Hopefully someone can help. I've had an issue with Kodi crashing using the Titan skin from Fuchs repo for a while now on all devices so, today, I tried to get to the root of the cause. I'm no closer really but, it seems, the skin or one of the dependencies is causing the crash. I installed Matrix 19.4 on Windows 10, fresh with no addons (just the default "Vanilla" addons), and then installed just the skin. I set it to Titan Tiles 3 rows then, Kodi crashes again after getting a skin helper service error notification a couple of times. I can't figure it out so, I'm hoping someone here has an idea. Here is my Windows log if it helps:
https://paste.kodi.tv/urexiyusam.kodi
Thank you!
(2022-07-26, 21:28)StelioKantos Wrote: [ -> ]Hopefully someone can help. I've had an issue with Kodi crashing using the Titan skin from Fuchs repo for a while now on all devices so, today, I tried to get to the root of the cause. I'm no closer really but, it seems, the skin or one of the dependencies is causing the crash. I installed Matrix 19.4 on Windows 10, fresh with no addons (just the default "Vanilla" addons), and then installed just the skin. I set it to Titan Tiles 3 rows then, Kodi crashes again after getting a skin helper service error notification a couple of times. I can't figure it out so, I'm hoping someone here has an idea. Here is my Windows log if it helps:
Thank you!
You might want to try a clean installation without banned addons.
Follow the forum rules.
There is no support for banned addons.
Official:Forum_rules/Banned_add-ons (wiki)
I have an Odroid N2 running coreelec with Kodi 18 and the Titan Vanilla skin.
I now wanted to update to the newest version of coreelec with Kodi 19.
Because the Vanilla Skin isn't supported anymore I installed the Titan version from the fuchs repo.
The Problem is, that my player freezes when playing videos. This happens randomly.
I noticed that my log is full of messages like:
2022-07-28 13:14:11.617 T:5172 INFO <general>: UpdateDetailsForMovie: Starting updates for movie 1868
2022-07-28 13:14:11.626 T:5172 INFO <general>: UpdateDetailsForMovie: Finished updates for movie 1868
2022-07-28 13:14:23.480 T:5172 INFO <general>: UpdateDetailsForMovie: Starting updates for movie 1893
2022-07-28 13:14:23.494 T:5172 INFO <general>: UpdateDetailsForMovie: Finished updates for movie 1893
2022-07-28 13:14:24.940 T:4235 INFO <general>: UpdateDetailsForMovie: Starting updates for movie 1941
2022-07-28 13:14:24.949 T:4235 INFO <general>: UpdateDetailsForMovie: Finished updates for movie 1941
On my old system, there were no lines like that in my log.
So I did a fresh install with the new coreelec version (without Titan Skin) and started to play a movie.
The movie plays fine and there are no such entries in the log file.
Then I installed the Titan skin, switched to the skin and started to play a movie.
Now the log is begining to fill with theses lines. After some time (40 min.) the machine freezes.
Any idea?
My last log:
Kodi.log
(2022-07-28, 15:37)grappi Wrote: [ -> ]
Have you new created your database for Kodi Matrix?
Or are you using the Kodi Leia database?
Fuchs2468
Hi .
For French users
There are missing strings in resource.language.fr_fr / string.po
Here they are :
msgctxt "#31922"
msgid "Unknown"
msgstr "Inconnu"
msgctxt "#31923"
msgid "Adventure"
msgstr "Aventure"
msgctxt "#31924"
msgid "Action"
msgstr "Action"
msgctxt "#31925"
msgid "Animation"
msgstr "Animation"
msgctxt "#31926"
msgid "Documentary"
msgstr "Documentaire"
msgctxt "#31927"
msgid "Drama"
msgstr "Drame"
msgctxt "#31928"
msgid "Family"
msgstr "Familial"
msgctxt "#31929"
msgid "Fantasy"
msgstr "Fantastique"
msgctxt "#31930"
msgid "History"
msgstr "Histoire"
msgctxt "#31931"
msgid "Horror"
msgstr "Horreur"
msgctxt "#31932"
msgid "Comedy"
msgstr "Comédie"
msgctxt "#31933"
msgid "War"
msgstr "Guerre"
msgctxt "#31934"
msgid "Crime"
msgstr "Crime"
msgctxt "#31935"
msgid "Romance"
msgstr "Romance"
msgctxt "#31936"
msgid "Music"
msgstr "Musique"
msgctxt "#31937"
msgid "Mystery"
msgstr "Mystère"
msgctxt "#31938"
msgid "Science Fiction"
msgstr "Science-Fiction"
msgctxt "#31940"
msgid "TV Movie"
msgstr "Téléfilm"
msgctxt "#31941"
msgid "Western"
msgstr "Western"
msgctxt "#31942"
msgid "Thriller"
msgstr "Thriller"
(2022-07-29, 12:01)Fuchs2468 Wrote: [ -> ] (2022-07-28, 15:37)grappi Wrote: [ -> ]
Kodi has done a conversion on first startup from MyVideos116 to MyVideos119. Now it uses the 119 database. Thought that this is okay.
(2022-07-29, 12:34)Fuchs2468 Wrote: [ -> ] (2022-07-29, 12:22)Aphykit2006 Wrote: [ -> ]
thanks, I will it add
Hi
Could you help me :
I'm looking add another moviegenre : 3D
Ok for new genre : NOk for picture.
Regards
(2022-07-29, 13:01)grappi Wrote: [ -> ] (2022-07-29, 12:01)Fuchs2468 Wrote: [ -> ] (2022-07-28, 15:37)grappi Wrote: [ -> ]
Hi
Uptate + migrate is a long process.
Leave kodi open a night.
(2022-07-29, 15:25)Aphykit2006 Wrote: [ -> ] (2022-07-29, 13:01)grappi Wrote: [ -> ] (2022-07-29, 12:01)Fuchs2468 Wrote: [ -> ]Have you new created your database for Kodi Matrix?
Hi
I can try that.
But what amazes me is that after a fresh install of Kodi with only the default Estuary skin there are no "UpdateDetailsForMovie:" in the log. These lines only show up after I have installed and activated Titan. Even if I then select a different skin, the lines remain.
Therefore, I assumed that these update processes are initiated by Titan. The funny thing is that the movie numbers also repeats regularly.
Yes
I thik updating is because skin helper services.
( not shure)
Regards
(2022-07-29, 16:50)grappi Wrote: [ -> ] (2022-07-29, 15:25)Aphykit2006 Wrote: [ -> ]
I can try that.
Look here the same problem.
The cause was a corrupted database.
https://forum.kodi.tv/showthread.php?tid=365816
Skin Helper Service searches for missing data on movies or tv shows and stores them in simpelcache.db.
(2022-07-30, 01:40)Fuchs2468 Wrote: [ -> ] (2022-07-26, 01:27)psbguy Wrote: [ -> ] (2022-07-26, 01:06)Fuchs2468 Wrote: [ -> ]
@psbguy.
I have discovered an error in Next PVR pop-up.
You can update here: PVR_NextUp_POPUP.zip
Fuchs2468 That is better for sure, the transparency fix makes it more readable on lighter backgrounds.
Thanks for the update!
(2022-07-29, 17:47)Fuchs2468 Wrote: [ -> ] (2022-07-29, 16:50)grappi Wrote: [ -> ] (2022-07-29, 15:25)Aphykit2006 Wrote: [ -> ]
I can try that.
Where can I find this simplecache.db?
My video database is hostet on a synology mysql server. All other databases are in kodi/userdata/databases.
But nowhere is a simplecache.db
If this is a corrupted database, any hints how to fix this?
