I Apologize but I am getting quite confused. I think we need to start small so I can get my head around the main issue.
Your last post, you mention
Quote:you can't import correct the tvdb data when a ß is in a title and plot
http://thetvdb.com/?tab=series&id=74638
is only in the plot a ßäö... mc can scrap the series.
Import where? Kodi?
Or is Media Companion not importing the correct character.
What do you mean
Quote:and when you take searching for ß
this is a letter with no lowercase char. only big!
=> From TVDB to MC (series with "ß" in title)
=> When you run search in replace as example in notepad++ to check many files, or when you create regex..
aAbBcC .. small letter and upper-case letter
but the "ß" is only upper-case, no small letter version exists.
i have build a version and create new nfos. it look first okay, after one test...it failed.
Can't MC arrive at a source by reading the media codec, without having the source's name within the filename?
(2015-11-04, 18:22)marhutchy Wrote: [ -> ]Can't MC arrive at a source by reading the media codec, without having the source's name within the filename?
No, Source isn't exactly what is in the media's stream info, but rather where the media was sourced from.
ie: Screener, DVD, Pay-per-view, HDTV, Bluray etc.
Some of the above can have the same resolutions, but from completely different media, and these are usually found in the filename.
(2015-11-04, 19:08)vbat99 Wrote: [ -> ] (2015-11-04, 18:22)marhutchy Wrote: [ -> ]Can't MC arrive at a source by reading the media codec, without having the source's name within the filename?
That's true.
Most of my movies are BRRip, so I can set them manually with ease.
Morning/Afternoon Rob. Wanted to pass on an update to the actor scraping problem I have. I have "download actor images from TMDB" selected. If I re-scrape a movie the images are from TMDB. If I use the context menu and scrape actors IMDB is used. Also, could you explain this a bit more. This still holds true. However, if I switch scraper to IMDB, Scrape, then switch back to TMDB and use the context menu to scrape actors, TMDB is now used. I hope I explained that ok.
Another thing I noticed (might just be me) is artwork download from Fanart.tv is downloading as poster/fanart.jpg. This is my setup:
(2015-11-05, 18:45)bobrap Wrote: [ -> ]Morning/Afternoon Rob. Wanted to pass on an update to the actor scraping problem I have. I have "download actor images from TMDB" selected. If I re-scrape a movie the images are from TMDB. If I use the context menu and scrape actors IMDB is used. Also, could you explain this a bit more. This still holds true. However, if I switch scraper to IMDB, Scrape, then switch back to TMDB and use the context menu to scrape actors, TMDB is now used. I hope I explained that ok.
Gidday
bobrap
The actor issue with rescrape has been fixed, on Wednesday, just after the new release.
Quote:b4b24bfbc4f2
by vbat99
(0 downloads) Wed
10:24 AM
Movie - Fix logic rescrape actors to get correct actor source.
so next release with have that fix in place.
As for Farant.TV artwork, I just checked with the option to save as <moviename>-artwork.extn, and it seems MC is saving it as both
avatar-fanart.jpg and
Will have to check what the heck is going on.
BTW, Artwork Automator, has that been updated to support <moviename>-artwork ??
(2015-11-05, 19:33)vbat99 Wrote: [ -> ] (2015-11-05, 18:45)bobrap Wrote: [ -> ]Morning/Afternoon Rob. Wanted to pass on an update to the actor scraping problem I have. I have "download actor images from TMDB" selected. If I re-scrape a movie the images are from TMDB. If I use the context menu and scrape actors IMDB is used. Also, could you explain this a bit more. This still holds true. However, if I switch scraper to IMDB, Scrape, then switch back to TMDB and use the context menu to scrape actors, TMDB is now used. I hope I explained that ok.
Gidday bobrap
Quote:b4b24bfbc4f2
by vbat99
(0 downloads) Wed
10:24 AM
Thanks for having a look. I don't think artwork downloader has been updated yet.
Found another little glitch. All the artwork from fanart.tv seems to be getting scraped, but, only the set artwork is showing in MC.
Damn, it'll be that option for <moviename>-artwork that I added.
Will have a look.
Oops, seems I missing one location to change the naming of Fanart.TV saved images if we are naming as
Right in the section that downloads and saves the artwork when scraping or re-scraping a movie.
Fix in place for next release.
how do we get the media info of .Iso bluray file? can media companion scan this format or just MKV?
thanks
