Hi, @
Fuchs2468
Regarding
Artwork Downloader / Artwork Beef.
I made the old Artwork Downloader addon back to life with Matrix supported and some code fixes (Personally, I prefer this than Beef in the DialogVideoInfo.xml screen)
In order to be able to use it again, I made a modification on these skin files:
- 1080i / IncludesSkinSetings.xml, IncludesDialogVideoInfo.xml, IncludesDialogMusicInfo.xml
- extras / skinsettings.xml
Can you add this officialy to your skin version?
It works perfectly:
Skin xml files:
https://f2h.io/cihb4um5d76v
Artwork Downloader 15.5.0.0 (Matrix) (Made by me) :
zip:
https://f2h.io/orl5efswxyia
Beef (Matrix) :
zip:
https://henryjfry.github.io/repository.t...0.28.6.zip
(2021-09-26, 16:08)Fuchs2468 Wrote: [ -> ] (2021-09-26, 15:21)burekas Wrote: [ -> ] (2021-09-26, 11:12)Fuchs2468 Wrote: [ -> ]
Simple confluence-style homescreen vertical
Activate "Titan Default Homescreen Layout".
Then the animation of the main menu is deactivated.
Thanks, I missed that.
I'm a big fan of the old Titan classic skin and I followed Marcel through the old version with bugs/comments/requests.
This is the reason I stuck with Kodi 17.6, but I decided to make a try and upgrade to v19,
My purpose is to bring this mod of yours to the same configuration/setep/look as I had.
Long time ago I wrote a big comment on some differences I noticed, but no one worked on them.
I will start to go over it again and open a fresh new comment in the future.
Thanks for you great work and contribution.
Titan is the best!
Using Titan-MOD (BETA) for MATRIX 19.1.22
Layout Netflix Origin
The home screen doesn't show the header. (it's a clock)
Just changing the layout to Netflix Style Home Menu Layout, shows the clock.
Only in the main home screen this happens, not the sub pages.
(2021-09-26, 18:05)Zodler Wrote: [ -> ]Using Titan-MOD (BETA) for MATRIX 19.1.22
This is so wanted at "Netflix Origin". The header does not fit the "Netflix Origin" Design.
That's why Titan Mod also has 16 different home layouts.
This selection should have a suitable layout for everyone.
You put in the skin settings that you can have a header for the main menu.
If I didn't want it I can disable it but I want the clock, it should show it.
If anyone didn't like it, they can disable it. Please show it. It is in the skin settings.
(2021-09-27, 00:56)Zodler Wrote: [ -> ]You put in the skin settings that you can have a header for the main menu.
Please also remember that I do all this in my free time and can not fulfill every wish.
I am grateful for all suggestions and will also implement them, if I think it's useful and necessary.
But please do not put myself under pressure, I do not like that.
But I'll think about whether I install a switch for the clock in "Netflix Origin".
(2021-09-26, 17:03)burekas Wrote: [ -> ]Regarding Artwork Downloader / Artwork Beef.
Thanks for the files, I will test it.
At the moment I do not have the time to answer you in detail.
Jeez. Nobody is putting anyone under pressure. How on earth I can put anyone on pressure? I'm just reporting the things I see.
In your mind sharing information is putting under pressure? Grow up please. You can do whatever you want of course. One is, ignore posts and not to reply to every post.
(2021-10-05, 01:54)ThatSlimGuy Wrote: [ -> ] (2021-09-26, 17:03)burekas Wrote: [ -> ]Hi, @Fuchs2468
This is awesome. Is there any easy way for us to implement it manually or is it easier to wait to possibly be integrated ??
This is simple to do it also by your own.
As I wrote:
Download the "skin zip files" I made and put them in the skin addon files:
Then download and install the Artwork addons (One of them or both, whatever you like)
In the skin settings set and enable the video info buttons as you like.
(2021-09-07, 13:45)Fuchs2468 Wrote: [ -> ]Update Titan-Mod Matrix version 19.1.22
- fix clearlogo
repository.fuchs246-1.0.0.zip
Hello am keen to try out your Titan mod, alas I'm not able to get your repo to install.
Is there a possibility that the link isn't working at the moment ?
(2021-10-07, 07:14)circuit Wrote: [ -> ] (2021-09-07, 13:45)Fuchs2468 Wrote: [ -> ]Update Titan-Mod Matrix version 19.1.22
- fix clearlogo
The link works. Click the Download Button.
