I migrated leia to matrix.
Everything work fine except to change view (force view isn't very cool)
But i got another problem in landescape wide view for widget
The landescape be overlaid to next movie like this
In widget settings, layout is landscape wide not use global settings
How can I fix it ?
(2021-03-14, 00:48)kokoplex Wrote: [ -> ]Hi,
How can I fix it ?
yes the skin works in matrix but i cant change view in addon or programs.
(2021-03-14, 09:29)audigy2 Wrote: [ -> ] (2021-03-14, 00:48)kokoplex Wrote: [ -> ]Hi,
How can I fix it ?
That's because of skin helper.
(2021-03-14, 14:58)AchillesPunks Wrote: [ -> ] (2021-03-14, 09:29)audigy2 Wrote: [ -> ] (2021-03-14, 00:48)kokoplex Wrote: [ -> ]Hi,
How can I fix it ?
so skin helper should be updated to support matrix?
(2021-03-15, 07:06)audigy2 Wrote: [ -> ] (2021-03-14, 14:58)AchillesPunks Wrote: [ -> ] (2021-03-14, 09:29)audigy2 Wrote: [ -> ]yes the skin works in matrix but i cant change view in addon or programs.
Yes that is correct. I think we just got my skin able to install through the zip. Thanks to one of the members. He had to update bingie helper for ours.
How can I fix it ?
audigy2
Here is a small update for "Matrix" for download:
skin.titan.mod.beta.matrix-19.1.19~alpha.zip
With this update, the view selection in Matrix is then possible again.
LandesCape Wide works Click "Use Fix Focus" even if switch is on ON.
I still have to revise it.
(2021-03-15, 14:58)Fuchs2468 Wrote: [ -> ]Here is a small update for "Matrix" for download: skin.titan.mod.beta.matrix-19.1.19~alpha.zip
Just wanted to say thanks for continuing to work on this skin. Nice to know that there will be an option to keep using Titan once I decide to move to Matrix.
(2021-03-15, 16:50)aerogems Wrote: [ -> ] (2021-03-15, 14:58)Fuchs2468 Wrote: [ -> ]Here is a small update for "Matrix" for download: skin.titan.mod.beta.matrix-19.1.19~alpha.zip
me too thanks for this update for matrix I think titan is one of the best skins I used in kodi.
(2021-03-15, 14:58)Fuchs2468 Wrote: [ -> ] (2021-03-14, 00:48)kokoplex Wrote: [ -> ]Hi,
How can I fix it ?
@audigy2
Thank you for continuing to work on this great skin!!!
Hi Fuchs2468,
Thanks a lot. You have put in commendable efforts. Kudos to you.
Next, Can this update be installed directly on a fresh Matrix installation or first on Leia and then update to matrix from within kodi.
Thank you!!!!!
Really appreciate your great work - was v anxious about losing this skin with Matrix!
(2021-03-16, 07:35)VikramSandhu Wrote: [ -> ] (2021-03-15, 14:58)Fuchs2468 Wrote: [ -> ] (2021-03-14, 00:48)kokoplex Wrote: [ -> ]
Hi Fuchs2468,
I was able to do a fresh install with the skin on Kodi 19 "Matrix" final. The tricky part is to get Matrix-versions of all the addons that the skin needs, especially skin.helper and skin.shortcuts. You can grab them from here
https://github.com/kodi-community-addons
and here
http://softlibre.unizar.es/kodi/addons/m...shortcuts/
It did not work for me to just unzip and copy those addons into the addons-folder of Kodi. I always had "skin.helper error" oder "skin-shortcuts error" popping up. So I needed to install at least those two addons via "install from zip"-function within Kodi. Then I had no errors anymore. I assume it is about further addons that will be downloaded and actiavted when you install them this way.
As to the skin it seems that all options are working. I was also able to import my old skin settings from Kodi 18 Leia (for colors and design) as well as configure the main menu from scratch (entries, sub-menu, widgets; I did not import them because I heard of compatibility issues of skin.shortcuts). However, I was not able to alter the icons or backgrounds of the menu entries. Besides that everything seems fine for the moment.
(2021-03-17, 17:14)fantasticn Wrote: [ -> ]
(2021-03-15, 14:58)Fuchs2468 Wrote: [ -> ]I was able to do a fresh install with the skin on Kodi 19 "Matrix" final. The tricky part is to get Matrix-versions of all the addons that the skin needs, especially skin.helper and skin.shortcuts. You can grab them from here
and here
Hi fantasticn,
Thank you sir for helping me out.
Just got back home. Shall do it in the morning and update here.
Fuchs2468 hi,
I got another little thing which doesn't work anymore.
In configure shortcuts settings > set thumbnail or select background don't work.
Whatever the background or thumb chosen, there no effect, thumb or background don't change
