2018-08-04, 00:11
(2018-08-03, 23:59)TDown Wrote: [ -> ]I started a new thread with the below but I figure it should be posted here. This issue is definitely specific to V18:
I have witnessed a black screen flickering across multiple v18 Nightlies on a RPi 3B+. I have since returned to v17 without this issue.
The issue only appears to happen with Standard Definition channels (480i).
http://ix.io/1fNI
http://www.filehosting.org/file/details/...licker.zip
The above are uploaded logs as well as a short clip recorded through Kodi/NPVR (I apologize for the randomly located hosting service). The TS file when played through v18 flickers the same as watching a live channel. Flickering does not exist when TS file is watched on PC.
Can you determine which of these v18 test builds is the first with this issue? You'll be limited to builds after mid March (when the Pi3B+ launched).
