(2021-02-24, 04:00)t123thomas Wrote: [ -> ]
The skin searches for locally stored trailers that is actually not an error. An error message is only returned because there is no trailer.
But I could install a switch in the skin with which the search for local trailers can be deactivated.
MardukL has a new repository version you have to update.
Here the link:
https://github.com/marduklev/repository....-1.0.4.zip
(2021-02-23, 21:46)Fuchs2468 Wrote: [ -> ] (2021-02-23, 12:17)Aphykit2006 Wrote: [ -> ]Hi all.
If 'don't use skinhelpersercice ' for mulriple fanart :
Inside infoviews ( movies series or artists)
Do you have a single fanart, multifanart or a black background ??.
I only have a black background ☹️.
This seems to be an older problem that I haven't looked at yet.
Dont Use Skinhelper Service seems to be working.
I won't deal with that until later, however, it doesn't have such a high priority.
Hi
Thank you very much for your answer.
This problem is not very serious, especially since I found an interim solution by modifying the file
IncludesBackgroundBuilding.xml
But I have a static background only and I’m not sure my changes are very good.
I also modified the
View_529_NetflixSeasons.xml file to have a more visible background image.
I tested my color themes and they handle well.
Feel free to incorporate them into the delivery.
Congratulations for the excellent work, I know it is very difficult to resume a program.
So I would wait for a real change when you have time to make it.
Please also keep the horizontal Titan style for the main menu.
If you are open to suggestions, I would like a view for music like the 529_NetflixSeasons view dedicated to series. (I failed so I quit)
A good day
(2021-02-24, 22:57)t123thomas Wrote: [ -> ] (2021-02-24, 11:12)Fuchs2468 Wrote: [ -> ] (2021-02-24, 04:00)t123thomas Wrote: [ -> ]
I looked at your log files and would first recommend a portable installation for kodi to test.
I currently have 6 different Kodi installations to test on my PC, just for information.
If you need help with the portable installation, I would also be happy to write instructions.
What I also saw in your log you are not using any current skin.helper versions
Please install "Marcelveldt's BETA repository" and install all current versions of
script.module.metadatautils
script.skin.helper.backgrounds
script.skin.helper.service
script.skin.helper.skinbackup
script.skin.helper.widgets
and then test again with emby-next-gen.
Has anyone made this skin work with Matrix and if so can you tell me step by step how you did it.
Thanks in Advance for any help.
UbuntuUser
(2021-02-25, 01:59)UbuntuUser Wrote: [ -> ]Has anyone made this skin work with Matrix and if so can you tell me step by step how you did it.
UbuntuUser
looks like its still being worked on
cant wait for it to be available
my stupid google tv auto-updated kodi
now im stuck with the default skin and it sucks
UbuntuUser
Don't panic, the skin works with Matrix
Today I got "script.skin.helper.skinbackup" up and running for matrix.
I just have to test whether it works with Leia.
My matrix version is coming soon.
(2021-02-25, 04:43)Fuchs2468 Wrote: [ -> ] (2021-02-25, 01:59)UbuntuUser Wrote: [ -> ]
All the best.
Desperately awaiting.....
i see some of you have gotten titan mod working on matrix
i have modified the pakage as per 2-3 pages back
but the skin helper service has dependencies
i did get most of them from the link that was posted
but i still cant find a working beautiful soup for matrix
where did those of you who got it working get it from?
(2021-02-25, 04:43)Fuchs2468 Wrote: [ -> ] (2021-02-25, 01:59)UbuntuUser Wrote: [ -> ]Has anyone made this skin work with Matrix and if so can you tell me step by step how you did it.
UbuntuUser
Thanks for the info, Looking forward to the Matrix Version.
UbuntuUser
(2021-02-25, 20:22)charettepa Wrote: [ -> ]i see some of you have gotten titan mod working on matrix
It's in the pack in the post I linked to a ways back.
Skin failed to installed I followed this instructions to change the GUI 5.15.50, please what I have done wrong.
INFO <general>: Loading skin file: DialogConfirm.xml, load type: KEEP_IN_MEMORY
2021-02-25 20:21:05.291 T:4816 INFO <general>: Loading skin file: FileBrowser.xml, load type: KEEP_IN_MEMORY
2021-02-25 20:22:00.325 T:4816 ERROR <general>: CAddonInfoBuilder::ADDON::CAddonInfoBuilder::Generate: Unable to load 'zip://C%3a%5cUsers%5cAdmin%5cDownloads%5cSkin%5cskin.titan.mod.beta.leia-18.1.19%7ealpha.zip/skin.titan.mod.beta.leia-18.1.19~alpha/addon.xml', Line 0
Failed to open file
2021-02-25 20:22:00.329 T:10420 INFO <general>: CActiveAESink::OpenSink - initialize sink
(2021-02-25, 01:37)Fuchs2468 Wrote: [ -> ] (2021-02-24, 22:57)t123thomas Wrote: [ -> ] (2021-02-24, 11:12)Fuchs2468 Wrote: [ -> ]
Thanks, I downloaded the latest version of Marcel Beta repo, so the system runs a better than previous but the errors report previous did not disappeared, I guess once you implement the option to disable trailer this should eliminate the error. I will post additional error if I find them, my focus is test EMBY-NEXT-GEN with Titan to ensure it's working fine
(2021-02-26, 02:15)aerogems Wrote: [ -> ] (2021-02-25, 20:22)charettepa Wrote: [ -> ]i see some of you have gotten titan mod working on matrix
Thanks I found it. I'm up and running.
Sure is nice to be using the Titan skin again.
