(2017-12-12, 20:10)Vimes Wrote: [ -> ]Just to ask if there is a thread, section, GIT or something that I could follow for updates to the ALSA and audio engine updates.?
This thread should be sufficient. Already fixed in #1212, I just haven't had time to post the release notes.
New LibreELEC.tv Leia build #1212:
RPi /
RPi2
(Supercedes previous build)
SHA256 Checksum:
a7731700ba28d36ce68218c87cb4acecc3b3425bd6a309766ce203797b59a47a (RPi)
SHA256 Checksum:
674c1e922f9b2dad4fe635b5c3aab7e43453a48787d35345a2685b5d099f37f4 (RPi2)
# uname -a
Linux rpi512 4.14.5 #1 Tue Dec 12 21:11:30 GMT 2017 armv6l GNU/Linux
# vcgencmd version
Dec 1 2017 16:20:32
Copyright (c) 2012 Broadcom
version 38ac72569d7fbd7cf75754d9f14c2495416aaee7 (clean) (release)
# lsb_release
LibreELEC (Milhouse): devel-20171212210351-#1212-g871c73c [Build #1212]
# Kodi version
(18.0-ALPHA1 Git:4855b1a). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (871c73c,
changelog) and tip of
XBMC master (4855b1a,
- Includes newclock5 patches
- Excludes the LibreELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.14.y
- Includes latest bcm2835-driver master (bcd3b8f, ahead +7)
- Includes latest kodi-platform master (36fb493)
- Includes latest libcec master (8adc786, ahead +26)
- Includes latest libnfs master (82b3411, ahead +109)
- Includes latest p8-platform master (a822e19)
- Includes latest addons: inputstream.adaptive (d2081b2), inputstream.rtmp (c772497), peripheral.joystick (33b43ce), pvr.argustv (1a48789), pvr.demo (aaf7654), pvr.dvblink (816f90c), pvr.dvbviewer (6129441), pvr.filmon (2dee2ca), pvr.hdhomerun (63dfccb), pvr.hts (67fe2df), pvr.iptvsimple (ac4f4bd), pvr.mediaportal.tvserver (6c35e88), pvr.mythtv (8f214cd), pvr.nextpvr (938bb48), pvr.njoy (4a5efef), pvr.octonet (c4af00a), pvr.pctv (6484615), pvr.stalker (44025a1), pvr.teleboy (e431126), pvr.vbox (619c32b), pvr.vdr.vnsi (0ec3e77), pvr.vuplus (7ea6b21), pvr.wmc (55e701b), pvr.zattoo (23d9993), vfs.libarchive (568a2a1)
- Include [env] compare (perma): dmidecode: initial package
- Include [env] compare (perma): kodi: enable USE_LTO
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: libcec: don't link non-existant libtinfo
- Include [env] patch: rev hack for kodi
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, other)
- Include [env] PR:2228 (perma): kodi: safe mode
- Include [env] PR:2243 (perma): NOOBS: shorten partition labels, add $DEVICE support
- Include [env] PR:2270 (perma): dvb driver addons
- Include [env] PR:2298 (perma): Kodi updates for Jan 2018
- Include [env] PR:2317 (perma): linux: update to linux-4.14.8
- Include [pkg] patch: ##lan78xx: disable WOL (linux)
- Include [pkg] patch: skin.estuary: reduce system info font size (kodi)
- Include [pkg] PR:55 (perma): Fix deprecated function warnings (pvr.pctv)
- Include [pkg] PR:80 (perma): update jsoncpp methods to non deprecated versions (pvr.filmon)
- Include [pkg] PR:86 (perma): connman.py: More secure default password for tethering (service.libreelec.settings)
- Include [pkg] PR:87 (perma): add safe mode text (service.libreelec.settings)
- Include [pkg] PR:103 (perma): jsoncpp deprecated function change (pvr.stalker)
- Include [pkg] PR:13034 (perma): Cmake cpp14
- Include [pkg] PR:13062 (perma): smbclient changes for smb minprotocol and legacysecurity
Build Highlights:
- New 4.14.5 kernel
- Restore ALSA/Pulse co-existence patch
- Shadow passwd file: overwrite if root is missing
Build Details:
- LibreELEC.tv:
- shadow: detect corrupt content (PR:2316, 1 commit, 1 file changed)
- Refactor scripts/checkdeps, fix missing deps (PR:2247, 6 commits, 1 file changed)
- enable ccache with linaro aarch64 toolchain (PR:2314, 1 commit, 1 file changed)
- XBMC:
- fix typo (*VAApi()->VAApi*()) and function signature of VAAPIRegister (PR:13174, 1 commit, 1 file changed)
- [Estuary] Rework PVR seekbar + Fix PVR info dialog. (PR:13158, 3 commits, 5 files changed)
- Update README.md to reflect increased number of translations (PR:13177, 1 commit, 1 file changed)
- kernel 4.14.y:
- New commits in this build:
- staging: vchiq_arm: Make debugfs failure non-fatal (aeabd883)
(2017-12-13, 01:00)steveh Wrote: [ -> ]Any idea when shadertoy will be back in the build?
I have uploaded new builds of visualization.shadertoy. Untested.
Installation of #1212 did not appear to resolve my existing ssh access denied issue. However deleting shadow & shadow- then rebooting, reset shh password to standard and I could then ssh into rpi2 as normal with standard libreelec password.
(so i must have messed up with my checking/testing modified password somehow)
You're probably not the first person to change a password to something complicated and then be unable to retype it 5 minutes later (unless you had it written down somewhere, maybe on a post-it stuck to the monitor...)
Public/private keys are a lot easier and more secure, and PuTTY supports them well.
Weekly Linux 4.15-rc3 build #1212x:
RPi /
RPi2
Packages disabled/issues:
RTL8188EU
RTL8189FS
RTL8192CU
RTL8192DU
RTL8192EU
RTL8812AU
media_build
(2017-11-06, 18:12)Mike74 Wrote: [ -> ] (2017-11-05, 21:07)cesarleeds Wrote: [ -> ] (2017-11-05, 20:21)3DBuff Wrote: [ -> ]Same problem with 3D here. 3D ISO files play in 2D now
@-DH- traced it back to #1019 as the last version playing 3D MVC fles.
https://forum.kodi.tv/showthread.php?tid...pid2658671
Not only ISOs, even m2ts doesn´t work for me, although the files are perfectly fine, i mean, they played before.
Same Problem
This is still an issue. Please can someonf fix this.
(2017-12-13, 05:54)Milhouse Wrote: [ -> ] (2017-12-12, 20:10)Vimes Wrote: [ -> ]Just to ask if there is a thread, section, GIT or something that I could follow for updates to the ALSA and audio engine updates.?
Great to see it back and working as good as ever. Thanks for the heads up.
Hi, after update from 8.2.1 to Milhouse 9.0 #1212, 12-Dec-2017 my remote Control not works (lirc)
(2017-12-13, 06:13)Milhouse Wrote: [ -> ] (2017-12-13, 01:00)steveh Wrote: [ -> ]Any idea when shadertoy will be back in the build?
Just downloaded and tried with build 1212, no errors in the log (apart from a CAddonSettings parse error) but also just a black screen during audio playback.
Flicked to spectrum and this works, then back to shadertoy and nothing.
Regards
Steve
New LibreELEC.tv Leia build #1213:
RPi /
RPi2
SHA256 Checksum:
53c7f398f89fea05a984cc3ff8ef436aa51752084b74879d3a586358c953f3d2 (RPi)
SHA256 Checksum:
c0966b716b234129c03ffb8d77c5461c420d5113f83427530f205cf80aa1245d (RPi2)
# uname -a
Linux rpi512 4.14.5 #1 Wed Dec 13 21:35:30 GMT 2017 armv6l GNU/Linux
# vcgencmd version
Dec 1 2017 16:20:32
# lsb_release
LibreELEC (Milhouse): devel-20171213213418-#1213-g1315e7a [Build #1213]
# Kodi version
(18.0-ALPHA1 Git:cfbf206). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (1315e7a,
XBMC master (cfbf206,
- Includes latest addons: inputstream.adaptive (d2081b2), inputstream.rtmp (c772497), peripheral.joystick (33b43ce), pvr.argustv (1a48789), pvr.demo (aaf7654), pvr.dvblink (816f90c), pvr.dvbviewer (6129441), pvr.filmon (2dee2ca), pvr.hdhomerun (b00a8b5, +1), pvr.hts (67fe2df), pvr.iptvsimple (ac4f4bd), pvr.mediaportal.tvserver (6c35e88), pvr.mythtv (8f214cd), pvr.nextpvr (938bb48), pvr.njoy (4a5efef), pvr.octonet (c4af00a), pvr.pctv (6484615), pvr.stalker (44025a1), pvr.teleboy (e431126), pvr.vbox (619c32b), pvr.vdr.vnsi (0ec3e77), pvr.vuplus (7ea6b21), pvr.wmc (55e701b), pvr.zattoo (23d9993), vfs.libarchive (568a2a1)
Build Highlights:
- More AE fixes
Build Details:
- LibreELEC.tv:
- scripts/create_addon: improve PKG_ADDON_PROJECTS check (PR:2311, 2 commits, 3 files changed)
- projects/S905: new project (PR:2315, 3 commits, 24 files changed)
- XBMC:
- windowing/gbm: cleanup and OO structure (PR:13136, 3 commits, 16 files changed)
- windowing/gbm: fix building without vaapi (PR:13180, 1 commit, 1 file changed)
- [cmake] add defines for alsa and pulseaudio (PR:13181, 2 commits, 3 files changed)
- AESinkFactory: Adjust Sndio (PR:13183, 1 commit, 13 files changed)
- Attempt to fix FileFactory test (PR:13168, 6 commits, 17 files changed)
- AESinkFactory: Check return value of pulse (PR:13184, 3 commits, 6 files changed)
- [cmake] linux: add option to enable link time optimization (PR:13153, 1 commit, 2 files changed)
- [jenkins] improve revsion, date and branch name detection (PR:13167, 2 commits, 5 files changed)
- X11: rework visuals (PR:13178, 1 commit, 2 files changed)
- [Linux] Atomic DRM support (PR:12672, 4 commits, 8 files changed)
- fixed: add missing audiooutput.dspaddonsenabled entry in settings.xml (PR:13188, 1 commit, 1 file changed)
- pvr.hdhomerun:
- win10: fix build on UWP after #69 (PR:72, 1 commit, 1 file changed)
(2017-12-13, 13:04)trevorjharris Wrote: [ -> ] (2017-11-06, 18:12)Mike74 Wrote: [ -> ] (2017-11-05, 21:07)cesarleeds Wrote: [ -> ]Not only ISOs, even m2ts doesn´t work for me, although the files are perfectly fine, i mean, they played before.
Same Problem
Yep, please, would love to see 3D back and working.
(2017-12-13, 19:59)BazingaICore Wrote: [ -> ]Hi, after update from 8.2.1 to Milhouse 9.0 #1212, 12-Dec-2017 my remote Control not works (lirc)
I guess you need to switch from lirc-rpi to gpio-ir.
New LibreELEC.tv Leia build #1214:
RPi /
RPi2
SHA256 Checksum:
2ab15564fe135d54075098ce37f6e87cc104b3e0ca0c3850ac1262d2db6ab2a2 (RPi)
SHA256 Checksum:
a3c4d0ea0a3a2de364b86bbd3cce4208108893a6c4e164d60ccbc5c3826b056f (RPi2)
# uname -a
Linux rpi512 4.14.6 #1 Thu Dec 14 21:09:39 GMT 2017 armv6l GNU/Linux
# vcgencmd version
Dec 1 2017 16:20:32
# lsb_release
LibreELEC (Milhouse): devel-20171214210652-#1214-g9155531 [Build #1214]
# Kodi version
(18.0-ALPHA1 Git:cf696d4). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (9155531,
XBMC master (cf696d4,
- Include [env] patch: libcec: fix PR390
- Include [env] PR:2323 (perma): buildsystem: source functions earlier, validate project/arch earlier, refactor show_config
Build Highlights:
- New 4.14.6 kernel
- Drop gcc5 patch
- Drop Nuvoton and Ouya controller support
- Libcec: Fix LG tv always changing input
Build Details:
- LibreELEC.tv:
- Libcec: Fix LG tv always changing input (PR:2320, 1 commit, 1 file changed)
- dvb driver addons (PR:2270, 11 commits, 38 files changed)
- chromium: update to newer version (PR:1730, 17 commits, 16 files changed)
- kodi: safe mode [RFC] (PR:2228, 3 commits, 7 files changed)
- XBMC:
- [Estuary] fix musicplaylisteditor (PR:13147, 1 commit, 1 file changed)
- [cmake] make sure binutils are always defined (PR:13185, 1 commit, 1 file changed)
- FFmpegImage: Resolve Typo - make it more human readable (PR:13194, 1 commit, 1 file changed)
- Fix crash on POSIX that happens if HOME is not set. (PR:13193, 1 commit, 1 file changed)
- Updated: [env] PR:2317 (perma): linux: update to linux-4.14.8
- Added: [env] PR:2323 (perma): buildsystem: source functions earlier, validate project/arch earlier, refactor show_config
I got "large audio sync error" on twitch and youtube live streaming.
It make stutter frames very often.
And problem solved by setting PLL option to
"High" or "Max" "Medium", but it doesn't perfect.
Is it normal?
12:42:31.997 T:1400894352 NOTICE: Creating audio stream (codec id: 86018, channels: 2, sample rate: 48000, no pass-through)
12:42:32.012 T:1942134800 NOTICE: m_playbackStarting
12:42:32.012 T:1942134800 NOTICE: StereoscopicsManager::IsPlaying
12:42:32.012 T:1942134800 NOTICE: StereoscopicsManager::HasAudio
12:42:32.012 T:1942134800 NOTICE: StereoscopicsManager::Stream valid
12:44:23.653 T:1400894352 NOTICE: CVideoPlayerAudio:rocess - stream stalled
13:15:00.716 T:1912136592 WARNING: ActiveAE - large audio sync error: -1815.069997
13:15:00.727 T:1912136592 WARNING: ActiveAE - large audio sync error: -1834.726038
13:15:00.739 T:1912136592 WARNING: ActiveAE - large audio sync error: -1834.860101
13:15:00.749 T:1912136592 WARNING: ActiveAE - large audio sync error: -1835.260413
13:15:00.761 T:1912136592 WARNING: ActiveAE - large audio sync error: -1834.594058
13:15:00.772 T:1912136592 WARNING: ActiveAE - large audio sync error: -1836.719840
13:15:00.780 T:1912136592 WARNING: ActiveAE - large audio sync error: -1837.051974
13:15:00.789 T:1912136592 WARNING: ActiveAE - large audio sync error: -1834.379788
13:15:00.797 T:1912136592 WARNING: ActiveAE - large audio sync error: -1834.710362
13:15:00.806 T:1912136592 WARNING: ActiveAE - large audio sync error: -1834.963226
13:15:00.813 T:1912136592 WARNING: ActiveAE - large audio sync error: -1834.276976
13:15:00.821 T:1912136592 WARNING: ActiveAE - large audio sync error: -1834.589944
13:15:00.829 T:1912136592 WARNING: ActiveAE - large audio sync error: -1834.948433
13:15:00.837 T:1912136592 WARNING: ActiveAE - large audio sync error: -1833.998277
13:15:00.845 T:1912136592 WARNING: ActiveAE - large audio sync error: -1834.332497
13:15:00.854 T:1912136592 WARNING: ActiveAE - large audio sync error: -1835.679476
13:15:00.873 T:1912136592 WARNING: ActiveAE - large audio sync error: -1834.247547
