(2022-07-22, 00:23)accacc5 Wrote: [ -> ]Hi there,
Issue with movie genre icons in all views (except Circle View).
There is a folder icon covering the genre icon. Tried all Icon sets with same results.
Any ideas guys?
Cheers.
You should update to Titan Mod version 19.1.23.
This problem has been solved.
Oh! I don't know why I didn't get the update, will force referesh the repo and do it now.
Thanks man!
Got the update, works great.
Thanks for your efforts.
Cheers.
How can I get "skin helper service color picker 2.0.2" script? I could only find 2.0.1
After new update OSD buffer doesn't seem to work -should show in bright orange in bottom left.
Enable OSD of buffering progress during video playback, is enabled in Playback & OSD, and OSD progress bar buffer cache color is set to a bright orange.
Worked fine in previous version.
(2022-07-22, 10:33)csts Wrote: [ -> ]After new update OSD buffer doesn't seem to work -should show in bright orange in bottom left.
This function is not available at the moment.
I have replaced this function with pvr Timeshift buffer.
I will try to integrate the buffer display again in the next update.
(2022-07-22, 03:20)psbguy Wrote: [ -> ]How can I get "skin helper service color picker 2.0.2" script? I could only find 2.0.1
The version is in my repo
(2022-07-22, 15:49)Fuchs2468 Wrote: [ -> ] (2022-07-22, 03:20)psbguy Wrote: [ -> ]How can I get "skin helper service color picker 2.0.2" script? I could only find 2.0.1
Got it, thanks! I was trying to install it manually in Android, as I was unable to install it from the repository.
Would it be possible to add "up next" pop-up for live tv?
(2022-07-24, 22:54)psbguy Wrote: [ -> ]Would it be possible to add "up next" pop-up for live tv?
I will see what I can do.
(2022-07-25, 11:58)Fuchs2468 Wrote: [ -> ] (2022-07-24, 22:54)psbguy Wrote: [ -> ]Would it be possible to add "up next" pop-up for live tv?
Thank you for looking into this, appreciated!
Fuchs2468
Hi
Little old bug in View_529_NetflixSeasons.xml (dont display right duration if time > 60 minute)
Line 142 : Change Duration(mm) with Duration(hh:mm)
<label>$INFO[Container(529004).ListItem().Duration(hh:mm),, $LOCALIZE[12391]]</label>
Regards
