Full Version: Titan M O D ( last Updated 19-12-2019)
(2021-04-14, 01:20)Fuchs2468 Wrote: [ -> ]
(2021-04-13, 04:14)t123thomas Wrote: [ -> ]Hi Guys I am not sure which  of the Titan addons that is causing the cpu to run high and loud, before I installed the Titan skin the cpu was runing very low and quiet (pic1), shortly after installing Titan the cpu runs high and even when I switch back to confluence (pic2). The cpu returns to normal after I restated Librelec with confluence skin, please advise which addon to turned off in order to use Titan without cpu running high
Unfortunately, I can not tell you why that's the case with you, I have a Raspiberry 3+ and there is no Kodi 19 version of Libreelec yet.
You have to wait a while.
In general, however, I can tell you that the Skin Helper needs after a new installation, for a while until he has all the information he needs.
Of course, this can mean that your Raspberry 4 has a high CPU load for this time.
I am on interl ® Core ™ i5-8500 CPU @ 3.00/ Libreelec Generic.
Anyway, the cpu is runing low and quiet now
Hi @Fuchs2468
Here are some remarks and suggestions to improve the Titan Mod. atrix skin.
Note that I use the TitanTile layout (1 row of large tiles)
A little SHS bug in menu shortcuts
Edit menu shortcuts: Selecting an application no longer puts its thumbnail. we have to select it manually.
In the panel view
Big plot overlay: would it be possible to have something prettier, like in the aeon xx skins.
for example to use the bottom bar by dragging it upwards and indicating the various information (genre, duration, media tags, sinopsys, character art, ...)
I would very much like.  May be an Info Popup ??
In View View_529_NetflixSeasons.
little bug : after use, we lose the keyboard focus on exit. Obliged to go back (Escape) to the general menu.
Is it possible to add the media flags as well as the end time of the proposed episode? (page 2)
And I find the opacity on the fanart backgound too strong.
Here is a version with a lighter opacity: View_529_NetflixSeasons.xml
The ideal would be to have the choice as in the other views (hide (or not) customisable panel background)
Video info screen (Notice I use Enhanced VIP info)
In the same vein, opacity management is missing in the extended information view for films (VIP info) : it's because the use of the global background does not work well (if we put transparency in background color diffuse, the background inside film information screen is transparent too) probably another bug with IncludesBackgroundBuilding.xlm
This one is probably very difficult: IncludesBackgroundBuilding.xml
With the selection Skin settings / Media library views / Use ExtraFanart: dont use Skinhelper service
 In infomation views (Serial movies and music) the background is black instead of displaying the fanart (s).
Here is a small fix that only displays one image (but no multiple fanart) IncludesBackgroundBuilding.xml
with regard to film and series genres
Here is a French corrective language file but I cheated for the "3d" genre and the 'Kids "type is also missing : resource.language.fr_fr
There you go, it's a bit long. and I still have plenty of ideas
for example: for music: do as for series with the Netflix info view
Thanks for reading me
An answer is not urgent.
Regards
Please can you add to the player processing information mainly those hghlited in RED
videocamVideo
Title1080p HEVC
Codec HEVC
ProfileMain 10
Level12
0
Resolution1920x1080
Aspect Ratio16:9
Interlaced No
Framerate24
Bitrate2,579 kbps
Bit Depth10 bit
Pixel Formatyuv420p10le
Reference Frames1
AudiotrackAudio
Title English EAC3 6 ch (Default)
Language English
Codec EAC3
Channels 6 ch
Sample Rate48,000 Hz
(2021-04-14, 20:10)t123thomas Wrote: [ -> ]Please can you add to the player processing information mainly those hghlited in RED
videocamVideo
Title1080p HEVC
Codec HEVC
ProfileMain 10
Level12
0
Resolution1920x1080
Aspect Ratio16:9
Interlaced No
Framerate24
Bitrate2,579 kbps
Bit Depth10 bit
Reference Frames1
AudiotrackAudio
Language English
Codec EAC3
Channels 6 ch
Hi
Something like this ?
A question: are theses informations in the database ?
Hi
Little bug in Matrix mod.
When playing Music : slideshow does'nt work anymore with the new Matrix structure.
No fanart and no clearart.
( but ok in infoviews)
May be because smb acces?
Regards
EDIT
An idee: I'll try with local artis folder. ( not yet)
Edit 2 : same punition. Stay on fallback bg, without clearlogo.
(2021-04-15, 08:35)Aphykit2006 Wrote: [ -> ]
videocamVideo
Title1080p HEVC
Codec HEVC
ProfileMain 10
Level12
0
Resolution1920x1080
Aspect Ratio16:9
Interlaced No
Framerate24
Bitrate2,579 kbps
Bit Depth10 bit
Reference Frames1
AudiotrackAudio
Language English
Codec EAC3
Channels 6 ch
Hi
Yes Sir that is what I am referring to
(2021-04-17, 21:05)t123thomas Wrote: [ -> ]
videocamVideo
Title1080p HEVC
Codec HEVC
ProfileMain 10
Level12
0
Resolution1920x1080
Aspect Ratio16:9
Interlaced No
Framerate24
Bitrate2,579 kbps
Bit Depth10 bit
Reference Frames1
AudiotrackAudio
Language English
Codec EAC3
Channels 6 ch
Hi
Hi.
Press O when playing .
(It isn't skin, but kodi player. ).
Regards
(2021-04-18, 07:43)Aphykit2006 Wrote: [ -> ]
(2021-04-15, 08:35)Aphykit2006 Wrote: [ -> ]Hi
Hi.
Regards
I am aware of the O function, so you mean that its a default of Kodi.
(2021-04-18, 16:02)t123thomas Wrote: [ -> ]
(2021-04-17, 21:05)t123thomas Wrote: [ -> ]Yes Sir that is what I am referring to
Hi.
Regards
Hi
May be you could make a request on kodi's github
(2021-03-30, 02:54)t123thomas Wrote: [ -> ]@Fuchs2468,
@AchillesPunks
Please dont forget to add these changes to the skin  this is to ensure Matrix Titan  Skins are compatible Matrix- Emby Next gen plugin
IncludesSkinSetings.xml
                <selected>Skin.HasSetting(SmartShortcuts.emby) + System.HasAddon(plugin.video.emby)</selected>
                <enable>System.HasAddon(plugin.video.emby)</enable>
should be:
                <selected>Skin.HasSetting(SmartShortcuts.emby) + System.HasAddon(plugin.video.emby-next-gen)</selected>
                <enable>System.HasAddon(plugin.video.emby-next-gen)</enable>
and here:
                <param name="addon" value="plugin.video.emby" />
should be:
                <param name="addon" value="plugin.video.emby-next-gen" />
Hi Can you please help to confirm that these have been fixed, I couldn't find the addons in Libreelec back to validate and make changes if necessary, appreciate if someone can direct me to the location in Libreelec so I can make the changes myself.
should be:
and here:
should be:
In addition, I observed that when I use keyboard to navigating the UI the keyboard often freezed or hanged, also I added several submenus these does not often work.
Do
Does someone knows if “set thumbnail” in edit menu shortcuts works on 19.1.19alpha? For me, nothing happens when i click on it..
(2021-04-18, 17:12)simtaj Wrote: [ -> ]Does someone knows if “set thumbnail” in edit menu shortcuts works on 19.1.19alpha? For me, nothing happens when i click on it..
Yes for me, need last updates skin helper's modules.
(2021-04-18, 17:50)Aphykit2006 Wrote: [ -> ]
Can you please tell me what version of skinhelper is the right one, for this to work. I have version 1.1.35 and with this is not working...
@simtaj
1.35 too
Notice : i started with a fresh install.
Update from leia does'nt work fine (icon and some packs : no research)
I use titan title.
Try reset menu at default values.
And adding a program does not add the thumbnail.
Need create one + add manually every thumbnail .
Q: does music slideshow work for you ?( with artist logo)
Regards.
