(2019-06-21, 15:48)Abbaskip Wrote: [ -> ]Has something happened to the music art? I still have them enabled (artist pictures etc whilst songs playing) and they show whilst over a song in the menu, but as soon as it's playing it goes to a solid dark blue background
This is really driving me batty now - is anyone else noticing this? Music art shows when you're in the menu and it's playing in the background, as soon as you go to 'full screen' - or hide the menu, it changes to a black screen.
(2019-06-22, 07:24)Abbaskip Wrote: [ -> ] (2019-06-21, 15:48)Abbaskip Wrote: [ -> ]Has something happened to the music art? I still have them enabled (artist pictures etc whilst songs playing) and they show whilst over a song in the menu, but as soon as it's playing it goes to a solid dark blue background
On git version i made changes to improve a bit performance wise side for backgroundbuiling also have ability to dont use skinhelper for rotating extra fanart (new skinsetting)
Titan default/previous version did load images which arent need be loaded/visible.
i did a
quick test, and didnt noticed an issue there.
But may i missed something for music vis\artist slideshow.Will do further investigate next week
I will check that.
New release have no eta , as my time is very limited now next 3 weeks.
(2019-06-22, 12:34)mardukL Wrote: [ -> ] (2019-06-22, 07:24)Abbaskip Wrote: [ -> ] (2019-06-21, 15:48)Abbaskip Wrote: [ -> ]Has something happened to the music art? I still have them enabled (artist pictures etc whilst songs playing) and they show whilst over a song in the menu, but as soon as it's playing it goes to a solid dark blue background
i did a quick test, and didnt noticed an issue there.
I will check that.
The version straight from the git doesn't have the issue, so using that
I've just installed on a mate's Kodi box, straight from the github - and the little spinning Icon next to widget when they're loading doesn't seem to be there. Is this a setting?
It's key, as with any Skin Helper skins, if widgets are still loading when you go into Library, the Library views jump around.
NOTICE !!!
I will be away for next 3 weeks and couldnt finished the skin as i wanted to be, therefore i choosed make it public this way.
I case of lacking in free time i uploaded the latest alpha, on git.
If you like to you can test and report back some more issues.
Its mostly stable but still got some "bugs" , It needs to be downloaded and installed manualy (install from zip via kodi addon manager)
Here is the link ->
skin.titan.mod.beta.leia-18.1.13~alpha4.zip
Quote:
BUGS/ to do for final
- resolve clearlogo for spotlight trailer playing (temp use text label instead of logo for trailer playback due to widget refresh on playback start )
- find/make better diffuse texture / or use overlay for fanart spotlight focus
- repack images for themes (get rid of some [!]Skin.HasTheme([themename]))
- check issues with circle widgets/ViewItems (go over visibilitry conditions)
- rsolve artwork issues on skin serach
- resolve issues for Netflix Hubs
Actual Changlog:
Quote:SETTINGS WINDOW
- changed layout
SKINSETTINGS
- moved Skin.HasSetting(Home_TransParentTiles) setting to corresponding home section
- Trailers will auto fallback to youtube, if not "never do online lookup" is enebled (WIP)
- add new color ' ViewListAndDetailPanelColorNF '
- intention - diffused color for non-/-focused items, without losing wished colors in other layouts -
- choose if you wann use skinhelper service or native(Non-Addon) for showing ExtraFanart
- when not using skinhelper, you will also have rotating fanart available for musicvideos
- CHOOSE CAST PROVIDER for VideoInfo
- or skinhelper service
- or embuary
- added CAST ACTION
- perform library search via Skin Search by selceting a cast member in VideoInfo (actual just non netflix videoinfo)
- you need to set 1 provider after install new version in skinsettings -> library settings (if not no cast will show up)
- add new setting to use new "enhanced VideoInfo Screen" https://streamable.com/r969u
( it uses - 3 scrollable 'pages' (options for toggle some unwanted containers show/dont show will come next update) )
- Netflix2 Home - decide between 2 spotlight button layouts (frame bg, panel bg)
- check your Colors in Custom Color Section because they are need to handle colors differently
- Netflix Layouts - choose between Mpaa 2 Flag Layouts (default = diffuse frame , Alternative Layout = panel bg (Netflix Style))
EXTENDED INFO
- fixed studio logo not showing
FONT specific
- FOR TAGS - add font Alcubierre Font by Matt Ellis / Ellis Design
- FOR NETFLIX(523) - CLEARLOGO TITLE FALLBACK - add font CircleC Font
(http://allfont.net/download/circlec/ )
https://imgur.com/a/tebzuBh
- add new font helvetica neue for netflix layouts
HOME
- solved issues with "dont showing Widget Header" when scroll up again
- Win10 - enebled option to use zoom animation
- win10 - fixed scrollbar, now could be focused
- added option - show widget header centered
- larger square submenu , removed outstanding label, add submenu label at item bottom (optional layouts WIP)
HEADER
- slightly decreased height and adjusted labels/icons (comparison def vs. win10 style https://i.imgur.com/FfLnn2h.jpg)
(there will a decision , to just use 1 header header layout in future)
- add label/content for skin search
WIDGETS
- widget header are no longer hidden, when scroll up to previous widgets (all vertical home layouts)
- fixed several issues , when using multiple rows for some layout types
- cleanup some conditions
- landscapewidebox
- slight edit of focus animation
- is always fixed-list now
- if you have it already in use, you will need to re-set it as your widget layout
- added option to use use "dimmed play button" on focus
- changed focus zoom for widgets
- add focus animation for detail widgets (posterdetails,landscapedetails) (always)
- removed tag OVERLAY, tags are now at bottom below widget, not inside artowrk
- added new widget type 'circle' https://streamable.com/jwzqt
- added new widget type 'netflix spotlight' , replacement for current spotlight WIP, improvements needed
- correction posterthumb position - posterdetails widget
VIEWS
- fixed issue where No/wrong viewtype label is shown (525,526,527)
- fixed color issues
- added option to use use "dimmed play button" on focus (Credits for the Idea and the the playbutton belongs to @SualFred)
- add NEW viewtype 'Circle' kept the id (529)
https://imgur.com/a/q4ZkfOq
- Panel Wall (520)
- dont show header ( fixed overlay )
- List (50)
- removed discart option
- Netflix Potser - View (523)
- fixed discart animations
- fixed artwork + focusedlayout position
- optional font style for Titles if clearlogo not available (https://i.imgur.com/asXO5CQ.jpg)
- adjusted layouts in generell
TAGS
adjusted view types to use tags at bottom instead overlay (WIP)
overlay based on missing artwork is still in
- toggle them on off via Slidemenu Setting in Viewtypes, or in Shortcut Section for Widgets
SHORTCUTS
- fix some paths to windows
- fix not working submenu for "Music" Entry
- fix not working subsection for Shows: recentlyaddedepisodes, inprogresstvshows
- add some default Submenu entry for "TV Shows", "Musicvideos", "Movies"
- use xsp/native path (just) for sub sections instead skinhelper.service.widgets for : recentlyaddedmovies , InProgressMovies, UnwatchedMovies
SEARCH
- adjusted custom search (spotlight bg image unresolved)
MISC
- some more minor stuff and fixes, to improve performance
- cast provider on Netflix Trailer Playback in is now 'embuary helper' , faster (also dont need predefined actions actions)
- alphabet scrollbar 'provider' is now embuaryhelper, seems faster, also hiding 'empty' letter content
[" - started some code overhaul,
the goal for the future will be, that
script.skin.helper.service ,
script.skin.helper.widgets,
script.skin.helper.backgrounds (pretty resource hungry)
will not be neccessary dependencie addons,
Rotating Section Backgrounds will be replaced with a 'native' method, "]
Wanted to say a quick thanks for the work you've done on the skin and these updates. Have been enjoying it for sometime and its absolutely fantastic.!
(2019-06-26, 11:37)Leo2807 Wrote: [ -> ]Wanted to say a quick thanks for the work you've done on the skin and these updates. Have been enjoying it for sometime and its absolutely fantastic.!
Thanks alot ;-)
Hello
what are the parameters or addons that you use to make the clearlogo appear
Does anyone know how to decrease the transparency of the full pvr guide when livetv is playing. It seems to have changed with the new alpha and is very hard to read over a moving background.
Edit: figured it out, somehow the texture overlay was set to none
Does this skin have Manfeed lyrics support?
Hi @
mardukL
i want to tell another bug (not fixed with 13 version beta 4)
So if youre going to create a menu point "Movies" and under "Movies" youll create two submenus.
Example:
"Movies"
--> "Submenu1"
--> "Submenu2"
After you choose your source at the end you must choose which kind of source it is. (like fileview, movies, series ...)
if you choose "movies" there will not directly go to your movie source rather to script.skinshortcuts. After another click yo come to your movie source.
Do you know about this issue?
Firstly, many thanks for this fantastic skin...really appreciate the hard work keeping this skin alive!
I've updated to the new alpha and it's great, apart from one issue.
I'm using Netflix Landscape for TV episodes. The previous versions showed the episode number/name as a tag.
In the new alpha version this is missing and replaced by the series logo. I cannot find an option anywhere to show the episode name/number.
Can this be reinstated?
Try out Titan Bingie. It would solve this problem.
(2019-07-02, 02:17)jdig4240 Wrote: [ -> ]Does this skin have Manfeed lyrics support?
no , sorry.
unsure if i will add it somerime.
actually just basic cu lrc lyrics.
(2019-07-07, 01:37)Johnny1982fd Wrote: [ -> ]Hi @mardukL
Example:
"Movies"
--> "Submenu1"
--> "Submenu2"
i need to test this soon.
didnt noticed that behaviour.
