Hello,
I have a question about this great skin,
I am using panel with detail view for all movies and series, but only in sets the labels are still visible.
Despite the turn off label setting.
How can i fix that?
Thanks,
Bacardicola
(2020-11-16, 16:43)accacc5 Wrote: [ -> ]Hey Guys,
Any ideas to help in what I want to do?
Cheers.
Hello accacc5
Moving the widget header down would be a huge effort that is not worth it. I find the widget header above is in the right place. But if that helps you can move the widget header to the right or to the middle in the skin setting under "Home Screen Widgets".
(2020-11-18, 18:06)Fuchs2468 Wrote: [ -> ] (2020-11-16, 16:43)accacc5 Wrote: [ -> ]Hey Guys,
Cheers.
Hello accacc5
Hi @
Fuchs2468
I guess you are right about it being a big effort.
Thanks for getting back to me.
Cheers.
(2020-11-17, 17:24)bacardicola Wrote: [ -> ]Hello,
How can i fix that?
Thanks,
Bacardicola
Hello Bacardicola
Replace the file "View_53_PanelDetails.xml" in "\addons\skin.titan.mod.beta.leia\1080i\"
with this:
Then restart and have fun.
(2020-11-18, 18:57)Fuchs2468 Wrote: [ -> ] (2020-11-17, 17:24)bacardicola Wrote: [ -> ]Hello,
How can i fix that?
Thanks,
Bacardicola
Hello Bacardicola
with this: View_53_PanelDetails.xml
Thank you very much, it worked like a charm.
I am having an issue and was wondering if is away to add .3D MVC. to the list of "3D" movies. Right now when I have the files named .3D they show the 3D tags. the .3D MVC. files only show up as Blu-ray. I use TMM to rename my files, and now they tag them as .3D HSBS. or .3D MVC. or .3D TAB. etc.
Example :
The Amazing Spider-Man 2 (2014) - Blu-ray.1080p.3D.DTSHD-MA.6ch.mkv <-- Shows as 3D
Doctor Strange (2016) - Blu-ray.1080p.3D MVC.DTSHD-MA.8ch.mkv <-- Shows as BD
I'm using the Netflix View
Kodi - 17.7 DSPlayer Version (In Portable Mode)
Titan - MOD (Beta) For Krypton - V17.1.11
Windows - Windows 10 x64 1909
(2020-11-20, 19:10)robsch Wrote: [ -> ]I am having an issue and was wondering if is away to add .3D MVC. to the list of "3D" movies. Right now when I have the files named .3D they show the 3D tags. the .3D MVC. files only show up as Blu-ray. I use TMM to rename my files, and now they tag them as .3D HSBS. or .3D MVC. or .3D TAB. etc.
Example :
If you want "3D" to be displayed change the file name to ".3D." around.
So in your example the file should be named like this:
Doctor Strange (2016) - Blu-ray.1080p.3D.MVC.DTSHD-MA.8ch.mkv
(2020-11-20, 22:43)Fuchs2468 Wrote: [ -> ] (2020-11-20, 19:10)robsch Wrote: [ -> ]I am having an issue and was wondering if is away to add .3D MVC. to the list of "3D" movies. Right now when I have the files named .3D they show the 3D tags. the .3D MVC. files only show up as Blu-ray. I use TMM to rename my files, and now they tag them as .3D HSBS. or .3D MVC. or .3D TAB. etc.
Example :
Yea, I just did that, and it works, but when I run TMM, it changes the names back to .3D MVC. (TMM does not allow me to change what I want 3D to tagged as) This is why I was wondering if there was away to add that to a list of what gets tagged.
(2020-11-20, 22:55)robsch Wrote: [ -> ] (2020-11-20, 22:43)Fuchs2468 Wrote: [ -> ] (2020-11-20, 19:10)robsch Wrote: [ -> ]Yea, I just did that, and it works, but when I run TMM, it changes the names back to .3D MVC. (TMM does not allow me to change what I want 3D to tagged as) This is why I was wondering if there was away to add that to a list of what gets tagged.
That looks bad for "Titan-MOD (Beta) For Krypton" there will be no more updates.
It shouldn't be that difficult to replace a space with a dot.
I have problems with auto trailes from widget. On my widget Tv shows (recently added) auto trailer works, but on widget Movies(recently added) they don’t work (manually they work).
Did I miss something or? I have Nvidia shield with plexkodiconnect. I watch my shows and movies through Plex server.
Thank you for your help
I recently set Kodi up with this skin on a new computer, everything done from scratch. I must've stuffed something up somewhere as I'm getting Skin Helper Service Errors on launch. The only problem I've noticed compared to my old setup is I'm not getting a Contextual Menu, that command always launches the sidebar menu. I'm hoping that some smart person can help, debug log file at the link;
https://pastebin.com/Fnw0aKM9
(2020-11-25, 09:55)Wayne33 Wrote: [ -> ]I recently set Kodi up with this skin on a new computer, everything done from scratch. I must've stuffed something up somewhere as I'm getting Skin Helper Service Errors on launch. The only problem I've noticed compared to my old setup is I'm not getting a Contextual Menu, that command always launches the sidebar menu. I'm hoping that some smart person can help, debug log file at the link;
Since you are using an Apple Mac there seems to be an error in script.module.cherrypy.
Test this version.
https://github.com/AnonTester/script.module.cherrypy
(2020-11-26, 19:04)Fuchs2468 Wrote: [ -> ] (2020-11-25, 09:55)Wayne33 Wrote: [ -> ]I recently set Kodi up with this skin on a new computer, everything done from scratch. I must've stuffed something up somewhere as I'm getting Skin Helper Service Errors on launch. The only problem I've noticed compared to my old setup is I'm not getting a Contextual Menu, that command always launches the sidebar menu. I'm hoping that some smart person can help, debug log file at the link;
Test this version. https://github.com/AnonTester/script.module.cherrypy
Thank you very much for your help. That has removed the Skin Helper error but now I get "Remote Communication Server Failed to Start". The contextual menu error is also still present (if that is related). I've posted another log;
https://paste.kodi.tv/hipisugado.kodi
(2020-11-26, 21:23)Wayne33 Wrote: [ -> ] (2020-11-26, 19:04)Fuchs2468 Wrote: [ -> ] (2020-11-25, 09:55)Wayne33 Wrote: [ -> ]I recently set Kodi up with this skin on a new computer, everything done from scratch. I must've stuffed something up somewhere as I'm getting Skin Helper Service Errors on launch. The only problem I've noticed compared to my old setup is I'm not getting a Contextual Menu, that command always launches the sidebar menu. I'm hoping that some smart person can help, debug log file at the link;
Did you use the correct keys "C" for context menu and "M" for options and views.
Test what it shows with the standard skin (Estuary).
(2020-11-26, 23:20)Fuchs2468 Wrote: [ -> ] (2020-11-26, 21:23)Wayne33 Wrote: [ -> ] (2020-11-26, 19:04)Fuchs2468 Wrote: [ -> ]Since you are using an Apple Mac there seems to be an error in script.module.cherrypy.
I was using a remote, which seems to be where the error is as the keyboard commands work correctly. Thanks for solving that, appreciated.
