Since #0422 I'm seeing the choppy GUI again like described here already:
2720729 (post)
(2018-04-24, 18:32)thent Wrote: [ -> ]Since #0422 I'm seeing the choppy GUI again like described here already:
2720729 (post)
Are you using OMXPlayer or MMAL?
New LibreELEC.tv Leia build #0424:
RPi /
RPi2
(Supercedes previous build)
SHA256 Checksum:
20949f6a7d0ceb59d2a6de1fe95e08fceb41aa049300265f6004ed83ea5ad3b4
(RPi)
SHA256 Checksum:
26ec8b6414c964ae39124db56d554c28a04c5ce27f2ba3fc1753d8a279967f41
(RPi2)
text:
# uname -a
Linux rpi512 4.14.34 #1 Tue Apr 24 21:05:06 BST 2018 armv6l GNU/Linux
# vcgencmd version
Apr 16 2018 18:21:52
Copyright © 2012 Broadcom
version af8084725947aa2c7314172068f79dad9be1c8b4 (clean) (release)
# lsb_release
LibreELEC (Milhouse): devel-20180424210314-#0424-gadc0ff9 [Build #0424]
# Kodi version
(18.0-ALPHA2 Git:af4a548). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (adc0ff9,
changelog) and tip of
XBMC master (cd6c3fa,
- Includes newclock5 patches
- Includes latest commits from kernel branch rpi-4.14.y
- Includes latest bcm2835-driver master (a154f21)
- Includes latest kodi-platform master (e8574b8)
- Includes latest libcec master (8adc786, ahead +26)
- Includes latest libnfs master (8b064bf, ahead +125)
- Includes latest p8-platform master (a822e19)
- Includes latest addons: inputstream.adaptive (0f0ced4, +5), inputstream.rtmp (3b5058d), peripheral.joystick (80224e1), pvr.argustv (377f796), pvr.demo (d5e5cd1), pvr.dvblink (c61ea73), pvr.dvbviewer (3799782, +4), pvr.filmon (0ca1665), pvr.hdhomerun (484b91d), pvr.hts (9533cce), pvr.iptvsimple (77156cb), pvr.mediaportal.tvserver (9702684), pvr.mythtv (9d15025), pvr.nextpvr (de30ff2), pvr.njoy (bd6581f), pvr.octonet (54680a3), pvr.pctv (5e95300), pvr.stalker (da6f0f8), pvr.teleboy (a84e5ef), pvr.vbox (3cf15ad), pvr.vdr.vnsi (d6fe796), pvr.vuplus (00a963f), pvr.wmc (2acca13), pvr.zattoo (1244e14, +2), vfs.libarchive (e7d149e)
- Exclude [env] kodi-0100-temp-add-pr13594.patch: merged upstream
- Include [env] compare (perma): dmidecode: initial package
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: libcec: fix PR390
- Include [env] patch: libcec: don't link non-existant libtinfo
- Include [env] patch: rev hack for kodi
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, other)
- Include [env] PR:2536 (perma): kodi: libinput fixes
- Include [env] PR:2572 (perma): update dvb addons
- Include [env] PR:2623 (perma): RPi, Generic: backport proposed patch to reduce IR latency
- Include [env] PR:2627 (perma): linux: update to linux-4.14.34
- Include [env] PR:2653 (perma): samba: fix interleaved config generation/modification
- Include [env] PR:2654 (perma): kodi: Early May 2018
- Include [pkg] patch: skin.estuary: reduce system info font size (kodi)
- Include [pkg] PR:3 (perma): Reusepython (kodi)
- Include [pkg] PR:13176 (perma): [RFC] [Linux] add libinput backend for non window system platforms
- Include [pkg] PR:13274 (perma): Mode whitelist
- Revert [pkg] PR:13780: bump ffmpeg to 4.0 (reason: LibreELEC needs to bump ffmpeg and patches)
- Revert [pkg] PR:13791: ffmpeg: drop some deprecated functions
Build Highlights:
- Reusable Python fixes
Build Details:
- LibreELEC.tv:
- scripts/image: support periodic image names (PR:2661, 1 commit, 1 file changed)
- initramfs: add missing fakeroot:host dependency (PR:2663, 1 commit, 1 file changed)
- XBMC:
- [fix] call av_dump_format with redacted url (PR:13801, 1 commit, 2 files changed)
- kernel 4.14.y:
- New commits in this build:
- BCM270X_DT: Add sdio_overclock parameter (2d71f6ea)
- gpiolib: Don't prevent IRQ usage of output GPIOs (aad95bfc)
- Updated: [pkg] PR:3 (perma): Reusepython (kodi)
(2018-04-22, 23:54)Milhouse Wrote: [ -> ] (2018-04-22, 23:26)beertank Wrote: [ -> ]#0422 keeps rebooting after update eventually ending up in safe mode.
Crash log here: http://ix.io/18tG
OK that looks to be a Python issue, can you downgrade back to #0421 for now?
Edit: If you're stuck in Safe Mode then downgrading via ssh or Samba is likely to be the easiest solution - drop the #0421 tar file in the .update (ssh)/Update (Samba) folder, reboot and you should be back in your normal Kodi (ie. no longer in Safe Mode).
Confirm #0423 / #0424 run OK
(2018-04-24, 20:24)Milhouse Wrote: [ -> ] (2018-04-24, 18:32)thent Wrote: [ -> ]Since #0422 I'm seeing the choppy GUI again like described here already:
2720729 (post)
For video playback I'm using MMAL, but the issue is only with audio playback (probably with dvdplayer).
Trying latest build on Pi1, starting any Movie or TV show crashes kodi.
I have my old Pi1 hooked up to a BENQ screen with HDMI and the screen has no sound. I see a muted speaker icon when kodi is running, not sure if that is why it can't playback without crashing.
http://ix.io/18H6
Not sure if i was supposed to reply to this post or post it somewhere else?
Brunis
I have my old Pi1 hooked up to a BENQ screen with HDMI and the screen has no sound. I see a muted speaker icon when kodi is running, not sure if that is why it can't playback without crashing. Hope that helps.
2720729 (post)
Same here, especially for Pi1, i'm seeing 2fps in Home window, even after setting resolution down to 768x576
Upgraded from 329 to 422 and experienced severe stuttering audio and video.
Downgraded to 407 and all is ok.
Anyone else having similar issues?
Regards Phil
(2018-04-25, 15:11)b1m1 Wrote: [ -> ]Hi,
Regards Phil
Yes i have the same issue. 407 is the last working version.
https://pastebin.com/P3WiaAAr
New LibreELEC.tv Leia build #0425:
RPi /
RPi2
SHA256 Checksum:
ab95ae4bd765ccd439d162287ce5caed61a2d59b9fd3c9daeed68860c39fd036
(RPi)
SHA256 Checksum:
d8aff2769741dddb7264ecd230be6b4ba6a2dbec97033cf1bf0d8a6d2aea9391
(RPi2)
text:
# uname -a
Linux rpi512 4.14.34 #1 Wed Apr 25 21:17:38 BST 2018 armv6l GNU/Linux
# vcgencmd version
# lsb_release
LibreELEC (Milhouse): devel-20180425211539-#0425-gd3607ba [Build #0425]
# Kodi version
(18.0-ALPHA2 Git:cd6c3fa). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (d3607ba,
XBMC master (d233545,
- Include [pkg] PR:13814 (perma): Reusepython
- Include [pkg] PR:13815 (perma): [PVR] Implement smart direct channel number input
Build Highlights:
- ffmpeg 4.0-Leia-Alpha-1
Build Details:
- LibreELEC.tv:
- create sha256 checksum files of tars and images (PR:2664, 3 commits, 2 files changed)
- XBMC:
- [Linux] add libinput backend for non window system platforms (PR:13176, 14 commits, 30 files changed)
- newclock5:
- ffmpeg: hevc: Rebase to ffmpeg 4 (bd944228)
- Commits no longer in build:
- kernel 4.14.y:
- Updated: [env] PR:2623 (perma): RPi, Generic: backport proposed patch to reduce IR latency
- Updated: [env] PR:2654 (perma): kodi: Early May 2018
- Updated: [pkg] PR:13814 (perma): Reusepython
- Added: [pkg] PR:13815 (perma): [PVR] Implement smart direct channel number input
latest build is a total bust on Pi1 .. it's running, but home screen never appears..
i'd send debug logs, but i can't even ssh into it.. it responds though and samba shares are browsable.
popcornmix 3D iso playback does not work in #425. Log shows a wellknown "Open: MVC stream not found", maybe new ffmpeg 4.0 needs some more patches?
Believe I Installed #0425 build around 22:25 and following morning unattended "idle" Kodi crash
Kodi Crashlog
New LibreELEC.tv Leia build #0426:
RPi /
RPi2
SHA256 Checksum:
91fb3bdac31aeda68aa6dacd8b77d6d6cad44c1851aa9ea8c470643dee023ccb
(RPi)
SHA256 Checksum:
b4d864afa8ad9fdd3666796b13560d54bd9af78fb74ba745a60e8a1ca811e511
(RPi2)
text:
# uname -a
Linux rpi512 4.14.37 #1 Thu Apr 26 21:05:04 BST 2018 armv6l GNU/Linux
# vcgencmd version
# lsb_release
LibreELEC (Milhouse): devel-20180426210309-#0426-gad45714 [Build #0426]
# Kodi version
Based on tip of
LibreELEC.tv master (ad45714,
XBMC master (2f5f0c0,
- Include [env] PR:2627 (perma): linux: update to linux-4.14.37
- Include [env] PR:2672 (perma): make: fix build against actual host glibc
- Include [pkg] PR:13803 (perma): windowing: add overrides for UseLimitedColor for specific platforms
Build Highlights:
- New 4.14.37 kernel
- samba 4.8.1 (bug fixes)
Build Details:
- LibreELEC.tv:
- Remove u-boot-tools package dependency for WC & WP (PR:2671, 1 commit, 2 files changed)
- samba: fix interleaved config generation/modification (PR:2653, 2 commits, 5 files changed)
- samba: update to samba-4.8.1 (PR:2673, 1 commit, 2 files changed)
- XBMC:
- Assorted FreeBSD fixes (PR:13691, 7 commits, 8 files changed)
- [cleanup][windows] remove unused scripts & files (PR:13818, 2 commits, 5 files changed)
- [PVR] Implement smart direct channel number input (PR:13815, 2 commits, 14 files changed)
- [depends][darwin] cleanup, fix variable order & build / host mix up (PR:13816, 3 commits, 6 files changed)
- Updated: [env] PR:2572 (perma): update dvb addons
- Updated: [env] PR:2627 (perma): linux: update to linux-4.14.37
- Added: [env] PR:2672 (perma): make: fix build against actual host glibc
- Added: [pkg] PR:13803 (perma): windowing: add overrides for UseLimitedColor for specific platforms
