(2020-07-13, 00:20)Edworld Wrote: [ -> ] (2020-07-13, 00:13)vbat99 Wrote: [ -> ]10000 seconds is 166 minutes. Probably at the end of the movie
I over did a zero, I tried different numbers and none worked.
Just tested with a DVD converted to mkv file, and MC successfully is able to create fanart from the file.
So I'm not sure why this isn't working for you.
What's your Media Companion location on your PC?
Can you change out a different video and test getting fanart from the video file?
Or go to an older MC version.
I may look at updating the ffmpeg in MC to the latest version for the next release also.
(2020-07-14, 12:24)vbat99 Wrote: [ -> ] (2020-07-13, 00:20)Edworld Wrote: [ -> ] (2020-07-13, 00:13)vbat99 Wrote: [ -> ]10000 seconds is 166 minutes. Probably at the end of the movie
I installed 3.7.38 and with same movie, got this error: seqyence contains no elements continue?
MC is installed in c drive.
(2020-07-15, 03:23)Edworld Wrote: [ -> ]I installed 3.7.38 and with same movie, got this error: seqyence contains no elements continue?
Odd, and that error message doesn't mean anything unfortunately.
I'll have a look at getting the latest ffmpeg into MC for the next release, hopefully that will resolve your issue.
Hello Rob,
I was having the idea of moving my all foreign languages movie to a separate location in my drive using the language filter functionality in MC. I figured out that MC has an option called export selected movies and it works like copy and paste functionality. Similarly can we have an option which can work as cut and paste or move functionality. It will be easier to move movies from one location to another rather than selecting one movie and cut paste it to another location.
Thanks John.
(2020-07-23, 13:27)john8546 Wrote: [ -> ]Hello Rob,
Thanks John.
Hi John
The Export function was set as Copy/Paste as a trade off as I did not want Media Companion to Cut and Paste or delete movie(s) and become liable for a movie or movies to go missing or be deleted altogether.
So Copy/Paste will remain, and it is up to the user to check files got copied correctly to the correct location, and then delete the original location.
Hi Rob,
Found I have a problem with the latest version of MC (Media Companion 3.726b x64).
The last couple of movies I have scraped (Set to use imdb) do NOT have a rating or votes field (see below)...
<ratings>
<rating name="imdb" max="10" default="true">
<value>7.8</value>
<votes>1097481</votes>
</rating>
<rating name="metacritic" max="10">
<value>8.3</value>
<votes>35</votes>
</rating>
<rating name="themoviedb" max="10">
<value>7.4</value>
<votes>21726</votes>
</rating>
</ratings>
(Should be here)
<userrating>0</userrating>
<top250>0</top250>
<country>United States</country>
Here is an older file that has the correct fields...
<ratings>
<value>5.7</value>
<votes>40100</votes>
</rating>
<value>4.4</value>
<votes>35</votes>
</rating>
</ratings>
<rating>6.0</rating>
I only picked it up because my older version of Kodi did not display a rating.
I can't remember when I last updated MC, but I have only found two movies like this (the last two I have scraped) - although there was a couple weeks between the last two movies.
Could be user error, but I have scraped a number of movies to try to figure it without success.
Need some help. Thanks muchly
(2020-07-24, 09:10)KidKiwi Wrote: [ -> ]Hi Rob,
<ratings>
<value>7.8</value>
</rating>
<value>8.3</value>
<votes>35</votes>
</rating>
<value>7.4</value>
</rating>
</ratings>
(Should be here)
<top250>0</top250>
<ratings>
<value>5.7</value>
</rating>
<value>4.4</value>
<votes>35</votes>
</rating>
</ratings>
From waaaay back
Quote:MC 3.728b 2019-03-03
New:
MC - Add Option to not save legacy tags <rating>, <votes> & <metascore> in nfo. Default is Enabled.
In Preferences -> Common Settings
Uncheck
Don't save legacy Rating/Votes/Metascore in nfo
Hey Rob,
Thanks for the help.
You know...I actually found that setting before I posted. I deselected it and tried a re-scrape...and I got the same response (no ratings field). Not sure what I did wrong, but now it is working. Must be getting senile.
Cheers
vbat99,
This latest version is no longer scraping art from fanart.tv when I scrape a new movie. If I do rescrape specific, artwork fanart.tv it works.
(2020-08-02, 01:01)Edworld Wrote: [ -> ]vbat99,
I'll look into this in the next couple of day
Finally got five minutes to test fanart.tv for movies, and worked perfectly.
Clearart, logo etc all downloading during scrape of a new movie.
If your using a personal API Key, I'd check its still valid, or apply for a new API Key.
(2020-08-05, 11:14)vbat99 Wrote: [ -> ] (2020-08-02, 01:01)Edworld Wrote: [ -> ]vbat99,
How do I test my key? I logged in fanart and is still listed under my settings.
Quickest test would be remove your API key and test with menu companions built-in key and see if a movie scrapes with fan art .
If that works then you may need to apply for a new api-key period if that does not work then there's another issue going on maybe a firewall blocking you anti-virus or something else .
I hope that help
Hi. How do I enable scraping from TMDb for tv series? I can't find it in TV preferences
(2020-08-13, 03:56)adun79 Wrote: [ -> ]Hi. How do I enable scraping from TMDb for tv series? I can't find it in TV preferences
There are two methods.
1. In Folders, you can select a specific Root folder to be TVDB, or TMDb source for all series found within the Root TV Folder.
2. You can use
F2 to add a new TV Series, there you can select if the series is scraped from TVDB or TMDB.
Current series already scraped from TVDB can not be changed to TMDb.
