Yeah all of my folders are in the Root Movie Folder
vbat99 is there any chance you can add image resizing to episode screenshot, I would like to keep mine to the standard dimension on thetvdb.com, which is 400 x 225 for 16:9 and 400x300 for 4:3, that way I can share the episode screenshots on thetvdb.com without having to batch resize them
(2014-12-16, 20:50)wints Wrote: [ -> ]Yeah all of my folders are in the Root Movie Folder
OK, so its not that issue. Can you post up a link to your config.xml file, or PM me the link, and I'll see if it's a setting issue causing the duplicates.
[quote='Wulfsige' pid='1863296' dateline='1418757004']
@vbat99 is there any chance you can add image resizing to episode screenshot, I would like to keep mine to the standard dimension on thetvdb.com, which is 400 x 225 for 16:9 and 400x300 for 4:3, that way I can share the episode screenshots on thetvdb.com without having to batch resize them
Very valid point. I'll add to the To Do list to have the Screenshot save as original or in TVDB sizing.
(2014-12-16, 21:22)vbat99 Wrote: [ -> ] (2014-12-16, 21:10)Wulfsige Wrote: [ -> ]@vbat99 is there any chance you can add image resizing to episode screenshot, I would like to keep mine to the standard dimension on thetvdb.com, which is 400 x 225 for 16:9 and 400x300 for 4:3, that way I can share the episode screenshots on thetvdb.com without having to batch resize them
This feature will be in next release.
Why is MC not adding media tags to my .nfo and conversely why are they not showing up in MC. I'm having to go in afterwards and hit rescrape media tags.
Hi how can i stop MC making movie collection folders? has some times it puts some of the films in but not all that should be and in other cases it does it correctly. Cheers
(2014-12-19, 09:21)clubwerks Wrote: [ -> ]Why is MC not adding media tags to my .nfo and conversely why are they not showing up in MC. I'm having to go in afterwards and hit rescrape media tags.
What are you scraping? Movies or TV. If it's TV and using XBMC TVDB scraper, then yes, I found an issue with this routine not adding media stream details. Fix is in place for the next release.
If Movies or TV not using XBMC TVDB scraper, then check you have the relevant options selected to include stream details when scraping.
TV ->
Save Media Tags to episode nfo files.
Movies ->
Enable MC to save Media Tags to nfo file.
(2014-12-19, 10:18)wints Wrote: [ -> ]Hi how can i stop MC making movie collection folders? has some times it puts some of the films in but not all that should be and in other cases it does it correctly. Cheers
Change to rename folder option from
%N\%T (%Y) to
%T (%Y)
%N options is to create the collection as part of the folder name, but, with
\, this will create <collection name> as a folder, then <moviename> (<year>) as a subfolder.
(2014-12-19, 19:44)vbat99 Wrote: [ -> ] (2014-12-19, 09:21)clubwerks Wrote: [ -> ]Why is MC not adding media tags to my .nfo and conversely why are they not showing up in MC. I'm having to go in afterwards and hit rescrape media tags.
TV -> Save Media Tags to episode nfo files.
Movies -> Enable MC to save Media Tags to nfo file.
OK, that worked. I was using XBMC scraper. Turning that off fixed the issue.
Next question. How do I get it to show the best audio track first? Thanks!
(2014-12-20, 08:53)clubwerks Wrote: [ -> ]OK, that worked. I was using XBMC scraper. Turning that off fixed the issue.
We don't have a method of selecting which track is best. Only which is the default track.
You could use:
mkvpropedit -- Modify properties of existing Matroska files to change the default track to your preferred track, but you'd have to do that outside of Media Companion.
(gui for mkvpropedit -
http://forum.doom9.org/showthread.php?t=163753 )
Not sure but i am now facing two issues with the new version.
You still cannot change the movie and scrape the information from tmdb, it used to work for few days, but its stopped again.
When the new version was released few days back, and after installing it, my system slowed down, with sever lag.
Norton reported the exe file containing a virus/trojan.
Anyways i had an image copy of my windows with every program installed except media companion, after reflashing the disc the system was back to normal, but again after installing media companion just today from the new version link mentioned by vbat99.. norton reported it as a virus again, but i excluded it from quarntaine and now the same issue has plagued me again, the system has slowed down .
Anyone face this issue?
(2014-12-21, 22:25)MANswers Wrote: [ -> ]Not sure but i am now facing two issues with the new version.
I have been hounding Norton, McAfee, and Avast to validate the files in Media Companion as Safe, even to the point of giving them links to the code...Still no replies.
The warning is a False Positive.
In Avast it says the file is a "Suspected" virus, which means it's smart scanning to guess if a file is infected is being a Bitch!
I have used
VirusTotal to scan all Media Companion files, and there have been no Positive hits. Just the Antivirus being too picky.
OK, as to Change Movie, There is another fix for this already in place for the next release. Hope to have a new release out in the next 24 hrs.
As for system slow-down, sorry, haven't noticed this at all. Running it on three different PC's, Work, Home and a separate PC just for stand-alone testing (ie, no development software, just like average user).
By chance, how much Ram do you have? What sort of size collection of Movies and TV Series/episodes are loaded into Media Companion?
Thanks for the update
I'm testing out the TV screenshot re-sizing and I'm having no luck
I did a fresh install of MC and selected "Save Screenshot in TVDB friendly Size." but it's not re-sizing for me, are there other options I should be setting?
(2014-12-22, 06:55)Wulfsige Wrote: [ -> ]Thanks for the update I'm testing out the TV screenshot re-sizing and I'm having no luck
How are you creating the screenshots?
Just tested with r-click missing thumb preview and selected
Create Episode ScreenShot and also from screenshot tab.
MC saved 720p, 16:9 screenshot at 400x225.
