(2018-09-22, 13:23)Milhouse Wrote: [ -> ] (2018-09-22, 12:02)Jezze Wrote: [ -> ]Is that ERROR: AddOnLog: InputStream Adaptive: Unable to load widevine shared library (/storage/.kodi/cdm/libwidevinecdm.so) message libreelec problem or addon problem? I dont have logs yet but i can give it later. Wondering if someone can tell it? Im not sure what version that problem started but worked fine earlier.
Netflix and Amazon both working for me with #0921, widevine loading without a problem, so presumably you don't have a compatible widevine - use the inputstream.helper to maintain your widevine installation.
tl;dr: not a LibreELEC issue.
Thanks for the info. I try update my libreelec to latest soon and test.
#0921 problem with the CPU temperature , every time i watch a 1080p video (mp4,mkv,others), live TV etc. no matter what the extension / codec is, i have the icon that the CPU is overheating, i tested with mmal and OMX , both do the same thing
It didn't do that on every build before theĀ #0921 (all previous firmware are fine)
Hi Popcornmix,
Confirmation that this has fixed the Green/Purple blocks in HEVC video #0921.
3. ffmpeg update - should fix green frames
Thanks very much. :-)
Kevin.
(2018-09-22, 13:27)Jezze Wrote: [ -> ] (2018-09-22, 13:23)Milhouse Wrote: [ -> ] (2018-09-22, 12:02)Jezze Wrote: [ -> ]Is that ERROR: AddOnLog: InputStream Adaptive: Unable to load widevine shared library (/storage/.kodi/cdm/libwidevinecdm.so) message libreelec problem or addon problem? I dont have logs yet but i can give it later. Wondering if someone can tell it? Im not sure what version that problem started but worked fine earlier.
Thats odd. I upgraded to latest version and inputstream.helper is installed but still not working. @
Milhouse, do you have any hints?
(2018-09-22, 16:42)Jezze Wrote: [ -> ]Thats odd. I upgraded to latest version and inputstream.helper is installed but still not working. @Milhouse, do you have any hints?
Without a log I can only suggest you contact the add-on maintainer as widevine is not supported here. It's working for me, so something on your system is not right - I don't know what. Try deleting widevine and install it again using inputstream.helper.
(2018-09-22, 16:00)germa18 Wrote: [ -> ]#0921 problem with the CPU temperature , every time i watch a 1080p video (mp4,mkv,others), live TV etc. no matter what the extension / codec is, i have the icon that the CPU is overheating, i tested with mmal and OMX , both do the same thing
What hardware is this RPi0, RPi1, RPi2, RPi3, RPi3+?
Can you post your config.txt.
Have you tried running
bcmstat.sh Zyed1
and monitored the temperature and event flags during playback? What temps are you seeing?
I have a problem with the VU + / Enigma2 client on two Pi3. From Milhouse test build # 0911 the PVR Manager will not start anymore.
New LibreELEC.tv Leia build #0922:
RPi /
RPi2
(Supercedes previous build)
SHA256 Checksum:
27829d3d1bb114f5887586aa2e240c462956d101ba637ad6c798828b69a428d5
(RPi)
SHA256 Checksum:
4e3b736ad402d2c1e87824e55702cd3969dc44e219eb287f274f5422118383ab
(RPi2)
text:
# uname -a
Linux rpi512 4.18.9 #1 Sat Sep 22 21:06:06 BST 2018 armv6l GNU/Linux
# vcgencmd version
Sep 21 2018 15:48:28
Copyright © 2012 Broadcom
version 07f57128b8491ffdefcdfd13f7b4961b3006d9a9 (clean) (release)
# lsb_release
LibreELEC (Milhouse): devel-20180922210310-#0922-g5ad833b [Build #0922]
# Kodi version
(18.0-BETA3 Git:1a67bd7). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (5ad833b,
changelog) and tip of
XBMC master (1a67bd7,
- Includes newclock5 patches
- Includes latest commits from kernel branch rpi-4.18.y
- Includes latest bcm2835-driver master (404dfef)
- Includes latest kodi-platform master (e8574b8)
- Includes latest libcec master (8adc786)
- Includes latest libnfs master (9454d9f, ahead +9)
- Includes latest p8-platform master (a822e19)
- Includes latest addons: inputstream.adaptive (8d49b9d, +2), inputstream.rtmp (0cc2da1), peripheral.joystick (81fd01a, +1), peripheral.xarcade (91567dd), pvr.argustv (c57a5c4), pvr.demo (481f2fa), pvr.dvblink (72ef8a0), pvr.dvbviewer (dd9c518, +13), pvr.filmon (93ae10d), pvr.hdhomerun (7a607c9), pvr.hts (21d6d70, +1), pvr.iptvsimple (e8effad), pvr.mediaportal.tvserver (b17d5ad), pvr.mythtv (22aa23b), pvr.nextpvr (441edde), pvr.njoy (204d95b), pvr.octonet (1e44819), pvr.pctv (9d95bab), pvr.stalker (2eb66d1), pvr.teleboy (0f3ccfd), pvr.vbox (40ca81f), pvr.vdr.vnsi (bb4fb30), pvr.vuplus (10db232, +14), pvr.wmc (0aea001, +4), pvr.zattoo (8de69a1), vfs.libarchive (f93a5f3), vfs.sftp (e69acc9)
- Include [env] compare (perma): kodi-next
- Include [env] compare (perma): TESTING: increase timeout to ensure OS is able to create core dump/crash log
- Include [env] patch: kodi: use upstream repo for Milhouse RPi builds
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: kodi: remove annoying, excessively repetitive addon logging
- Include [env] patch: rev hack for kodi
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, peripheral.joystick/xarcade, other)
- Include [env] PR:2908 (perma): linux (Generic): update to linux-4.18.9
- Include [env] PR:2913 (perma): linux (RPi): update to linux-4.18.9
- Include [env] PR:2916 (perma): ffmpegx and tvh
- Include [env] PR:2970 (perma): fix crossbuilding heimdal by adding dependency to host-ncurses
- Include [env] PR:2985 (perma): llvm: update to 7.0.0
- Include [env] PR:2986 (perma): cmake: update to cmake-3.12.2
- Include [env] PR:2987 (perma): nano: update to nano-3.0
- Include [env] PR:2990 (perma): mesa: update to mesa-18.2.1
- Include [env] PR:2991 (perma): busybox: drop NFS support for linux < 2.6.23 (enable NFSv4)
- Include [env] PR:2992 (perma): scripts/image: use 256kb blocksize for squashfs images
- Include [env] PR:2993 (perma): Improve fs-resize, fix delay and simplify
- Include [env] PR:2994 (perma): samba-config.service: fix destroying .cache structure
- Include [pkg] PR:14341 (perma): input: libinput: add setting to allow changing keymap layout
- Include [pkg] PR:14460 (perma): [linux] allow overriding the userdata dir
Build Highlights:
- Fix for slow directories
- RetroPlayer fixes/improvements
- link with libnfs instead of loading it dynamic
- scripts/image: use 256kb blocksize for squashfs images
- samba-config.service: fix destroying .cache structure
Build Details:
- LibreELEC.tv:
- scripts/get: wget uses bar indicators (PR:2979, 1 commit, 1 file changed)
- samba: update to samba-4.9.0 (PR:2974, 1 commit, 2 files changed)
- curl: update to curl-7.61.1 (PR:2976, 2 commits, 2 files changed)
- sqlite: update to sqlite-autoconf-3250000 (PR:2977, 1 commit, 1 file changed)
- Update various packages (201809) (PR:2982, 3 commits, 3 files changed)
- XBMC:
- Use Linux Sysfs SoC interface for SystemInfo and CPUInfo (PR:14422, 3 commits, 5 files changed)
- [fix] iterate over reference and only copy the variable if needed (PR:14456, 1 commit, 1 file changed)
- [PVR] Fix accidentally introduced PVR Addon API incompatibility. (PR:14462, 1 commit, 1 file changed)
- Revert "[gui] Show a dvd/bluray icon for dvd/bluray folders." (PR:14461, 1 commit, 2 files changed)
- Game OSD: Show help dialog on first view (PR:14425, 3 commits, 29 files changed)
- RetroPlayer: Improve error message when game.libretro is missing (PR:14427, 1 commit, 4 files changed)
- RetroPlayer: Fix no game input after controller shuts off (PR:14437, 1 commit, 1 file changed)
- link with libnfs instead of loading it dynamic (PR:14450, 2 commits, 13 files changed)
- peripheral.joystick:
- Remove android buttonmaps after breaking android compatibility (PR:150, 1 commit, 13 files changed)
- pvr.vuplus:
- Add autotimers, readonly repeat timers and get drive space (PR:93, 5 commits, 10 files changed)
- Added: [env] PR:2970 (perma): fix crossbuilding heimdal by adding dependency to host-ncurses
- Added: [env] PR:2985 (perma): llvm: update to 7.0.0
- Added: [env] PR:2986 (perma): cmake: update to cmake-3.12.2
- Added: [env] PR:2987 (perma): nano: update to nano-3.0
- Added: [env] PR:2992 (perma): scripts/image: use 256kb blocksize for squashfs images
- Added: [env] PR:2993 (perma): Improve fs-resize, fix delay and simplify
- Added: [env] PR:2994 (perma): samba-config.service: fix destroying .cache structure
Hy all!!
Recently I updated my libreelec running on an rpi3 to leila (kodi 18), yesterday I've tried to play a couple of videos stored on my ssh server in my LAN and I found that no one works..
I've deleted the ssh network locations and i've tried to make from the beginning but i've found that SSH/SFTP are missing in the list of the avaible network protocols: is there a way to reinstall/add them again?
You need to install the VFS SFTP add-on.
I have a problem with Samba. I just cannot connect over my linux system or my smartphone to the rpi3b+ running last build. I cannot say if it worked with other builds cause its a new rpi3b+ . Theres is no change if I set a password or without password. the pi is not sharing any files or dir
(2018-09-23, 13:35)Posti30 Wrote: [ -> ]Log:
https://paste.ubuntu.com/p/sDxpq7qkB5/
Unfortunately there's not much in the log other than:
text:
10:58:30.894 T:1800377200 DEBUG: CFileCache::Open - opening <web/timerlist> using cache
10:58:30.894 T:1800377200 DEBUG: CurlFile::Open(0x72505450) http://192.168.111.26:80/web/timerlist
10:58:31.080 T:1579754352 DEBUG: Thread FileCache start, auto delete: false
10:58:31.081 T:1579754352 INFO: CFileCache:rocess - Source read didn't return any data! Hit eof(?)
10:58:31.131 T:1800377200 INFO: AddOnLog: VU+ / Enigma2 Client: GetHttpXML Got result. Length: 6453
10:58:31.133 T:1800377200 DEBUG: AddOnLog: VU+ / Enigma2 Client: LoadTimers Processing timer 'The Blacklist'
10:58:31.134 T:1579754352 DEBUG: Thread FileCache 1579754352 terminating
10:58:31.141 T:1800377200 ERROR: Process error processing job pvr-startup
If this problem started with #0911, then the obvious candidate is:
(2018-09-11, 22:40)Milhouse Wrote: [ -> ]Build Details:
- pvr.vuplus:
- Added Support for Timer Types, complete with 3 types (PR:90, 1 commit, 9 files changed)
ksooo / @
phunkyfish any ideas?
I deleted the old timers on the backend and it works again.
