(2021-05-24, 20:50)Aphykit2006 Wrote: [ -> ] (2021-05-24, 19:38)simtaj Wrote: [ -> ] (2021-05-20, 00:10)Aphykit2006 Wrote: [ -> ]Correction
I use :
Music : generic scrapers ( better results)
Movies : Universal movies scraper ( python gives rarely clearlogo)
Series : tmdb
Regards
All others you have disabled?
Sorry, i don't understand this question.
Did you all other scrapers disabled or uninstalled? Because I have all installed and enabled ( universal, tmdb, phyton...), is that a problem?
(2021-05-26, 08:22)simtaj Wrote: [ -> ] (2021-05-24, 20:50)Aphykit2006 Wrote: [ -> ] (2021-05-24, 19:38)simtaj Wrote: [ -> ]All others you have disabled?
Hi.
All scraper are installed and configured ( in case of)
One disk ( ressource) = 1 scrapper
Hi Fuchs2468, I noticed that in the Titan MOD Matrix that the shortcut is not working, below is the screen shorts screen from Leia, which works perfectly,
Once you load the shortcut of a node, its associated submenu is also displayed
Here is the displayed on the main screen Kids with associated submenus
Here is the screen shortcut from Titan MOD Matrix notice that each node missing ">" which suggested to me that the codes that drives the submenu are missing or broken.
Please can you fix this issue, and advise when to test the codes
Hi I see this errors, could this Titian MOD skin related issue or something else, please advise
2021-05-27 17:23:38.261 T:4244 ERROR <general>: Traceback (most recent call last):
2021-05-27 17:23:38.261 T:4244 ERROR <general>: File "C:\Program Files\Kodi\system\python\Lib\multiprocessing\util.py", line 224, in __call__
2021-05-27 17:23:38.294 T:4244 ERROR <general>:
2021-05-27 17:23:38.294 T:4244 ERROR <general>: res = self._callback(*self._args, **self._kwargs)
2021-05-27 17:23:38.295 T:4244 ERROR <general>:
2021-05-27 17:23:38.295 T:4244 ERROR <general>: File "C:\Program Files\Kodi\system\python\Lib\multiprocessing\pool.py", line 692, in _terminate_pool
2021-05-27 17:23:38.318 T:4244 ERROR <general>:
2021-05-27 17:23:38.318 T:4244 ERROR <general>: cls._help_stuff_finish(inqueue, task_handler, len(pool))
2021-05-27 17:23:38.318 T:4244 ERROR <general>: File "C:\Program Files\Kodi\system\python\Lib\multiprocessing\pool.py", line 945, in _help_stuff_finish
2021-05-27 17:23:38.318 T:4244 ERROR <general>: inqueue.get(block=False)
2021-05-27 17:23:38.319 T:4244 ERROR <general>: _queue
2021-05-27 17:23:38.319 T:4244 ERROR <general>: .
2021-05-27 17:23:38.319 T:4244 ERROR <general>: Empty
2021-05-27 17:23:38.319 T:4244 ERROR <general>: :
2021-05-27 17:23:40.947 T:2332 INFO <general>: Loading skin file: DialogButtonMenu.xml, load type: KEEP_IN_MEMORY
2021-05-27 17:23:41.011 T:9344 ERROR <general>: Exception ignored in:
2021-05-27 17:23:41.011 T:9344 ERROR <general>: <Finalize object, dead>
2021-05-27 17:23:59.957 T:9120 ERROR <general>: File "C:\Program Files\Kodi\system\python\Lib\multiprocessing\pool.py", line 945, in _help_stuff_finish
2021-05-27 17:23:59.958 T:9120 ERROR <general>:
2021-05-27 17:23:59.958 T:9120 ERROR <general>: inqueue.get(block=False)
2021-05-27 17:24:39.855 T:5824 INFO <general>: CPythonInvoker(19, C:\Users\Admin\AppData\Roaming\Kodi\addons\script.embuary.helper\plugin.py): script successfully run
2021-05-27 17:24:40.014 T:5824 INFO <general>: Python interpreter stopped
2021-05-27 17:24:40.015 T:11064 INFO <general>: CPythonInvoker(20, C:\Users\Admin\AppData\Roaming\Kodi\addons\script.embuary.helper\plugin.py): script successfully run
2021-05-27 17:24:40.162 T:11064 INFO <general>: Python interpreter stopped
2021-05-27 17:24:40.794 T:1224 ERROR <general>: XFILE::CDirectory::GetDirectory - Error getting addons://search/
Hello. I have a Problem with the Skin. I use Kodi Matrix.
If i want see the information of a movie, nothing happens. so i can't open the information screen.
any suggestions for this problem?
(2021-05-27, 23:32)t123thomas Wrote: [ -> ]Hi I see this errors, could this Titian MOD skin related issue or something else, please advise
Please use "script.module.cherrypy-11.0.1", then your mistakes should no longer occur.
"script.module.cherrypy-11.0.1" is available in the "Fuchs repo".
(2021-05-27, 22:41)t123thomas Wrote: [ -> ]Hi Fuchs2468, I noticed that in the Titan MOD Matrix that the shortcut is not working, below is the screen shorts screen from Leia, which works perfectly,
The problem would not have arisen, EMBY should not rename the addon.
This is also why the smart shortcuts with "plugin.video.emby-next-gen" does not work.
I have 2 versions for testing creates a "Emby-next-gen" and one for "Jellyfin".
Since I have no Emby I could only test with Jellyfin (free
It works with Jellyfin:
The following addons must be replaced:
- "script.module.metadatautils"
- "script.skin.helper.backgrounds"
- "script.skin.helper.service"
- "script.skin.helper.widgets"
- "skin.titan.mod.beta.matrix"
Here is the version for "Emby-next-gen":
Titan-Mod_Matrix+SHS_for_Emby-next-gen.zip
Here is the version for "Jellyfin":
Titan-Mod_Matrix+SHS_for_Jellyfin.zip
(2021-05-29, 21:17)Jogi0815 Wrote: [ -> ]Hello. I have a Problem with the Skin. I use Kodi Matrix.
I can not understand your problem, video info works.
Do you use this setting?
(2021-05-30, 21:25)Fuchs2468 Wrote: [ -> ] (2021-05-27, 22:41)t123thomas Wrote: [ -> ]Hi Fuchs2468, I noticed that in the Titan MOD Matrix that the shortcut is not working, below is the screen shorts screen from Leia, which works perfectly,
Since I have no Emby I could only test with Jellyfin (free ).
Here is the version for "Emby-next-gen": Titan-Mod_Matrix+SHS_for_Emby-next-gen.zip
Here is the version for "Jellyfin": Titan-Mod_Matrix+SHS_for_Jellyfin.zip
Thanks for the efforts, there was an error when loading the skin helper background so it fails to load, please let me know when to further test
here is the full log report
Log
ERROR <general>: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <class 'SyntaxError'>
Error Contents: invalid syntax (smartshortcuts.py, line 56)
File "C:\Users\Admin\AppData\Roaming\Kodi\addons\script.skin.helper.backgrounds\service.py", line 9, in <module>
from resources.lib.backgrounds_updater import BackgroundsUpdater
File "C:\Users\Admin\AppData\Roaming\Kodi\addons\script.skin.helper.backgrounds\resources\lib\backgrounds_updater.py", line 24, in <module>
from .smartshortcuts import SmartShortCuts
File "C:\Users\Admin\AppData\Roaming\Kodi\addons\script.skin.helper.backgrounds\resources\lib\smartshortcuts.py", line 56
def emby-next-gen_nodes(self):
SyntaxError: invalid syntax
(2021-06-01, 05:17)t123thomas Wrote: [ -> ] (2021-05-30, 21:25)Fuchs2468 Wrote: [ -> ] (2021-05-27, 22:41)t123thomas Wrote: [ -> ]
Log
I have created a new version for "emby-next-gen".
Please test and post new test report.
To educate a good test result please install Kodi new.
It can also be a portable installation.
here the link:
(2021-06-01, 23:32)Fuchs2468 Wrote: [ -> ] (2021-06-01, 05:17)t123thomas Wrote: [ -> ] (2021-05-30, 21:25)Fuchs2468 Wrote: [ -> ]
Log
here the link: Titan-Mod_Matrix+SHS_for_Emby-next-gen.zip
Same issue as before, after installing the repo which was fine without issue.Let me know what other steps to follow.
Then I downloaded the Titan-Mod Matrix Emby-next gen
Installed in this order
1, script.module.metadatautils (Fine)
2, script.skin.helper.backgrounds (Error)
3, script.skin.helper.service (Fine)
4, script.skin.helper.widgets (Fine)
5, skin.titan.mod.beta.matrix
Here is the log
Log
(2021-06-02, 05:00)t123thomas Wrote: [ -> ] (2021-06-01, 23:32)Fuchs2468 Wrote: [ -> ] (2021-06-01, 05:17)t123thomas Wrote: [ -> ]Thanks for the efforts, there was an error when loading the skin helper background so it fails to load, please let me know when to further test
Log
Here is the log
Log
Hi I just update with this version "script.skin.helper.backgrounds-master" it does resolved the error message, however, this does not resolved the shortcut issue, please let me know the next action
Log
(2021-06-03, 00:47)t123thomas Wrote: [ -> ] (2021-06-02, 05:00)t123thomas Wrote: [ -> ] (2021-06-01, 23:32)Fuchs2468 Wrote: [ -> ]
I tested yesterday with the EMBY server.
I have a good and bad news for you.
The bad news is Emby-next-gen does not seem to be kompertibel with SHS.
But now the good message install the Jellyfin Addon it works with your EMBY server.
The only thing that does not work is the automatic server detection, but no problem just give your server address manually a "localhost: 8096" and everything should work.
Here are the required links:
repository.jellyfin.kodi.zip
t123thomas
I am not very familiar with Python but so much I know, no hyphen should be used in a name at Pyhton. (emby-next-gen)
As a test, I also rewritten "plugin.video.emby-next-gen-5.3.1" in "plugin.video.emby_next_gen-5.3.1". (exactly 142 changes)
So I was able to integrate it without error in SHS.
Result:
Smart Shortcut does not work with "plugin.video.emby-next-gen", no idea what has been changed in this addon.
What is the latest version of the Kodi Skin?
Is there already a complete pack, or is it still needed to download and install all the depenencies first?
