: 7 2019-03-10 16:01:57.308 T:1478296432 DEBUG: CDVDDemuxFFmpeg::AddStream ID: 8 2019-03-10 16:01:57.308 T:1478296432 DEBUG: CDVDDemuxFFmpeg::AddStream ID: 9 2019-03-10 16:01:57.309 T:1478296432 NOTICE: Opening stream: 0 source: 256 2019-03-10 16:01:57.309 T:1478296432 NOTICE: Creating video codec with codec id: 173 2019-03-10 16:01:57.310 T:1478296432 ERROR: CMMALVideo::Open : Video codec unknown: ad
2019-03-10 16:01:57.310 T:1478296432 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: HEVC (rpi)
2019-03-10 16:01:57.310 T:1478296432 DEBUG: CDVDVideoCodecFFmpeg - open frame threaded with 8 threads
From USB-Stick:
Same behaviour and (i think) same logging-information --> Crash
Thanks a lot for the good work and hopefully you can fix the issue!
I am using kodi with an old TV using composite out. Starting after 9.0 #1030 there was an issue that video calibratrion settings were not saved (they were lost after a reboot).
There was a discussion in the forum:
https://forum.libreelec.tv/thread/14028-...ersistent/
Github issue #15165 discussed it further:
https://github.com/xbmc/xbmc/issues/15165
User peak3d seemd to solve it in PR #15516:
https://github.com/xbmc/xbmc/pull/15516
According to a user in the last link the issue was fixed in a kodi nightly from Feb. 19th. However, I tried LE #0309 today and the issue is still present. Is PR #15516 integrated into this buiild? This bug annoys me as hell ...
Best wishes
kdre
