(2021-04-23, 00:03)Fuchs2468 Wrote: [ -> ] (2021-04-22, 21:23)t123thomas Wrote: [ -> ]kodi log
I am experiencing some unsual behaviour of the skin the keyboard happen not to respond or act funny at times when I navigate around the skin, which lead to turn on the deburging so I see several errors which I am not sure if they relate to Kodi, or Skin, but when switch the skin to default the issue happens to disappear. Please advice if these error are not Skin related, so I can further post the error in another forum.
INFO <general>: Loading skin file: Home.xml, load type: KEEP_IN_MEMORY
2021-04-22 14:30:25.419 T:8680 ERROR <general>: unmatched parentheses in string.isempty(skin.string(extrafanartdelay)
021-04-22 14:30:35.102 T:10852 ERROR <general>: Exception ignored in:
2021-04-22 14:30:35.102 T:10852 ERROR <general>: <Finalize object, dead>
2021-04-22 14:30:35.102 T:10852 ERROR <general>: Traceback (most recent call last):
2021-04-22 14:30:35.102 T:10852 ERROR <general>: File "C:\Program Files\Kodi\system\python\Lib\multiprocessing\util.py", line 224, in __call__
2021-04-22 14:30:35.103 T:10852 ERROR <general>:
2021-04-22 14:30:35.103 T:10852 ERROR <general>: res = self._callback(*self._args, **self._kwargs)
2021-04-22 14:30:35.103 T:10852 ERROR <general>: File "C:\Program Files\Kodi\system\python\Lib\multiprocessing\pool.py", line 692, in _terminate_pool
2021-04-22 14:30:35.105 T:10852 ERROR <general>:
2021-04-22 14:30:35.105 T:10852 ERROR <general>: cls._help_stuff_finish(inqueue, task_handler, len(pool))
2021-04-22 14:30:35.105 T:10852 ERROR <general>: File "C:\Program Files\Kodi\system\python\Lib\multiprocessing\pool.py", line 945, in _help_stuff_finish
2021-04-22 14:30:35.106 T:10852 ERROR <general>:
2021-04-22 14:30:35.106 T:10852 ERROR <general>: inqueue.get(block=False)
2021-04-22 14:30:35.106 T:10852 ERROR <general>: _queue
2021-04-22 14:30:35.106 T:10852 ERROR <general>: .
2021-04-22 14:30:35.106 T:10852 ERROR <general>: Empty
2021-04-22 14:30:35.106 T:10852 ERROR <general>: :
2021-04-22 14:30:35.107 T:10852 ERROR <general>:
Yes, the mistake is known to me, it is caused by "script.module.cherrypy 12.0.2".
Fast solution Install this version of "script.module.cherrypy".
script.module.cherrypy-11.0.1(matrix).zip
Then the error should be gone.
Hi I downgraded from cherrypy 12 to 11, it errors seems to have gone, however, there seems to be few errors which might relates to the skin or so, I thought I should let know may be its something that you're are aware of and working to resolve.
2021-04-23 13:00:04.799 T:9556 INFO <general>: skin loaded...
2021-04-23 13:00:04.800 T:9556 INFO <general>: Loading skin file: Startup.xml, load type: LOAD_EVERY_TIME
2021-04-23 13:00:04.853 T:9556 WARNING <general>: CApplication::Initialize - startup.xml taints init process
2021-04-23 13:00:04.863 T:9556 WARNING <general>: JSONRPC: Could not parse type "Setting.Details.SettingList"
2021-04-23 13:00:04.863 T:9556 INFO <general>: JSONRPC: Adding type "Setting.Details.SettingList" to list of incomplete definitions (waiting for "Setting.Details.Setting")
2021-04-23 13:00:04.864 T:9556 INFO <general>: JSONRPC: Resolving incomplete types/methods referencing Setting.Details.Setting
2021-04-23 13:00:04.879 T:9556 INFO <general>: JSONRPC v12.2.1: Successfully initialized
2021-04-23 13:00:04.914 T:9556 INFO <general>: Running the application...
2021-04-23 13:00:04.915 T:9556 INFO <general>: Loading skin file: Home.xml, load type: KEEP_IN_MEMORY
2021-04-23 13:00:04.922 T:9556 ERROR <general>: unmatched parentheses in string.isempty(skin.string(extrafanartdelay)
2021-04-23 13:00:04.986 T:9556 WARNING <general>: Trying to add unsupported control type 1
2021-04-23 13:00:05.031 T:2036 INFO <general>: Skipped 1 duplicate messages..
2021-04-23 13:00:16.652 T:9556 INFO <general>: Loading resource://resource.uisounds.kodi/sounds.xml
2021-04-23 13:00:16.680 T:9556 INFO <general>: skin loaded...
2021-04-23 13:00:16.680 T:9556 INFO <general>: Loading skin file: Home.xml, load type: KEEP_IN_MEMORY
2021-04-23 13:00:16.684 T:9556 ERROR <general>: unmatched parentheses in string.isempty(skin.string(extrafanartdelay)
2021-04-23 13:00:16.718 T:9556 WARNING <general>: Trying to add unsupported control type 1
2021-04-23 13:00:16.746 T:8340 INFO <general>: Skipped 1 duplicate messages..
2021-04-23 13:00:16.746 T:8340 INFO <general>: initializing python engine.
2021-04-23 13:00:16.805 T:10744 INFO <general>: Skin Helper Service --> Starting WebService on port 52307
2021-04-23 13:00:16.807 T:8364 INFO <general>: Skin Helper Service --> Skin Helper Service version 1.1.35 started
