2013-01-21, 08:25
(2013-01-21, 05:48)fma965 Wrote: [ -> ]Hmm, so your saying that bug has happened before? Will take another look tomorrow since got plenty of time free currently, if I don't fix it then I skip it and finish the rest, adding frodo support isn't hard but it is time consuming.Maybe; or it could have been something else I've worked on - it's hard to keep track. If you can solve it, that would be grand!
(2013-01-21, 05:48)fma965 Wrote: [ -> ]So what plans are there for media companion?There are no real plans that I know of. I have a couple of ideas of what I would like to do, but most time is spent with bug fixes. Most new stuff is added by newcomers like yourself.
(2013-01-21, 05:48)fma965 Wrote: [ -> ]Also what do you mean by ui merging issues?He he, you'll find out!
The form designer .vb and .resx files tends to differ considerably between systems, OSs, and Visual Studio versions, so what one person submits will be re-written by VS when somebody else works on UI. There is no (practical) way of merging the files directly, so we found the easiest way is for one dev to work on UI stuff at a time. That is why it is so important to rebase before submitting patches. For example, if I had made some changes to the UI and delivered this weekend, then you delivered tomorrow, then most likely my changes would be lost, and I would be annoyed. If I had made changes, and you rebased before delivering, then you would have to figure out how best to merge those changes, and it probably wouldn't go smoothly!
We're not the only project to have this problem, so I'd like to hear how others solve this!
