i did a update from #1210 to #1219 but now my whole menu is gone and cant do anything anymore in kodi. also did a reboot/shutdown etc.
i can press the B (green) button on my TV remote and it shows the vidoe thing so i can choose files etc and play files but that also isnt handy
(2016-12-19, 23:47)Little_Kitty Wrote: [ -> ]i did a update from #1210 to #1219 but now my whole menu is gone and cant do anything anymore in kodi. also did a reboot/shutdown etc.
Are you using estuary mod by any chance?
(2016-12-20, 00:00)bmonster Wrote: [ -> ] (2016-12-19, 23:47)Little_Kitty Wrote: [ -> ]i did a update from #1210 to #1219 but now my whole menu is gone and cant do anything anymore in kodi. also did a reboot/shutdown etc.
No i use a other one but cant remeber the name of it.
http://sprunge.us/YQKe
the log file
Is it just me, anyone else noticing the pink/red hue in upper left and lower right corners of the Estuary skin in recent builds?
(Not sure which build introduced this planned background change in default skin?)
(2016-12-20, 00:46)MikeKL Wrote: [ -> ]Is it just me, anyone else noticing the pink/red hue in upper left and lower right corners of the Estuary skin in recent builds?
You can change it in the skin settings.
(2016-12-20, 00:13)Little_Kitty Wrote: [ -> ] (2016-12-20, 00:00)bmonster Wrote: [ -> ] (2016-12-19, 23:47)Little_Kitty Wrote: [ -> ]i did a update from #1210 to #1219 but now my whole menu is gone and cant do anything anymore in kodi. also did a reboot/shutdown etc.
the log file
I know there's an issue with skin shortcuts that causing the problem your describing, which happened to me on estuary mod.
Had to install skin shortcuts version 1.0.13, and not 1.0.15, if your using this add-on that could be your problem.
Check out post 2810
http://forum.kodi.tv/showthread.php?tid=267343&page=188
New LibreELEC.tv Krypton build #1219:
RPi /
RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.9.0 #1 Mon Dec 19 21:08:44 GMT 2016 armv6l GNU/Linux
# vcgencmd version
Dec 9 2016 17:52:15
Copyright (c) 2012 Broadcom
version 40f32e4ad457a5e9dc91288ebccb13e23d986e4a (clean) (release)
# lsb_release
LibreELEC (Milhouse) - Version: devel-20161219210733-#1219-gafc1649 [Build #1219]
# Kodi version
(18.0-ALPHA1 Git:17.0-beta7-7581c4a). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (afc16497,
changelog) and tip of
XBMC master (335a1b98,
- Includes newclock5 patches
- Excludes the LibreELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.9.y
- Includes latest bcm2835-driver next (397e1bb5, ahead +608)
- Includes latest kodi-platform master (c8188d82)
- Includes latest libcec master (12fa2750, ahead +2)
- Includes latest libnfs master (a2b37349, ahead +2)
- Includes latest p8-platform master (2d90f986, ahead +9)
- Includes latest addons: inputstream.adaptive (fc862638), inputstream.rtmp (55437ac7), peripheral.joystick (987a818e), pvr.argustv (4702a9e7, +3), pvr.demo (99db6bf5, +3), pvr.dvblink (4e6992d9, +3), pvr.dvbviewer (2b8ab246, +12), pvr.filmon (a23db0c5, +3), pvr.hdhomerun (baeafbde, +3), pvr.hts (117d4020, +3), pvr.iptvsimple (df0649e7, +5), pvr.mediaportal.tvserver (f00ccfd3, +15), pvr.mythtv (41c3201f, +48), pvr.nextpvr (48a7796a, +3), pvr.njoy (d1ad569b, +3), pvr.octonet (8549a31c), pvr.pctv (b8286a23, +3), pvr.stalker (dfda4c51, +3), pvr.vbox (bfa938c7, +8), pvr.vdr.vnsi (3efe8682, +6), pvr.vuplus (acd75dc5, +3), pvr.wmc (35be514e, +3)
- Exclude [env] kodi-100.06-dont-set-_NET_WM_STATE_FULLSCREEN.patch: Reason: No longer required
- Exclude [env] linux-999-i915-Fix-random-GPU-hang-Bug-156851.patch: Removed: Do we still need this?
- Include [env] patch: Don't build ADSP addons
- Include [env] patch: kodi: fix intel gpu detection patch after kodi/10848
- Include [env] patch: linux: use in-tree rtl8192cu for RPi/RPi2
- Include [env] patch: repository.retroplayer.libreelec.addons: add temp repo for testing
- Include [env] patch: Add kodi binary addons (pvr, adsp, other)
- Include [env] PR:1025: scripts/create_addon: use PKG_REV as part of the binary addon version
- Include [env] PR:1052: Package updates
- Include [env] PR:1058: libdvbcsa: AArch64 support
- Include [env] PR:1067: vaapi hvec 10bit support
- Include [env] PR:1075: Package updates
- Include [pkg] PR:39: use prettyname_regex to show shortname in update menu (service.libreelec.settings)
- Include [pkg] PR:44: update infobools (service.libreelec.settings)
- Include [pkg] PR:249: Fix ass_set_cache_limits() to work with composite cache (libass)
- Include [pkg] PR:11163: Fix silent failure when game add-on can't be installed
- Include [pkg] PR:11223: [PVR] Fix stack overflow while trying to get play resume point from PVR client
Build Highlights:
- Fix stack overflow while trying to get play resume point from PVR client
- Bump various packages (mysql, sqlite, etc.)
Build Details:
- LibreELEC.tv:
- remove tbs support (PR:1074, 2 commits, 6 files changed)
- chromium: updated default.py to allow installing flash (afc16497)
- XBMC:
- Fix for deadlock in AlarmClock (PR:11214, 1 commit, 1 file changed)
- [jsonrpc] bump version to 8.0.0 (PR:10639, 1 commit, 1 file changed)
- log: Don't force logging with a debug build (PR:11080, 1 commit, 1 file changed)
- pvr.dvbviewer:
- Add appveyor (ab66d610)
- Add support for on-pause/on-demand timeshifting (2b8ab246)
- newclock5:
- New commits in this build:
- [cec] Drop CEC_DOUBLE_TAP_TIMEOUT_MS_OLD code (2cfd683e)
(2016-12-17, 04:46)smp1 Wrote: [ -> ]I'm getting some random live TV video corruption (green artefacts) with # 1216. Using the latest VDR.
I still see this with #1219. Also, I noticed that I get a lot of video corruption when transferring data (e.g. copying a file to an sd card over LAN) - even when the deinterlacing is disabled.
bmonster PR11223 in latest build should fix your PVR startup problems. Can you please test and report back?
(2016-12-20, 07:24)smp1 Wrote: [ -> ] (2016-12-17, 04:46)smp1 Wrote: [ -> ]I'm getting some random live TV video corruption (green artefacts) with # 1216. Using the latest VDR.
If you revert to #1215 does the problem go away?
(2016-12-20, 08:25)ksooo Wrote: [ -> ]@bmonster PR11223 in latest build should fix your PVR startup problems. Can you please test and report back?
Hi Ksooo,
Yep that fixed it, been running all night without any problems.
Thanks and Regards
Bucky..
(2016-12-20, 14:22)popcornmix Wrote: [ -> ] (2016-12-20, 07:24)smp1 Wrote: [ -> ] (2016-12-17, 04:46)smp1 Wrote: [ -> ]I'm getting some random live TV video corruption (green artefacts) with # 1216. Using the latest VDR.
No. #1214 is the last good one. Could this be due to a new 4.9.0 kernel?
(2016-12-20, 16:09)smp1 Wrote: [ -> ]No. #1214 is the last good one. Could this be due to a new 4.9.0 kernel?
It is possible. Can you test #1213x from here:
http://forum.kodi.tv/showthread.php?tid=...pid2478312
That should narrrow down if it's a kernel issue or not.
Is it just live TV that fails or do you see corruption from previously good recordings?
Where is the TV backend? On the same Pi or another machine on network?
(2016-12-20, 17:36)popcornmix Wrote: [ -> ]It is possible. Can you test #1213x from here:
I just did a quick 20 minute test with #1213 (4.8.13 kernel) vs. #1213x (4.9.0 kernel).
#1213x = occasional artifacts on HD channels
#1213 = no issues
There is defititely something funky going on with kernel 4.9.0. It looks like it put more strain on the Pi which results in video artifacts when watching live HDTV.
Quote:Is it just live TV that fails or do you see corruption from previously good recordings?
I didn't mess with the recordings yet.
Quote:Where is the TV backend? On the same Pi or another machine on network?
On the same Pi.
