New LibreELEC.tv Leia build #0302:
RPi /
RPi2
(Supercedes previous build)
SHA256 Checksum:
30d2fb1c4a399ac8ab0ca204d34adf5bfbf097566d63786244653ba31925ac73
(RPi)
SHA256 Checksum:
c6a516669ea919c897eddebaff0be59511dd4b29a25afef6c4922b93ff74f0a0
(RPi2)
text:
# uname -a
Linux rpi512 4.19.25 #1 Sun Mar 3 04:54:46 GMT 2019 armv6l GNU/Linux
# vcgencmd version
Feb 22 2019 18:10:04
Copyright © 2012 Broadcom
version c32b049542c0da4e13087d1043bbfa6c50b242f3 (clean) (release) (start_x)
# lsb_release
LibreELEC (Milhouse): devel-20190303045138-#0302-g0111c1d [Build #0302]
# Kodi version
Kodi (18.2-RC1 Git:f43abaf). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (0111c1d,
changelog) and tip of
XBMC master (f43abaf,
- Includes newclock5 patches
- Includes latest commits from kernel branch rpi-4.19.y
- Includes latest bcm2835-driver master (f84820e, ahead +1)
- Includes latest kodi-platform master (e8574b8)
- Includes latest libcec master (3bbd432)
- Includes latest libnfs master (0308145)
- Includes latest p8-platform master (1eb12b1)
- Includes latest addons: inputstream.adaptive (b76c81f), inputstream.rtmp (ce68b77, +1), peripheral.joystick (6b2a4dd, +5), peripheral.xarcade (d218f0d, +2), pvr.argustv (83aa1e9), pvr.demo (964686d), pvr.dvblink (b636726, +2), pvr.dvbviewer (c2c1beb, +2), pvr.filmon (e850633), pvr.hdhomerun (a9d7309), pvr.hts (8dcd62d, +3), pvr.iptvsimple (73feb2f), pvr.mediaportal.tvserver (931afab), pvr.mythtv (c954c7e), pvr.nextpvr (78c6633), pvr.njoy (4467cac), pvr.octonet (203f800), pvr.pctv (b60b971), pvr.stalker (d0170c5), pvr.teleboy (1956113), pvr.vbox (ea20464), pvr.vdr.vnsi (cbb75ab), pvr.vuplus (045d3a4, +14), pvr.wmc (7b28be3), pvr.zattoo (30868ce), vfs.libarchive (2ba1102), vfs.rar (b66c6df, +1), vfs.sftp (ab0dc82, +1)
- Include [env] compare (perma): TESTING: increase timeout to ensure OS is able to create core dump/crash log
- Include [env] patch: Add http2 support for curl
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: kodi: use upstream repo for Milhouse RPi builds
- Include [env] patch: kodi: remove annoying, excessively repetitive addon logging
- Include [env] patch: rev hack for kodi
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, peripheral.joystick/xarcade, other)
- Include [env] PR:2471 (perma): openssl: update to 1.1.1b
- Include [env] PR:3238 (perma): kodi/openssl: fix crash using vfs.sftp
- Include [env] PR:3316 (perma): openssh: drop support for ssh-dss keys
- Include [env] PR:3324 (perma): linux (RPi/Generic): update to linux-4.19.25/26
- Include [env] PR:3329 (perma): [RFC] add safe_remove to notify if a file doesn't exist
- Include [env] PR:3334 (perma): xf86-video-nvidia: update to xf86-video-nvidia-410.104
- Include [env] PR:3336 (perma): gcc: update to gcc-8.3.0
- Include [env] PR:3342 (perma): scripts/build: fix broken sym link after #3328
- Include [env] PR:3348 (perma): packages/{x11,print,devel}: bump packages
- Include [env] PR:3349 (perma): Packages: Miscellaneous package bumps to new minor versions
- Include [env] PR:3351 (perma): config/options: ban spaces in paths
- Revert [env] PR:8ad229b70f70c4811ccda9c81d5df8929d5babc1 ([url=]perma[/url]): openssl: revert minor bump
- Include [pkg] 983cf7a2: Sets the BCDC priority to constant 0 (linux)
- Include [pkg] patch: kodi: fix addon platform_tag (kodi)
- Include [pkg] PR:14571 (perma): Remove ARB postfix from GL functions
- Include [pkg] PR:15164 (perma): TexturePacker: Fix memory / resource leak the ugly way
- Include [pkg] PR:15356 (perma): Optimize locking in ApplicationMessenger
- Include [pkg] PR:15591 (perma): Fix TCP buffer parsing to find JSON statements to correctly
- Include [pkg] PR:15621 (perma): [cmake] microhttpd: only link with libraries
Build Highlights:
- openssl: update to 1.1.1b - this may break some addons
Build Details:
- XBMC:
- [cleanup] remove include guards (PR:15646, 1 commit, 6 files changed)
- [Android] Fix monoscopic/2D viewrect calcuation (PR:15649, 1 commit, 1 file changed)
- peripheral.xarcade:
- [cosmetic] use correct provider name (d218f0d)
- Added: [env] PR:2471 (perma): openssl: update to 1.1.1b
- Updated: [env] PR:3342 (perma): scripts/build: fix broken sym link after #3328
- Added: [env] PR:3351 (perma): config/options: ban spaces in paths
#0302 Installed and tvheadend client does not appear to start correctly. (Tvheadend server "v4.2.8-15-gdae8467" running OK can connect via web) Assume a consequence of openssl update.
Additionally other Addons appear to be commenting more? than usual in attached
kodi debug log
Note: Attached Log captured remotely, after clean reboot and enter/exit of TV channels + attempt to create log via LibreELEC settings which failed due to size of log.
MikeKL did you upgrade your tvheadend server to service.tvheadend42-9.1.118-0302~milhouse-v4.2.8-15-gdae8467.zip, which also uses the new version of openssl?
Your log is full of:
text:
2019-03-03 11:43:50.014 T:1489695600 ERROR: AddOnLog: Tvheadend HTSP Client: pvr.hts - unable to connect to 127.0.0.1:9982
which would suggest a communication issue between client and server, presumably caused by openssl (assuming it worked with #0301).
(2019-03-03, 21:10)Milhouse Wrote: [ -> ]@MikeKL did you upgrade your tvheadend server to service.tvheadend42-9.1.118-0302~milhouse-v4.2.8-15-gdae8467.zip, which also uses the new version of openssl?
Milhouse Apologies, I had not updated tvheadened server from 0301~milhouse-v4.2.8-15-gdae8467.zip which was installed to 0302~milhouse-v4.2.8-15-gdae8467.zip.
Once updated, tvheadend backend/frontend communicating correctly
New LibreELEC.tv Leia build #0303:
RPi /
RPi2
SHA256 Checksum:
21b357a519ee656e7e19be5160ebb956718ece7d940224738d3ef78d04e38bf9
(RPi)
SHA256 Checksum:
7d771031d3383a295a897a824a0d8c9d8dd83b36748912573265af428a1c85ce
(RPi2)
text:
# uname -a
Linux rpi512 4.19.25 #1 Sun Mar 3 21:04:36 GMT 2019 armv6l GNU/Linux
# vcgencmd version
# lsb_release
LibreELEC (Milhouse): devel-20190303210320-#0303-g0111c1d [Build #0303]
# Kodi version
Kodi (18.2-RC1 Git:847f1e8). Platform: Linux ARM 32-bit
Based on tip of
XBMC master (847f1e8,
Build Highlights:
- Minors
Build Details:
- XBMC:
- [music] format album rating (PR:15653, 1 commit, 1 file changed)
- [Android] generate keypress for mediasession actions (PR:15654, 1 commit, 1 file changed)
#0302 / #0303Â
Good Morning, since 03.02.19 TvHeadend give me an error (GetDriveSpace: Add-on 'Tvheadend:127.0.0.1:9982' returned an error: server error) when i go back too 0220 all works.
Kodi Log
(2019-03-04, 03:41)jasonx20ac Wrote: [ -> ]#0302 / #0303Â
Kodi Log
Can you boot into #0302/#0303 and run "journalctl -a|pastebinit" then post the link?
There are about 10 builds between #0220 and #0302, so if you could narrow it down that might help.
Ok i have installed #0301 and everything works.
Could it be that oscam service isn´t using the new libssl ?
(2019-03-04, 19:16)jasonx20ac Wrote: [ -> ]Ok i have installed #0301 and everything works.
Yes, oscam needs updating.
New LibreELEC.tv Leia build #0304:
RPi /
RPi2
SHA256 Checksum:
77a4b4c1db79fc86331108db4a2a4d48422814602fc31dc5dcb3e94b332a00ee
(RPi)
SHA256 Checksum:
5cd98de9f1c0e8235e98d60d62cf512e6955aa155d48622ee9fe8a24c1678e58
(RPi2)
text:
# uname -a
Linux rpi512 4.19.25 #1 Mon Mar 4 21:04:32 GMT 2019 armv6l GNU/Linux
# vcgencmd version
# lsb_release
LibreELEC (Milhouse): devel-20190304210323-#0304-g0111c1d [Build #0304]
# Kodi version
Kodi (18.2-RC1 Git:1a261cf). Platform: Linux ARM 32-bit
Based on tip of
XBMC master (1a261cf,
- Include [env] PR:3354 (perma): brcmfmac_sdio-firmware-rpi: fix race between service and /dev/serial1
- Include [pkg] PR:193 (perma): Async connection (pvr.vuplus)
- Include [pkg] PR:15644 (perma): [curl] Accept all supported content encodings by default
Build Highlights:
- brcmfmac_sdio-firmware-rpi: fix race between service and /dev/serial1
- Async connection (pvr.vuplus)
- [curl] Accept all supported content encodings by default
Build Details:
- XBMC:
- fixed: always update stream details from player (fixes #15584) (PR:15589, 1 commit, 1 file changed)
- [cmake] microhttpd: only link with libraries (PR:15621, 2 commits, 2 files changed)
- [Android] Prevent HDMI_AUDIO_PLUG intent on TV (PR:15661, 1 commit, 2 files changed)
- Fix TCP buffer parsing to find JSON statements to correctly (PR:15591, 1 commit, 1 file changed)
- Added: [env] PR:3354 (perma): brcmfmac_sdio-firmware-rpi: fix race between service and /dev/serial1
- Added: [pkg] PR:193 (perma): Async connection (pvr.vuplus)
- Added: [pkg] PR:15644 (perma): [curl] Accept all supported content encodings by default
Can I know how to install your TVheadend compilation?? I try to add the URL and install it like any other zip addon but doesn't install. Is necesary any other steps??Â
New LibreELEC.tv Leia build #0305:
RPi /
RPi2
SHA256 Checksum:
0fd155e9f3005fd8f9e9a5ed547120ece66704afb40f7069be8f4f4970cc34fb
(RPi)
SHA256 Checksum:
46681c040c4ea71222216a967de8f836a7a1a013a1e66b900d24cf56ae35d9dc
(RPi2)
text:
# uname -a
Linux rpi512 4.19.25 #1 Tue Mar 5 22:17:23 GMT 2019 armv6l GNU/Linux
# vcgencmd version
# lsb_release
LibreELEC (Milhouse): devel-20190305221520-#0305-g0111c1d [Build #0305]
# Kodi version
Kodi (18.2-RC1 Git:4de5972). Platform: Linux ARM 32-bit
Based on tip of
XBMC master (4de5972,
- Includes latest addons: inputstream.adaptive (b76c81f), inputstream.rtmp (ce68b77, +1), peripheral.joystick (6b2a4dd, +5), peripheral.xarcade (d218f0d, +2), pvr.argustv (83aa1e9), pvr.demo (964686d), pvr.dvblink (ecc9cfd, +4), pvr.dvbviewer (c2c1beb, +2), pvr.filmon (e850633), pvr.hdhomerun (a9d7309), pvr.hts (8dcd62d, +3), pvr.iptvsimple (73feb2f), pvr.mediaportal.tvserver (931afab), pvr.mythtv (c954c7e), pvr.nextpvr (78c6633), pvr.njoy (4467cac), pvr.octonet (203f800), pvr.pctv (b60b971), pvr.stalker (d0170c5), pvr.teleboy (1956113), pvr.vbox (ea20464), pvr.vdr.vnsi (cbb75ab), pvr.vuplus (97c67ae, +23), pvr.wmc (7b28be3), pvr.zattoo (30868ce), vfs.libarchive (2ba1102), vfs.rar (b66c6df, +1), vfs.sftp (ab0dc82, +1)
- Include [env] PR:3324 (perma): linux (RPi/Generic): update to linux-4.19.25/27
Build Highlights:
- lan78xx: EEE support is now a PHY property
Build Details:
- XBMC:
- [Android] implement MediaSession::onMediaButtonEvent (PR:15675, 1 commit, 3 files changed)
- pvr.dvblink:
- Add PVR addon update interval setting (PR:114, 1 commit, 7 files changed)
- Fixed: deleted timers do not remain in the list as disabled (#118); R (PR:119, 1 commit, 3 files changed)
- pvr.vuplus:
- Async connection (PR:193, 9 commits, 36 files changed)
- kernel 4.19.y:
- New commits in this build:
- lan78xx: EEE support is now a PHY property (7f41587c)
- Updated: [env] PR:3324 (perma): linux (RPi/Generic): update to linux-4.19.25/27
New LibreELEC.tv Leia build #0306:
RPi /
RPi2
SHA256 Checksum:
a3431b854aab430161a63db187384cae813549a1f93302a8a6cf2efdc4d26a8b
(RPi)
SHA256 Checksum:
4c360a2bc28c17dbd318ae91565517a657dbbb9ba33ee2e123a8f083e24a9042
(RPi2)
text:
# uname -a
Linux rpi512 4.19.27 #1 Wed Mar 6 21:13:07 GMT 2019 armv6l GNU/Linux
# vcgencmd version
# lsb_release
LibreELEC (Milhouse): devel-20190306210326-#0306-g0111c1d [Build #0306]
# Kodi version
Kodi (18.2-RC1 Git:26ba848). Platform: Linux ARM 32-bit
Based on tip of
XBMC master (26ba848,
- Include [env] compare (perma): kodi: fix patch
- Include [env] PR:3324 (perma): linux (RPi/Generic): update to linux-4.19.27
Build Highlights:
- New 4.19.27 kernel
- Minor log changes (kodi)
Build Details:
- XBMC:
- Minor log changes (PR:15678, 1 commit, 4 files changed)
- Added: [env] compare (perma): kodi: fix patch
- Updated: [env] PR:3324 (perma): linux (RPi/Generic): update to linux-4.19.27
