(2017-09-22, 04:04)Milhouse Wrote: [ -> ]I've noticed something similar when "unpausing" a video, but in my case (RPi3 into computer monitor with 2.0 channel audio) after unpausing a video I sometimes hear a brief burst of white noise (or "click"), and then all audio is lost until playback is ended. It can also happen when starting playback. Seems to affect most videos - h264, hevc - with 2.0 or 5.1 audio but I couldn't trigger it on a VC-1 video with TrueHD audio.
I believe it started with #0910.
Can you confirm "ActiveAE - large audio sync error" does not appear in debug log? (it didn't for pyrodex so I'm assuming that part of PR12785 is not to blame).
(2017-09-22, 13:01)popcornmix Wrote: [ -> ]Can you confirm "ActiveAE - large audio sync error" does not appear in debug log? (it didn't for pyrodex so I'm assuming that part of PR12785 is not to blame).
It doesn't appear to be there.
This is a debug log:
http://sprunge.us/BiVE
I pressed PlayPause several times until I lost audio between these two key presses:
12:07:44.245 T:1943306352 DEBUG: OnKey: homepage (0xea) pressed, action is PlayPause
<"click" heard, then audio lost>
12:07:46.994 T:1943306352 DEBUG: OnKey: guide (0xe0) pressed, action is Stop
GUI sounds are working normally after playback is stopped.
In case it is my computer monitor freaking out I tried powering it off after audio is "lost", and then back on again while the video continues to play, but audio is not restored.
I checked "vcdb log msg" (
http://sprunge.us/efjd) but don't see anything being added there at the time of the "click".
I've been able to reproduce and have pushed a minimal revert of PR12785 to newclock5. Does that fix it for you?
I just noticed another quirk/bug but it is more in Kodi.
I have a show that is partially watched, 15:42s remaining of 22:03s, and Kodi correctly identifies it as so but in the show list when I filter on UnWatched it is not showing up. Only when I change the filter to Watched (Unexpected) or All Videos (Expected) it shows up. This used to be previous behavior but not sure when this fully happened since I regularly clean out my shows when they are finished being watched.
(2017-09-22, 13:26)popcornmix Wrote: [ -> ]I've been able to reproduce and have pushed a minimal revert of PR12785 to newclock5. Does that fix it for you?
Thanks - that's fixed it!
Hi Milhouse,
a quick question: do your builds already include support for the xbox usb tuner (as discussed (in German) at
kodinerds)?
Cheers,
chessplayer
(2017-09-22, 14:47)chessplayer Wrote: [ -> ]Hi Milhouse,
a quick question: do your builds already include support for the xbox usb tuner (as discussed (in German) at kodinerds)?
Cheers,
chessplayer
No it's not in these builds, as we've
made the decision not to take this patch into LE master at this time, mainly because we're trying to avoid intrusive kernel patches like this as they almost always break with new kernels. It has however been merged in LE8.2 since the kernels in that branch are stable.
The hope is that the Xbox tuner patch will make its way into the mainline linux media_tree, and we'll pick it up once that happens.
(2017-09-22, 15:18)Milhouse Wrote: [ -> ]The hope is that the Xbox tuner patch will make its way into the mainline linux media_tree, and we'll pick it up once that happens.
Ok, thanks, understood. Seems like an inexpensive and promising piece of HW, although it will never match the Sundtek Sticks w.r.t quality (which obviously has its price as well).
New LibreELEC.tv Leia build #0922:
RPi /
RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.13.3 #1 Sat Sep 23 03:05:51 BST 2017 armv6l GNU/Linux
# vcgencmd version
Sep 12 2017 15:25:20
Copyright (c) 2012 Broadcom
version 3fbb171d1950eb3789eb8e37ba11e01079a37239 (clean) (release)
# lsb_release
LibreELEC (Milhouse): devel-20170923030442-#0922-g5ab8b2a [Build #0922]
# Kodi version
(18.0-ALPHA1 Git:f97ea3c). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (5ab8b2a,
changelog) and tip of
XBMC master (f97ea3c,
- Includes newclock5 patches
- Excludes the LibreELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.13.y
- Includes latest bcm2835-driver master (eb04fcf, ahead +5)
- Includes latest kodi-platform master (36fb493)
- Includes latest libcec master (8adc786, ahead +26)
- Includes latest libnfs master (3ba2a2c, ahead +101)
- Includes latest p8-platform master (a822e19)
- Includes latest addons: inputstream.adaptive (dde3921, +12), inputstream.rtmp (e094fa3), peripheral.joystick (cc14287), pvr.argustv (23cc0e8), pvr.demo (122dedd), pvr.dvblink (816f90c), pvr.dvbviewer (8741c8b), pvr.filmon (34dca04), pvr.hdhomerun (ace19fa), pvr.hts (53118d8), pvr.iptvsimple (ac4f4bd), pvr.mediaportal.tvserver (c86ab35), pvr.mythtv (b46e5be), pvr.nextpvr (03933e9, +3), pvr.njoy (cc1cb56, +1), pvr.octonet (a77cf11), pvr.pctv (549f690), pvr.stalker (e15edca), pvr.teleboy (8280157, +16), pvr.vbox (ff01396, +1), pvr.vdr.vnsi (f3f80d5, +1), pvr.vuplus (5e154bc, +4), pvr.wmc (7e2cb4b, +1), pvr.zattoo (d2ba3cc, +10)
- Include [env] 22775c5: include crazycat dvb drivers addon in image
- Include [env] compare: dmidecode: initial package
- Include [env] compare: kodi updates (ffmpeg-3.3.4)
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: libcec: don't link non-existant libtinfo
- Include [env] patch: rev hack for kodi
- Include [env] patch: tvheadend42: fix makefile patch
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, other)
- Include [env] patch: pvr addons: disable broken addons
- Include [env] PR:1776: Don't cause system to hang on halt/reboot when net-booting
- Include [env] PR:1791: nss/nspr: include in main image [rfc]
- Include [env] PR:1835: add support for optional kernel modules in image and from addons
- Include [env] PR:1978: linux: update to linux-4.13.4
- Include [env] PR:2002: linux: include HBR and ELD fixes for Intel
- Include [pkg] patch: skin.estuary: reduce system info font size (kodi)
- Include [pkg] PR:234: implement intensity compensation for VC-1 decoding for Ivybridge and better (intel-vaapi-driver)
- Include [pkg] PR:260: Fix Seeking with VC1 after 6702b01ee3598017f05374bfc7956493f790361c (intel-vaapi-driver)
- Include [pkg] PR:12823: [PVR] Fix channel OSD dialog channel preselection.
Build Highlights:
- New 4.13.3 kernel
- [PVR] Fix channel OSD dialog channel preselection.
- Fix silence after unpausing
Build Details:
- LibreELEC.tv:
- linux: update amlogic-3.14 kernel to 3.14-c8c32b4 (PR:2023, 1 commit, 1 file changed)
- wpa_supplicant: change url (PR:2028, 1 commit, 1 file changed)
- squashfs: change upstream, update to squashfs-1a6ffc7, add zstd support (PR:1992, 3 commits, 4 files changed)
- XBMC:
- AE: fix pause bursts (PR:12820, 1 commit, 4 files changed)
- ActiveAE: Fix up bytes skipped in SyncStream (PR:12824, 1 commit, 1 file changed)
- [skin.estouchy] PVR Guide fix (PR:12815, 1 commit, 3 files changed)
- inputstream.adaptive:
- [ISM] force secure decoder (android) (dde3921)
- pvr.zattoo:
- Fix selection of Quickline and crash while loading epg (d2ba3cc)
- newclock5:
- New commits in this build:
- ActiveAE: Revert SyncStream change 1 (b0f85467)
- Added: [pkg] PR:12823: [PVR] Fix channel OSD dialog channel preselection.
(2017-09-22, 18:18)chessplayer Wrote: [ -> ] (2017-09-22, 15:18)Milhouse Wrote: [ -> ]The hope is that the Xbox tuner patch will make its way into the mainline linux media_tree, and we'll pick it up once that happens.
Just one more thing: I just got the tuner this morning, plugged it into an RPi3 with the official LibreELEC Beta (8.1.1) and, like they
announced on their blog, it worked. So, I am afraid I do not fully understand the decision you guys took not to include it, but you seem to know what you are doing, so I respect that.
(2017-09-23, 11:38)chessplayer Wrote: [ -> ]So, I am afraid I do not fully understand the decision you guys took not to include it, but you seem to know what you are doing, so I respect that.
I thought I explained in my post. The LE 8.2 kernel is stable, while master is not. Supporting out-of-tree kernel patches with unstable (ie. constantly changing) kernels is a support headache. We decided to include the Xbox patch in LE 8.2 as a one-off decision as the expectation is that the Xbox driver will merge upstream before LE9.
(2017-09-23, 11:45)Milhouse Wrote: [ -> ] (2017-09-23, 11:38)chessplayer Wrote: [ -> ]So, I am afraid I do not fully understand the decision you guys took not to include it, but you seem to know what you are doing, so I respect that.
You did indeed and it now made its way into my brain as well. Sorry about that!
With the latest Milhouse-builds (tested 1509 and above) I have a problem installing game addons.
11:38:37.579 T:1855976336 ERROR: CAddonInstallJob[game.libretro.gambatte]: Die Abhängigkeit auf kodi.binary.global.main in Version 1.0.11 konnte nicht aufgelöst werden.
Is this a known issue with Milhouse builds and I have to use garbears builds?
There is a thread also here, but no one had posted a solution yet
https://forum.kodi.tv/showthread.php?tid...pid2647705
Thx for the answer
(2017-09-23, 13:38)Solo0815 Wrote: [ -> ]Is this a known issue with Milhouse builds and I have to use garbears builds?
Yes, game addons are broken since #0914 introduced more addon API changes. The game addons (and probably most others) need to be rebuilt.
New LibreELEC.tv Leia build #0923:
RPi /
RPi2
# uname -a
Linux rpi512 4.13.3 #1 Sat Sep 23 21:55:12 BST 2017 armv6l GNU/Linux
# vcgencmd version
# lsb_release
LibreELEC (Milhouse): devel-20170923215403-#0923-gea8fa96 [Build #0923]
# Kodi version
(18.0-ALPHA1 Git:ec3fc3d). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (ea8fa96,
XBMC master (ec3fc3d,
- Includes latest addons: inputstream.adaptive (dde3921, +12), inputstream.rtmp (e094fa3), peripheral.joystick (cc14287), pvr.argustv (23cc0e8), pvr.demo (122dedd), pvr.dvblink (816f90c), pvr.dvbviewer (8741c8b), pvr.filmon (34dca04), pvr.hdhomerun (ace19fa), pvr.hts (53118d8), pvr.iptvsimple (ac4f4bd), pvr.mediaportal.tvserver (c86ab35), pvr.mythtv (b46e5be), pvr.nextpvr (03933e9, +3), pvr.njoy (cc1cb56, +1), pvr.octonet (a77cf11), pvr.pctv (549f690), pvr.stalker (e15edca), pvr.teleboy (8280157, +16), pvr.vbox (ff01396, +1), pvr.vdr.vnsi (f3f80d5, +1), pvr.vuplus (5e154bc, +4), pvr.wmc (7e2cb4b, +1), pvr.zattoo (47cf5db, +11)
- Include [pkg] e5dbcce3: X11: fix getting visual (kodi)
Build Highlights:
- Updated OSD channel preselection PR:12823
Build Details:
- LibreELEC.tv:
- projects/WeTek_Hub: build media support drivers as modules (PR:2029, 2 commits, 2 files changed)
- projects/Odroid_C2: build media support drivers as modules (PR:2031, 2 commits, 2 files changed)
- projects/WeTek_Play_2: build media support drivers as modules (PR:2030, 3 commits, 3 files changed)
- scripts: update checkdeps for openjdk and libjson-perl on Arch (ea8fa96)
- XBMC:
- [addons] add blocked addon call event to prevent problems after disable (PR:12473, 4 commits, 7 files changed)
- VideoPlayer: send cb notifications on exit via a job (PR:12817, 1 commit, 1 file changed)
- pvr.zattoo:
- Added: [pkg] e5dbcce3: X11: fix getting visual (kodi)
