(2019-02-06, 10:21)Akirafubuki Wrote: [ -> ]Yes i have bluetooth activated. Maybe refreshing for new devices is causing the problem.
Can you try disabling Bluetooth and confirm if the problem continues?
Hi. Milhouse!
Yesterday 02/05 I was still able to play videos from Amazon Prime. I also borrowed a video from Amazon and started to watch it.
I today wanted to finish it but it didn't play. I tried to start from the beginning but it didn't work either.
I then tried to play a video that is included in my Prime account - same issue.
Please check
http://ix.io/1AmG for the debug log.
Thanks,
Raoul
Tested. I confirm that bluetooth is the cause. Disabled no problem. Enabled after 10 seconds the problems start. Tested in build #0205.
(2019-02-06, 22:16)raoulbhatia Wrote: [ -> ]Hi. Milhouse!
Please check http://ix.io/1AmG for the debug log.
Thanks,
Raoul
What changed between the video working, and not working - did you upgrade the LibreELEC version, or Amazon add-on? Looking at your log, the video cannot be accessed:
text:
21:11:19.504 T:1516065648 DEBUG: CurlFile::Open(0x59423990) https://9s3.lvlt.dash.eu.aiv-cdn.net/d/2$ZBPlgVbPsIFrAg2ypdPQjw18gZE/prod/db16/ba4b/9709/43f9-88b5-d7f3224e86d1/0a80d1fc-e662-4f4b-a1da-dcbc2fe3aa53_video_11.mp4
21:11:19.637 T:1516065648 ERROR: AddOnLog: InputStream Adaptive: Download https://9s3.lvlt.dash.eu.aiv-cdn.net/d/2$ZBPlgVbPsIFrAg2ypdPQjw18gZE/prod/db16/ba4b/9709/43f9-88b5-d7f3224e86d1/0a80d1fc-e662-4f4b-a1da-dcbc2fe3aa53_video_11.mp4 failed with error: 403
21:11:19.637 T:1516065648 ERROR: AddOnLog: InputStream Adaptive: Unable to select stream!
21:11:19.638 T:1507672944 DEBUG: CurlFile:arseAndCorrectUrl() adding custom header option 'Range: bytes=0-1629'
Amazon Prime Instant is working for me (both movies and tvshows) on RPi3+ with #0205 so if your problem continues I suggest you contact your Amazon add-on maintainer.
(2019-02-06, 22:18)Akirafubuki Wrote: [ -> ]Tested. I confirm that bluetooth is the cause. Disabled no problem. Enabled after 10 seconds the problems start. Tested in build #0205.
Thanks, will look in to i!
(2019-02-06, 22:40)Milhouse Wrote: [ -> ]What changed between the video working, and not working - did you upgrade the LibreELEC version, or Amazon add-on? Looking at your log, the video cannot be accessed:
text:
Initially, I didn't change anything. The build I was using yesterday and when I again tried today was #0201. However, I cannot tell if an addon was updated while I was not "watching".
Yeah, I saw the 403 error. However, (a) I can play the video fine from my laptop and (b) if I try to play a free video ("Die Taschendiebin") I get audio but no picture. Perhaps the problem is more related to InputStream Adaptive?
Thanks for your swift reply!
Raoul
New LibreELEC.tv Leia build #0206:
RPi /
RPi2
(Supercedes previous build)
SHA256 Checksum:
c019d431d89c2aa6a3d0be4269ff1de22030a851102ebc075a4c52392c45b008
(RPi)
SHA256 Checksum:
a72694785d8d98bb31a57b3e0bd461e015ac6a1c49397b61c3b28359e7f0a182
(RPi2)
text:
# uname -a
Linux rpi512 4.19.19 #1 Wed Feb 6 21:05:54 GMT 2019 armv6l GNU/Linux
# vcgencmd version
Jan 22 2019 16:54:23
Copyright © 2012 Broadcom
version 7bfabcecab2918f85a2a217b389e256eac696962 (clean) (release) (start_x)
# lsb_release
LibreELEC (Milhouse): devel-20190206210434-#0206-g974f4cb [Build #0206]
# Kodi version
(18.1-RC1 Git:7001c65). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (974f4cb,
changelog) and tip of
XBMC master (7001c65,
- Includes newclock5 patches
- Includes latest commits from kernel branch rpi-4.19.y
- Includes latest bcm2835-driver master (ea3841a, ahead +1)
- Includes latest kodi-platform master (e8574b8)
- Includes latest libcec master (3bbd432)
- Includes latest libnfs master (9e031df, ahead +1)
- Includes latest p8-platform master (1eb12b1)
- Includes latest addons: inputstream.adaptive (0987a13, +1), inputstream.rtmp (ce7f559), peripheral.joystick (1fe4483, +1), peripheral.xarcade (f09a0e7), pvr.argustv (83aa1e9), pvr.demo (964686d), pvr.dvblink (d0bd868, +2), pvr.dvbviewer (1ff63d4), pvr.filmon (e850633), pvr.hdhomerun (a9d7309), pvr.hts (e394c79, +3), pvr.iptvsimple (73feb2f), pvr.mediaportal.tvserver (931afab), pvr.mythtv (3c104f7, +9), pvr.nextpvr (78c6633), pvr.njoy (4467cac), pvr.octonet (203f800), pvr.pctv (b60b971), pvr.stalker (d0170c5), pvr.teleboy (1956113), pvr.vbox (ea20464), pvr.vdr.vnsi (cbb75ab), pvr.vuplus (bb6babc), pvr.wmc (7b28be3), pvr.zattoo (c6ff1d2, +4), vfs.libarchive (6d39012), vfs.rar (45a0cec, +2), vfs.sftp (6749200)
- Include [env] compare (perma): TESTING: increase timeout to ensure OS is able to create core dump/crash log
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: kodi: use upstream repo for Milhouse RPi builds
- Include [env] patch: Bump devel packages, add multi-threaded buildsystem
- Include [env] patch: kodi: remove annoying, excessively repetitive addon logging
- Include [env] patch: rev hack for kodi
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, peripheral.joystick/xarcade, other)
- Include [env] PR:3238 (perma): kodi/openssl: fix crash using vfs.sftp
- Include [env] PR:3260 (perma): linux (RPi/Generic): update to linux-4.19.20
- Include [env] PR:3282 (perma): mesa: update to mesa-18.3.3
- Include [env] PR:3284 (perma): libva: update to libva-2.4.0
- Include [env] PR:3289 (perma): linux: add patch to fix Zotac IR remotes
- Include [env] PR:3290 (perma): openssl: update SSL CA trust store (sync with Kodi PR15441
- Include [pkg] PR:177 (perma): Recording edls (pvr.vuplus)
- Include [pkg] PR:14571 (perma): Remove ARB postfix from GL functions
- Include [pkg] PR:15164 (perma): TexturePacker: Fix memory / resource leak the ugly way
- Include [pkg] PR:15355 (perma): [JSON]Speed up Player and Playlist operations
- Include [pkg] PR:15356 (perma): Optimize locking in ApplicationMessenger
- Include [pkg] PR:15434 (perma): [python] fix usage of line-breaks in ok dialog
Build Highlights:
- update SSL CA trust store
- [PVR] Fix CPVRTimers::GetRecordingTimerForRecording to respect timer'
- [python] fix usage of line-breaks in ok dialog
Build Details:
- XBMC:
- [PVR] Fix CPVRTimers::GetRecordingTimerForRecording to respect timer' (PR:15443, 1 commit, 1 file changed)
- update SSL CA trust store (PR:15441, 1 commit, 1 file changed)
- Fix absurd Announcement Manager locking (PR:15341, 1 commit, 2 files changed)
- [Binary Addon] Provide instance version when creating AddonInstance (PR:15369, 1 commit, 5 files changed)
- [Android] Fix invalid PTS decoder value (PR:15445, 1 commit, 1 file changed)
- [Android] Fix invalid PTS decoder value (fix) (PR:15448, 1 commit, 1 file changed)
- pvr.dvblink:
- Version 4.7.1 - Added option to change default record show type (PR:111, 1 commit, 7 files changed)
- pvr.hts:
- Fix missing description in the EPG and DVR (PR:401, 3 commits, 3 files changed)
- kernel 4.19.y:
- New commits in this build:
- ASoC: pcm512x: Fix a double unlock in pcm512x_digital_mute() (e9ec52ce)
- usb: dwc_otg: Clean up build warnings on 64bit kernels (2dd63087)
- usb: dwc_otg: Use dma allocation for mphi dummy_send buffer (0fbb43f3)
- staging: vchiq_arm: Set up dma ranges on child devices (3595422c)
- staging: vc-sm-cma: Correct DMA configuration. (72025c85)
- staging: vc-sm-cma: Use a void* pointer as the handle within the kernel (36821cb6)
- staging: vc-sm-cma: Fix up for 64bit builds (8718503e)
- Updated: [env] patch: Bump devel packages, add multi-threaded buildsystem
- Updated: [env] PR:3260 (perma): linux (RPi/Generic): update to linux-4.19.20
- Added: [env] PR:3290 (perma): openssl: update SSL CA trust store (sync with Kodi PR15441
- Updated: [pkg] PR:177 (perma): Recording edls (pvr.vuplus)
- Updated: [pkg] PR:15355 (perma): [JSON]Speed up Player and Playlist operations
- Added: [pkg] PR:15434 (perma): [python] fix usage of line-breaks in ok dialog
(2019-02-07, 00:06)raoulbhatia Wrote: [ -> ]Perhaps the problem is more related to InputStream Adaptive?
Raoul
Yes, I would say so.
I tried the latest Amazon Prime Instant on my Revo 3700 (x86_64, Nvidia ION2) with #0205 and for movies I have only audio (no video), but for tvshows I have both audio and video (ie. working fine). Yet with RPi3+, both movies and tvshows are working normally.
Whether this is an Amazon or inputstream.adaptive issue I don't really know, but I feel it's unlikely to be a LibreELEC specific issue. Probably best to open an issue on inputstream.adaptive.
Hi komerdoor,
I just updated to Libreelec 9.0 and along with using Piano DAC 1.1 and Kali Reclocker I just got hit by the noise issue.
You stated that changing from 24 bit to 32 bit output can fix this. However I don't know where in Libreelec or ALSA I can do this change. Can you help me with this?
Thomas
(2019-02-07, 16:18)thomas_-_s Wrote: [ -> ]Hi komerdoor,
Thomas
With my post I was referring to the post
https://forum.kodi.tv/showthread.php?tid...pid2761360, written by user
komerdoor. But of course I am happy to get help from anyone :-)
Pardon me if this is a dumb question, but I can't seem to track down the answer. I've been using these builds on RPi3 for a while now as I needed the Leia functionality to get Netflix to work (if I remember correctly). Currently I'm using #1219; I've not been updating automatically or just for the sake of it, but only if something appeared to be amiss.
I see now that LibreELEC (Leia) 9.0.0 Official has now been released in the last few days (2019-02-02), but I can't find anything in this forum about that, which seems odd. Why are these testbuilds still being released if this version is now the official one?
Bottom line – should I switch to official, and if so, can I and should I do so without doing a fresh install?
Thanks for any assistance.
(2019-02-07, 19:00)atatdotdot Wrote: [ -> ]I see now that LibreELEC (Leia) 9.0.0 Official has now been released in the last few days (2019-02-02), but I can't find anything in this forum about that, which seems odd. Why are these testbuilds still being released if this version is now the official one?
These testbuilds will continue until Kodi branches Leia and opens master for Kodi 19, at which point this thread will be closed and a new Kodi 19/LibreELEC 10 thread created.
(2019-02-07, 19:00)atatdotdot Wrote: [ -> ]Bottom line – should I switch to official, and if so, can I and should I do so without doing a fresh install?
Up to you, yes you can, and yes that should work.
New LibreELEC.tv Leia build #0207:
RPi /
RPi2
SHA256 Checksum:
db7267a439b45b841352fff8e7d7f887eab8fca0d321ceee77c033bd44839355
(RPi)
SHA256 Checksum:
7224541f8b2ea017f5272644b91219c873cd5e7560ea853bf4a56da26cef5cc6
(RPi2)
text:
# uname -a
Linux rpi512 4.19.19 #1 Thu Feb 7 21:05:56 GMT 2019 armv6l GNU/Linux
# vcgencmd version
# lsb_release
LibreELEC (Milhouse): devel-20190207210436-#0207-gbd32e40 [Build #0207]
# Kodi version
(18.1-RC1 Git:fee3771). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (bd32e40,
XBMC master (fee3771,
- Includes latest addons: inputstream.adaptive (0987a13, +1), inputstream.rtmp (ce7f559), peripheral.joystick (1fe4483, +1), peripheral.xarcade (f09a0e7), pvr.argustv (83aa1e9), pvr.demo (964686d), pvr.dvblink (d0bd868, +2), pvr.dvbviewer (1ff63d4), pvr.filmon (e850633), pvr.hdhomerun (a9d7309), pvr.hts (e394c79, +3), pvr.iptvsimple (73feb2f), pvr.mediaportal.tvserver (931afab), pvr.mythtv (c954c7e, +10), pvr.nextpvr (78c6633), pvr.njoy (4467cac), pvr.octonet (203f800), pvr.pctv (b60b971), pvr.stalker (d0170c5), pvr.teleboy (1956113), pvr.vbox (ea20464), pvr.vdr.vnsi (cbb75ab), pvr.vuplus (253f5d8, +12), pvr.wmc (7b28be3), pvr.zattoo (c6ff1d2, +4), vfs.libarchive (6d39012), vfs.rar (45a0cec, +2), vfs.sftp (6749200)
- Include [pkg] PR:182 (perma): Crash loop fix (pvr.vuplus)
Build Highlights:
- [sqlite] Use extended result codes
- [PVR] Ignore very first 'server not reachable' notification.
- [guiinfo] Fix ListitemAbsolute and ListItemPosition
- Crash loop fix (pvr.vuplus)
Build Details:
- LibreELEC.tv:
- linux: add patch to fix Zotac IR remotes (PR:3289, 2 commits, 5 files changed)
- [le9.0] add patch to fix Zotac IR remotes (PR:3292, 2 commits, 5 files changed)
- XBMC:
- [sqlite] Use extended result codes (PR:15232, 4 commits, 1 file changed)
- [PVR] Ignore very first 'server not reachable' notification. (PR:15449, 1 commit, 1 file changed)
- [guiinfo] Fix ListitemAbsolute and ListItemPosition (PR:15450, 2 commits, 1 file changed)
- [Android] Fix MediaCodec freeze when early disposing stream (PR:15455, 1 commit, 1 file changed)
- [addons] add for test purpose only a script for debian package generation (PR:15438, 1 commit, 1 file changed)
- [win32] don't react on DPI change event on Win10 >= FCU (PR:15460, 2 commits, 7 files changed)
- pvr.mythtv:
- pvr.vuplus:
- Recording edls (PR:177, 12 commits, 35 files changed)
- kernel 4.19.y:
- configs: Add Unicam and subdevices to bcmrpi3_defconfig (ceeb3a97)
- configs: Add VIDEO_BCM2835 to bcmrpi3_defconfig (c03af728)
- configs: Add V4L2 codec driver to bcmrpi3_defconfig (ff2a3f88)
- config: Add IPVLAN module to bcmrpi3_defconfig (4d167444)
- Added: [pkg] PR:182 (perma): Crash loop fix (pvr.vuplus)
Milhouse
I'm curious if there is substantial benefit to reinstalling my devices with LE9 proper versus leaving them on your builds?
(2019-02-08, 23:55)nonJon Wrote: [ -> ]@Milhouse
Switching to the official release means you'll be on a stable version suitable for long-term use, so if that appeals to you then go for it. The builds in this thread are test builds, intended to be updated regularly, and may be unstable from time to time. Now that Kodi 18 is winding down there's less of a difference between these builds and official releases but that should change again once Kodi 19 starts.
