Hi I want to report this issue that has always been in Leia Skin, but still present in Matrix Alpha, it pertains to
TV Shows ONLY settings
The TV shows settings in force views is as pic1, these settings to some extend often change randomly from Netflix to diff views intermitantly and it will return to Netfix views
Piics 2-4 is fine later it will change pics 5-7 and later it will change to pics 2-4 these can happen randomly
I hope these are issues are resolved in the next version of Titan MOD Matrix
Hello so I am on kodi 18.9 how to go to 19 so as not to have problems with the skin?
(2021-03-18, 01:28)Fuchs2468 Wrote: [ -> ] (2021-03-17, 21:15)kokoplex Wrote: [ -> ]@Fuchs2468 hi,
I got another little thing which doesn't work anymore.
In configure shortcuts settings > set thumbnail or select background don't work.
Whatever the background or thumb chosen, there no effect, thumb or background don't change
Yes this does not work with "matrix" the problem is "skin.helper.service" and not the skin.
But I have found the mistake.
Here is a fast fix for this problem.
Content of "\addons\script.skin.helper.service\resources\lib\skinsettings.py"
Replace with: https://paste.kodi.tv/humelabogu.Kodi
There are also other mistakes related to "skin.helper".
I am working on it.
If I have more time I have to inform "Angelinas" so he can test it.
This worked perfectly for Titan Bingie Mod. Thanks.
I use Titan mod 19.1.19 alpha.1 on Matrix. Does anybody have problems with language flags? For me is not working, when I search for subtitles (opensubtitles or addicted7) there is no flags like it was on Leia. On default Estaury skin flags are working for me.
Can anybody help, because it is difficult to download subtitles without flags...
Thank you !
(2021-03-27, 08:41)simtaj Wrote: [ -> ]I use Titan mod 19.1.19 alpha.1 on Matrix. Does anybody have problems with language flags? For me is not working, when I search for subtitles (opensubtitles or addicted7) there is no flags like it was on Leia. On default Estaury skin flags are working for me.
Thank you !
I had overlooked that at the update.
go to:
"\addons\skin.titan.mod.beta.matrix\1080i\"
and replace the file: DialogSubtitles.xml
With this file:
DialogSubtitles.xml
This applies to the versions Titan.mod 19.1.19 Alpha.1 and Titan.mod 18.1.19 Alpha.1 .
(2021-03-27, 14:56)Fuchs2468 Wrote: [ -> ] (2021-03-27, 08:41)simtaj Wrote: [ -> ]I use Titan mod 19.1.19 alpha.1 on Matrix. Does anybody have problems with language flags? For me is not working, when I search for subtitles (opensubtitles or addicted7) there is no flags like it was on Leia. On default Estaury skin flags are working for me.
Thank you !
go to:
With this file: DialogSubtitles.xml
Can you help me, how to do that. If I go to file manager in Kodi I see only addon_data folder in profile and no addons. Am I doing something wrong?
(2021-03-27, 21:20)simtaj Wrote: [ -> ] (2021-03-27, 14:56)Fuchs2468 Wrote: [ -> ] (2021-03-27, 08:41)simtaj Wrote: [ -> ]Can you help me, how to do that. If I go to file manager in Kodi I see only addon_data folder in profile and no addons. Am I doing something wrong?
I do not know which operating system you use. You must use an external file manager to replace this file.
Or you wait for my new update.
(2021-03-27, 21:36)Fuchs2468 Wrote: [ -> ] (2021-03-27, 21:20)simtaj Wrote: [ -> ] (2021-03-27, 14:56)Fuchs2468 Wrote: [ -> ]
I found it trough PC. Everything ok now. Thank you!
And something more..when I want to change background in widget for example for movies, nothing happens when I press “select background”. Is this bug or it is not working only for me?
Thank you for making this skin to work. Great job!
kodi freezes in some video addons when im using titan matrix skin when I press the stop button while watching a video.
Hi guys, a quick question, I've gone back to 18.9 as using Titan with Matrix is more halter than I have time for at the moment. I'm reinstalling fresh but just want to check; does Titan mod still work ok with Leia?
And the links for the marduk repo and art work beef on the first post seem to be dead, can anyone give me the links for the correct repos and add-ons needed for Titan mod please? Thanks
A huge thanks to everyone concerned for resurrecting this great skin. If an old dumbo like me can install it then you have done wonders,
